Member: 527534
Sonork: 100.1606510 Thanks Meter: 193 | Nokia 3.4 connection failed without reason.. Around week I was trying to connect and format Nokia 3.4 with easy jtag. But still I cant do it and i cant find a reason.
With same emmc connector I done Nokia 1.4 at once. But 3.4 always failed now. It was connected twice first connect after solder. Next time I mean after few second without change anything ( without move phone, box, emmc connector.. etc ) its not detected.
I soldered few times. Use another emmc connector. Check with another short copper wires... But I couldn't find a reason.
If anyone have same experience with Nokia 3.4 or with another phone please share with me your solutions and experiences with me. Quote:
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 06FF701A42DD814B, ,FW Ver.: 01.63
CMD Pullup Level:1887 mV
CMD Active Level:2815 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:1876 mV
CMD Active Level:2805 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:2031 mV
CMD Active Level:1557 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:2021 mV
CMD Active Level:1567 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:1701 mV
CMD Active Level:2588 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:2000 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:1660 mV
CMD Active Level:2598 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:1845 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Active Level:1588 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:2124 mV
CMD Active Level:3073 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 15010047503642414205BCB5FE4D184A
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 01/2005 Rev.0x5
eMMC NAME: GP6BAB , S/N: 3166043725
eMMC NAME (HEX): 475036424142
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 55045 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GP6BAB_3166043725_20220802_1320.extcsd
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SUPER : 0x000FCAC000 (2.398GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x00C0000000 (55.241GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done. | |
