04-25-2017, 14:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: syria
Member: 205475 Status: Offline Thanks Meter: 179 | MT6580 change emmc not work old emmc info: Code: ---------- eMMC Device Information ---------- EMMC CID : 8801034E4361726420269601F32F33D8 EMMC CSD : D0FFFF320F5903FFFFFFFFE7964000EA EMMC Manufacturer ID: 0088 , OEM ID: 0103 EMMC Date: 03/2016 Rev.0x26 EMMC NAME: NCard , S/N: 2516710191 EMMC NAME (HEX): 4E436172642000 EMMC ROM1 (Main User Data) Capacity: 7393 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: NCard _2516710191_20161113_1806.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 00000000-0000-0000-0000-000000000000 Warning: Entries Count = 21 MMCBLK0P0 (PROINFO) Range: [0X80000,0X37FE00] ,Len: 300000 MMCBLK0P1 (NVRAM) Range: [0X380000,0X87FE00] ,Len: 500000 MMCBLK0P2 (PROTECT1) Range: [0X880000,0X127FE00] ,Len: A00000 MMCBLK0P3 (PROTECT2) Range: [0X1280000,0X1C7FE00] ,Len: A00000 MMCBLK0P4 (SECCFG) Range: [0X1C80000,0X1CBFE00] ,Len: 40000 MMCBLK0P5 (LK) Range: [0X1CC0000,0X1D1FE00] ,Len: 60000 MMCBLK0P6 (BOOT) Range: [0X1D20000,0X2D1FE00] ,Len: 1000000 MMCBLK0P7 (RECOVDRY) Range: [0X2D20000,0X3D1FE00] ,Len: 1000000 MMCBLK0P8 (PARA) Range: [0X3D20000,0X3D9FE00] ,Len: 80000 MMCBLK0P9 (LOGO) Range: [0X3DA0000,0X459FE00] ,Len: 800000 MMCBLK0P10 (DXPDB) Range: [0X45A0000,0X4F9FE00] ,Len: A00000 MMCBLK0P11 (FRP) Range: [0X4FA0000,0X509FE00] ,Len: 100000 MMCBLK0P12 (NVDATA) Range: [0X50A0000,0X709FE00] ,Len: 2000000 MMCBLK0P13 (METAD`TA) Range: [0X70A0000,0X97FFE00] ,Len: 2760000 MMCBLK0P14 (OEMKEYSTORE) Range: [0X9800000,0X99FFE00] ,Len: 200000 MMCBLK0P15 (SECRO) Range: [0X9A00000,0X9FFFE00] ,Len: 600000 MMCBLK0P16 (KEYSTORE) Range: [0XA000000,0XA7FFE00] ,Len: 800000 MMCBLK0P17 (SYSTEM) Range: [0XA800000,0X6A7FFE00] ,Len: 60000000 MMCBLK0P18 (CACHE) Range: [0X6A800000,0X7A7FFE00] ,Len: 10000000 MMCBLK0P19 (USERDATA) Range: [0X7A800000,0X1CD07FE00] ,Len: 152880000 MMCBLK0P20 (FLASHINFO) Range: [0X1CD080000,0X1CE07FE00] ,Len: 1000000 Table Checksum: BAD (read: 846d8507 / calc: 4a8ce622) Done...Presets has been updated... Done. i try to change it by i9300 emmc Code: The size of the last section has been updated HiPower mode is OFF CMD Pullup Level: 3176 mV CMD Active Level: 3258 mV EMMC Device Information : EMMC CID: 15010056545530304DFC3D39868641FA EMMC CSD: D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacture Name: SAMSUNG EMMC NAME: VTU00M , S/N: 3D398686 , rev. FC EMMC NAME (HEX): 56545530304D EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: VTU00M_3D398686_20170425_160914.extcsd EMMC Init completed. Opening file: MT6580_Android_scatter.txt The new format of scatter config_version: V1.1.2 platform: MT6580 preloader_magc6580_we_l.bin Found 9 supported eMMC CID: name = 'FJ25AB' hex = 0x464A32354142 [SAMSUNG] name = 'F5X5CB' hex = 0x463558354342 [SAMSUNG] name = 'EMC04G' hex = 0x454D43303447 [Unknown vendor] name = 'P1J94M' hex = 0x50314A39344D [MICRON] name = 'DS1008' hex = 0x445331303038 [SANDISK] name = 'SHP808' hex = 0x534850383038 [Unknown vendor] name = 'EMC08G' hex = 0x454D43303847 [Unknown vendor] name = 'P1J95K' hex = 0x50314A39354B [MICRON] name = 'P1J94K' hex = 0x50314A39344B [MICRON] The size of the last section has been updated i make patch cid and emmc name chnge to name = 'FJ25AB' hex = 0x464A32354142 [SAMSUNG] thin write rom. after soldered to mobile not work pc detect it but not flashing any help thanx |
04-26-2017, 13:56 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | maybe its because of userdata size MMCBLK0P19 (USERDATA) Range: [0X7A800000,0X1CD07FE00] ,Len: 152880000 the question how to resize new emmc: EMMC ROM 1 (Main User Data) Capacity: 15028 MB original emmc: EMMC ROM1 (Main User Data) Capacity: 7393 MB |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
