Old 08-05-2020, 14:31   #1 (permalink)
Member: 2434148
Thanks Meter: 18
need help for a50 read dump
hi
any help pls i want to read a50 dump but i get this error at reading
Setting interface to EasyJtag2/UFS
Socket Information :
Socket Mark: EasyJTAG UFS Socket 3 in 1 by MOORC 17.06.20
Socket Serial: 01236034040B5FF5EE
UFS Power Information :
Mode: High, VCC: 3306mV, VCCQ2: 1910mV
UFS Device Information :
UFS Manufacturer: SAMSUNG, UFS ProductName: KLUDG4U1EA-B0C1
UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x3121BB71113F7ECEDE448EEEC0815338485852415039
Maximum Number of LUs: 8, Number of LUs found: 5, Number of WLUs found: 1, LUs Re-configure: Disabled
UFS LUN 0 Capacity: 122016 MB (001DCA000000)
UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000)
UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000)
UFS LUN 3 Capacity: 8 MB (000000800000)
UFS LUN 4 Capacity: 8 MB (000000800000)
UFS W-LUN 0xC4 (REPORT LUNS) Capacity: 16 MB (000001000000)
UFS Init completed.
Scanning soft partitions
UFS LUN 0
Error reading at address: 000000000000 , error: -403, Card does not support partitioning ... Retry #1
Error reading at address: 000000000000 , error: -403, Card does not support partitioning ... Retry #2
Error reading at address: 000000000000 , error: -403, Card does not support partitioning ... Retry #3
Stopped by User request...
Old 08-05-2020, 14:42   #2 (permalink)
Member: 2434148
Thanks Meter: 18
and with easy jtag classic
EasyJtag Suite Classic ver.: 3.7.0.17 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 10 (build 19041), 64-bit edition. Admin rights FAIL
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AAA6-9472 , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 2 serial devices
COM35 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM35)
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.17
UFS Socket Info.
Description: EasyJTAG UFS Socket 3 in 1 by MOORC 17.06.20
Identify UFS Chip.
UFS Chip Voltage: Low
VCC: 3306mV
VCCQ2: 1910mV
Chip Info:
Firmware Version: 0.02
UFS Version: 2.1
LUN 0:
Block size: 0x1000
Size: 0x1DCA000000 / 119,160,000,000B / 119GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x400000 / 0,004,000,000B / 4MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0x800000 / 0,008,000,000B / 8MB
LUN 4:
Block size: 0x1000
Number of W-LUs found: 1
W-LUN 0xC4 (REPORT LUNS):
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
Full size: 0x1DCC800000 / 119,200,000,000B / 119GB
Health:
Device life time method A: 0x01 (0%-10% device life time used)
Device life time method B: 0x01 (0%-10% device life time used)
Pre End of Life: 0x01 (Used less then 80% of reserved blocks)
Chip config is OTP
Checking LU0 for partitioning
LUN0 Have 32 partitions
LUN1 Have no partitions
LUN2 Have no partitions
LUN3 Have 1 partitions
LUN4 Have no partitions
------ Detected 33 partitions ------
LUN0 (BOTA0) [0x400000 0x480000] Size: 4.500MB
LUN0 (BOTA1) [0x880000 0x780000] Size: 7.500MB
LUN0 (EFS) [0x1000000 0x1400000] Size: 20.0MB
LUN0 (PARAM) [0x2400000 0x800000] Size: 8.0MB
LUN0 (UP_PARAM) [0x2c00000 0x800000] Size: 8.0MB
LUN0 (KEYSTORAGE) [0x3400000 0x80000] Size: 512.0KB
