07-11-2021, 07:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | May the team help how to write this file with JTAG Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2200 mV Box S/N: 447541118F10F29C, ,FW Ver.: 02.53 CMD Pullup Level:1046 mV CMD Active Level:1658 mV Box IO Level:2200 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A54443452000684ECE174F9 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2017 Rev.0x0 eMMC NAME: BJTD4R , S/N: 109374689 eMMC NAME (HEX): 424A54443452 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMBG2JETD-B041/32GB @FBGA169 Rev2 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMBG2JETD-B041/32GB @FBGA169 Rev9 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_ 109374689_20210711_0759.extcsd Partition info not found Done. ERROR: PARTION INFO NOT FOUND ,HOW MAY I FIX THIS PARTITON? |
