05-07-2017, 14:02 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | N7000 dead boot ( emmc repair) Checking NAND Image : K:\Easy Jitag\easy tag repair file\dump\Samsung\N 7000\babu bai\N7000 ok readed Dump\EMMC_ROM1_00000000_04000000 64mb mcc.bin File successefuly loaded! Found ROM2 and automatically selected. Processing file...K:\Easy Jitag\easy tag repair file\dump\Samsung\N 7000\babu bai\N7000 ok readed Dump\EMMC_ROM1_00000000_04000000 64mb mcc.bin Processing file...K:\Easy Jitag\easy tag repair file\dump\Samsung\N 7000\babu bai\N7000 ok readed Dump\EMMC_ROM2_00000000_00080000 mcc.bin ROM3 Are not selected , skip writing ROM2 extCSD Are not selected , skip writing extCSD Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:567 mV CMD Active Level:2351 mV Input file : K:\Easy Jitag\easy tag repair file\dump\Samsung\N 7000\babu bai\N7000 ok readed Dump\EMMC_ROM1_00000000_04000000 64mb mcc.bin Writing 0004000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 310 kB/s Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:567 mV CMD Active Level:2351 mV Input file : K:\Easy Jitag\easy tag repair file\dump\Samsung\N 7000\babu bai\N7000 ok readed Dump\EMMC_ROM2_00000000_00080000 mcc.bin Writing 0000080000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 292 kB/s Z3X EasyJtag Software ver. 2.0.6.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58 CMD Pullup Level:567 mV CMD Active Level:2351 mV eMMC Device Information EMMC CID : 15010056594C30304D194DEE017A11D2 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x19 EMMC NAME: VYL00M , S/N: 1307443578 EMMC NAME (HEX): 56594C30304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00M_1307443578_20170306_1600.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000 MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000 MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000 MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000 MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P6 (CACHE) Range: [0X3400000,0XFBFFE00] ,Len: C800000 MMCBLK0P7 (MODEM) Range: [0XFC00000,0X10BFFE00] ,Len: 1000000 MMCBLK0P8 (FACTORYFS) Range: [0X10C00000,0X45FFFE00] ,Len: 35400000 MMCBLK0P9 (DATAFS) Range: [0X46000000,0XC5FFFE00] ,Len: 80000000 MMCBLK0P10 (UMS) Range: [0XC6000000,0X38AFFFE00] ,Len: 2C5000000 MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000 Done...Presets has been updated... Done. Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:567 mV CMD Active Level:2351 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00400000 (4194304 bytes) Super Page size : 0x00008000 (32768 bytes) Optimal Write size : 0x00008000 (32768 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00040000 (262144 bytes) Total Number of banks : 2 Initial bad blocks per bank : 11,11,0,0 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 130,130,0,0 All Erase counts (min,avg,max): 0,0,13 SLC Erase counts (min,avg,max): 0,0,13 MLC Erase counts (min,avg,max): 0,0,1 S.M.A.R.T Report Done. |
The Following 3 Users Say Thank You to ALI_MAFIA For This Useful Post: |