LUN0 (SEC_EFS) [0x3480000 0x1400000] Size: 20.0MB
LUN0 (BOTA2) [0x4880000 0x800000] Size: 8.0MB
LUN0 (STEADY) [0x5080000 0x400000] Size: 4.0MB
LUN0 (UH) [0x5480000 0x200000] Size: 2.0MB
LUN0 (UHCFG) [0x5680000 0x400000] Size: 4.0MB
LUN0 (DTB) [0x5a80000 0x800000] Size: 8.0MB
LUN0 (DTBO) [0x6280000 0x800000] Size: 8.0MB
LUN0 (BOOT) [0x6a80000 0x3700000] Size: 55.0MB
LUN0 (RECOVERY) [0xa180000 0x4080000] Size: 64.500MB
LUN0 (RADIO) [0xe200000 0x3200000] Size: 50.0MB
LUN0 (NAD_REFER) [0x11400000 0x100000] Size: 1.0MB
LUN0 (PERSISTENT) [0x11500000 0x80000] Size: 512.0KB
LUN0 (MISC) [0x11580000 0x100000] Size: 1.0MB
LUN0 (KEYREFUGE) [0x11680000 0x1000000] Size: 16.0MB
LUN0 (KEYDATA) [0x12680000 0x1000000] Size: 16.0MB
LUN0 (DQMDBG) [0x13680000 0x1000000] Size: 16.0MB
LUN0 (VBMETA) [0x14680000 0x10000] Size: 64.0KB
LUN0 (BOTA3) [0x14690000 0x170000] Size: 1.437MB
LUN0 (SYSTEM) [0x14800000 0x14b400000] Size: 5.175GB
LUN0 (VENDOR) [0x15fc00000 0x32000000] Size: 800.0MB
LUN0 (PRODUCT) [0x191c00000 0x19000000] Size: 400.0MB
LUN0 (CACHE) [0x1aac00000 0x19000000] Size: 400.0MB
LUN0 (OMR) [0x1c3c00000 0x3200000] Size: 50.0MB
LUN0 (CP_DEBUG) [0x1c6e00000 0x500000] Size: 5.0MB
LUN0 (NAD_FW) [0x1c7300000 0x1400000] Size: 20.0MB
LUN0 (USERDATA) [0x1c8700000 0x1c01400000] Size: 112.19GB
LUN3 (CPEFS) [0x6000 0x600000] Size: 6.0MB
Read SYSTEM from LUN0.
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0014800000 (5.175GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 333904
Short Android info:
Unable to read prop.plist , code : 2
Read USERDATA from LUN0.
Detected USERDATA USERDATA : 0x01C8700000 (112.19GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 90B5AD06 20AC3D0D 91860D0E 40170000 304CC406 10AE3D0D 14CF5101 .....µ*. ¬=.‘†[email protected]Ä..®=..ÏQ.;
25000000 40DD0677 78FAC506 A9CC0877 304CC406 00000C06 00100000 14AC3D0D %...@Ý.wxúÅ.©Ì.w0LÄ..........¬=.;
00000000 5B721DA4 78FAC506 50E75101 00000000 600E130E 00000000 38B03D0D ....[r.¤xúÅ.PçQ.....`.......8°=.;
40170000 304CC406 30AD3D0D 14CF5101 25000000 40DD0677 78FAC506 A9CC0877 @...0LÄ.0*=..ÏQ.%...@Ý.wxúÅ.©Ì.w;
304CC406 40DD0677 00000000 A9CC0877 00000000 8B751DA4 78FAC506 50E75101 0LÄ.@Ý.w....©Ì.w....‹u.¤xúÅ.PçQ.;
00000000 FB751DA4 00000000 E8E65101 00000000 00000000 78FAC506 A4510B77 ....ûu.¤....èæQ.........xúÅ.¤Q.w;
30A26806 01000000 B0AC3D0D 18B13D0D 40170000 304CC406 A0AD3D0D 14CF5101 0¢h.....°¬=..±[email protected]Ä.**=..ÏQ.;
25000000 40DD0677 78FAC506 A9CC0877 304CC406 40DD0677 00000000 A9CC0877 %...@Ý.wxúÅ.©Ì.w0LÄ.@Ý.w....©Ì.w;
Done.
UFS Socket Info.
Identify UFS Chip.
VCC: 3294mV
VCCQ2: 1910mV
Chip Info:
UFS Version: 2.1
LUN 0:
Block size: 0x1000
LUN 1 (Boot A):
Block size: 0x1000
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
LUN 4:
Block size: 0x1000
Block size: 0x100
Health:
Chip config is OTP
Read UFS LUN0, Address: 0x0 ,Length: 0x1DCA000000
Output file :\ROM\UFS\SAMSUNG\A50\A505FDDU2ASE6\UFS_KLUDG4U1 EA-B0C1_0_00000000_1DCA000000.bin
Start
Can't read address 0x0, Code: -403, Reason: UAP SCSI: Command sense: MEDIUM_ERROR
Done.
Old 09-04-2020, 02:45   #3 (permalink)
Member: 525940
Thanks Meter: 213
can you share pinout on a505gn?
Page generated in 0.16464 seconds with 8 queries
