04-15-2017, 17:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | n9005 emmc ported to n900 , now baseband Unknown wrote rom 1 and rom2 and extcsd at write all emmc regions at once what could went wrong wrote efs but same Code: Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0A00402049186C15, ,FW Ver.: 01.58 CMD Pullup Level:464 mV CMD Active Level:2279 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004D4247384642F63118AF13BF96 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 11/2012 Rev.0xF6 EMMC NAME: MBG8FB , S/N: 823701267 EMMC NAME (HEX): 4D424738464200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MBG8FB_ 823701267_20170415_2054.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:464 mV CMD Active Level:2279 mV Box IO Level:2800 mV CLK Rate:14000 khz EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:464 mV CMD Active Level:2279 mV Box IO Level:2800 mV CLK Rate:14000 khz Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Checking NAND Image : E:\n900 dump\SM-N900_Alive_Rom1_BN.bin Autodetected RAW data File successefuly loaded! Found ROM2 and automatically selected. Found EXT CSD and automatically selected. Processing file...E:\n900 dump\V2W00M_3121767857_20140106_1343.extcsd Processing file...E:\n900 dump\SM-N900_Alive_Rom1_BN.bin Processing file...E:\n900 dump\SM-N900_Alive_Rom2_BN.bin ROM3 Are not selected , skip writing ROM3 Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:464 mV CMD Active Level:2279 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:464 mV CMD Active Level:2279 mV Length limit is enabled! Input file : E:\n900 dump\SM-N900_Alive_Rom1_BN.bin Writing 0008000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 2444 kB/s Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:464 mV CMD Active Level:2279 mV Input file : E:\n900 dump\SM-N900_Alive_Rom2_BN.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1364 kB/s |
The Following User Says Thank You to shahjee For This Useful Post: |
