08-14-2020, 07:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | mtk6768 cpu model vivo y19 firmware how can write preloader_k68v1_64.bin Found 9 supported eMMC CID: Warning: Parser does not support this preloader Send the preloader to support |
08-14-2020, 07:53 | #2 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | The new format of scatter config_version: V1.1.8 platform: MT6768 preloader_k68v1_64.bin Found 9 supported eMMC CID: Warning: Parser does not support this preloader Send the preloader to support The size of the last section has been updated |
08-14-2020, 15:25 | #3 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100335636434D4202BFA5DA6935BD EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 3V6CMB , HEX: 335636434D42 , S/N: BFA5DA69 , rev. 0x02 EMMC ROM 1 (Main User Data) Capacity: 119276 MB (001D1EC00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 61419 , Response: Not Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x02 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: 3V6CMB_BFA5DA69_20200814_195101.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 001D1EBFBE00 GPT-partitioning done Partition name: preloader Filename: preloader.bin , Offset: 000000000000 , filesize: 307848 bytes eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 1655.33 KB/s Partition name: bootloader_rom3 Filename: bootloader_rom3.bin , Offset: 000000000000 , filesize: 4194304 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 7530.03 KB/s Partition name: PRELOADER Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\preloader.bin Partition name: recovery Filename: recovery.bin , Offset: 000000008000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12381.94 KB/s Partition name: misc Filename: misc.bin , Offset: 000004008000 , filesize: 524288 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 6627.84 KB/s Partition name: para Filename: para.bin , Offset: 000004088000 , filesize: 524288 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 7452.24 KB/s Partition name: expdb Filename: expdb.bin , Offset: 000004108000 , filesize: 20971520 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 15379.64 KB/s Partition name: frp Filename: frp.bin , Offset: 000005508000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8203.75 KB/s Partition name: vbmeta Filename: vbmeta.bin , Offset: 000005608000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 9025.77 KB/s Partition name: backup Filename: backup.bin , Offset: 000005E08000 , filesize: 10485760 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 10073.99 KB/s Partition name: survival Filename: survival.bin , Offset: 000006808000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12323.24 KB/s Partition name: reserved Filename: reserved.bin , Offset: 00000A808000 , filesize: 10485760 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12791.45 KB/s Partition name: cust Filename: cust.bin , Offset: 00000B208000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 15776.76 KB/s Partition name: vgc Filename: vgc.bin , Offset: 00000F208000 , filesize: 209715200 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 19487.36 KB/s Partition name: metadata Filename: metadata.bin , Offset: 00001BA08000 , filesize: 33554432 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 17882.89 KB/s Partition name: nvcfg Filename: nvcfg.bin , Offset: 00001DA08000 , filesize: 33554432 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 11105.64 KB/s Partition name: nvdata Filename: nvdata.bin , Offset: 00001FA08000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 14501.25 KB/s Partition name: persist Filename: persist.bin , Offset: 000023A08000 , filesize: 50331648 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 19602.51 KB/s Partition name: protect1 Filename: protect1.bin , Offset: 000026A08000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8902.50 KB/s Partition name: protect2 Filename: protect2.bin , Offset: 000027208000 , filesize: 14647296 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 10173.24 KB/s Partition name: seccfg Filename: seccfg.bin , Offset: 000028000000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8900.11 KB/s Partition name: sec1 Filename: sec1.bin , Offset: 000028800000 , filesize: 2097152 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 10180.58 KB/s Partition name: proinfo Filename: proinfo.bin , Offset: 000028A00000 , filesize: 3145728 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8488.06 KB/s Partition name: efuse Filename: efuse.bin , Offset: 000028D00000 , filesize: 524288 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 5614.61 KB/s Partition name: boot_para Filename: boot_para.bin , Offset: 000028D80000 , filesize: 27262976 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 15051.02 KB/s Partition name: nvram Filename: nvram.bin , Offset: 00002A780000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 17269.40 KB/s Partition name: logo Filename: logo.bin , Offset: 00002E780000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8954.74 KB/s Partition name: md1img Filename: md1img.bin , Offset: 00002EF80000 , filesize: 134217728 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 14336.17 KB/s Partition name: spmfw Filename: spmfw.bin , Offset: 000036F80000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 6924.81 KB/s Partition name: scp1 Filename: scp1.bin , Offset: 000037080000 , filesize: 6291456 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8883.20 KB/s Partition name: scp2 Filename: scp2.bin , Offset: 000037680000 , filesize: 6291456 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8701.94 KB/s Partition name: sspm_1 Filename: sspm_1.bin , Offset: 000037C80000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 7894.03 KB/s Partition name: sspm_2 Filename: sspm_2.bin , Offset: 000037D80000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8171.22 KB/s Partition name: gz1 Filename: gz1.bin , Offset: 000037E80000 , filesize: 16777216 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12724.18 KB/s Partition name: gz2 Filename: gz2.bin , Offset: 000038E80000 , filesize: 16777216 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12854.36 KB/s Partition name: lk Filename: lk.bin , Offset: 000039E80000 , filesize: 5242880 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8805.20 KB/s Partition name: lk2 Filename: lk2.bin , Offset: 00003A380000 , filesize: 5242880 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8778.84 KB/s Partition name: boot Filename: boot.bin , Offset: 00003A880000 , filesize: 67108864 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 12423.75 KB/s Partition name: dtbo Filename: dtbo.bin , Offset: 00003E880000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8981.50 KB/s Partition name: tee1 Filename: tee1.bin , Offset: 00003F080000 , filesize: 5242880 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 8878.90 KB/s Partition name: tee2 Filename: tee2.bin , Offset: 00003F580000 , filesize: 11010048 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 10200.28 KB/s Partition name: vendor Filename: vendor.bin , Offset: 000040000000 , filesize: 1610612736 bytes eMMC switching to ROM1 Writing partition... |
