03-31-2017, 12:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | N7100 boot repair done with easy jatag EMMC CID : 15010056545530304DF1145768EF9FE2 EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 341272815 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_ 341272815_20170331_1558.extcsd Done. Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:0 mV CMD Active Level:2103 mV Box IO Level:2800 mV CLK Rate:14000 khz Removing write protection... Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:0 mV CMD Active Level:2103 mV Box IO Level:2800 mV CLK Rate:14000 khz EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! <font color="red">Please don't forget to repair extCSD from backup!</font> Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:0 mV CMD Active Level:2103 mV Box IO Level:2800 mV CLK Rate:14000 khz Sending Smart Wipe Request... Wiping Card... Please do not touch it! <font color="red">Please don't forget to repair extCSD from backup!</font> Done. Running:SAMSUNG: eMMC firmware update... EMMC NAME: VTU00M Z3X EasyJtag Software ver. 2.5.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 06010016636F12BE, ,FW Ver.: 01.56 CMD Pullup Level:1320 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:140000 khz Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 341272815_20170331_1558.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:140000 khz Writing... Done. Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:140000 khz Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:140000 khz Writing eMMC Register... Written: REG : 177 VAL :1 Done. Checking NAND Image : C:\Users\admin\Downloads\Compressed\RR\N7100_Rom1_ Alive_Dump_BN.bin File successefuly loaded! Processing file...C:\Users\admin\Downloads\Compressed\RR\N710 0_Rom1_Alive_Dump_BN.bin Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:2217 mV Input file : C:\Users\admin\Downloads\Compressed\RR\N7100_Rom1_ Alive_Dump_BN.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 7768 kB/s Checking NAND Image : C:\Users\admin\Downloads\Compressed\RR\EMMC_000000 00_00200000.bin File successefuly loaded! Processing file...C:\Users\admin\Downloads\Compressed\RR\EMMC _00000000_00200000.bin Z3X EasyJtag Software ver. 2.5.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:2217 mV Input file : C:\Users\admin\Downloads\Compressed\RR\EMMC_000000 00_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1222 kB/s |
The Following 8 Users Say Thank You to vickyjadhav6161 For This Useful Post: |
