03-03-2020, 16:07 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Oppo A3s [CPH1803][EDL MODE][DEAD RECOVERED][DONE] by Easy JTAG_H.R Palash Please don't remove CLK / CMD Resistance, Before remove components, Just do you complete the procedure are below. Step 1:- Unfortunately when you got your Phone ''EDL'' Mode Problem. (A) What can you do ? 1) Connect the I.S.P carefully accurate flow by the Pin out. 2) Immediately create your security area / partitions backup read by vendor. (B) How to backup security area / partitions. Read by vendor ? Answer:- Run ''EasyJTAG Plus'' set voltage manually which voltage sweet-able for your eMMC detected also set the frequency 1 mhz + Bus 1 bit. Go to Read soft partitions then Check ''eMMC / UFS'' if you get all partitions is okay only your phone dose not run or EDL mode detected by 'PC" device manager. No problem ! don't be upset ! Go to Read by vendor operation ''TAB" there are already all partitions are visible. (C) Pay attention, You have need to be create Below the partitions backup very carefully. *) config *) fsg *) sec *) modem *) modemst1 *) modemst2 *) oppodycnvbk *) opporeserve2 *) oppostanvbk *) Persist Unfortunately if your phone already has been full erase by mistake so you can restore only your B.B below the data write by vendor throw the Partitions. OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_oppodycnvbk + oppostanvbk + modemst1 + modemst2 + fsg + sec + modem.7z Very important instruction, when you write the security area for restore your B.B must UN-trick reparation option as per below the image. (D) Go to eMMC General / Image ''TAB'' select Dump_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB_06_03_2020_16_08_12.bin Mega Mirror ## Dump_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB Code: 3/11/2020 1:17:49 AM> Operation: Writing eMMC... 3/11/2020 1:17:49 AM> 3/11/2020 1:17:49 AM> Writing to: ROM1 , start: 0x000000000000 , size: 0x00000FA00000 3/11/2020 1:17:50 AM> Input file: C:\Users\Dream\Downloads\OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_ QE63MB_06_03_2020_16_08_12.bin 3/11/2020 1:17:50 AM> eMMC switching to ROM1 3/11/2020 1:17:50 AM> Writing partition... 3/11/2020 1:27:06 AM> Done writing partition. Write speed: 460.08 KB/s 3/11/2020 1:27:06 AM> 3/11/2020 1:27:06 AM> All done time: [00:09:16:631] Code: 3/11/2020 1:27:47 AM> Scanning soft partitions 3/11/2020 1:27:47 AM> GPT header is found and is valid 3/11/2020 1:27:47 AM> Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) 3/11/2020 1:27:47 AM> Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) 3/11/2020 1:27:47 AM> Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) 3/11/2020 1:27:47 AM> Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) 3/11/2020 1:27:47 AM> Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) 3/11/2020 1:27:47 AM> Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) 3/11/2020 1:27:47 AM> Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) 3/11/2020 1:27:47 AM> Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB) 3/11/2020 1:27:47 AM> Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB) 3/11/2020 1:27:47 AM> Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB) 3/11/2020 1:27:47 AM> Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB) 3/11/2020 1:27:47 AM> Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB) 3/11/2020 1:27:47 AM> Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB) 3/11/2020 1:27:47 AM> Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB) 3/11/2020 1:27:47 AM> Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB) 3/11/2020 1:27:47 AM> Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB) 3/11/2020 1:27:47 AM> Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB) 3/11/2020 1:27:47 AM> Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB) 3/11/2020 1:27:47 AM> Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB) 3/11/2020 1:27:47 AM> Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB) 3/11/2020 1:27:47 AM> Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB) 3/11/2020 1:27:47 AM> Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB) 3/11/2020 1:27:47 AM> Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB) 3/11/2020 1:27:47 AM> Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB) 3/11/2020 1:27:47 AM> Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB) 3/11/2020 1:27:47 AM> Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB) 3/11/2020 1:27:47 AM> Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB) 3/11/2020 1:27:47 AM> Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB) 3/11/2020 1:27:47 AM> Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB) 3/11/2020 1:27:47 AM> Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB) 3/11/2020 1:27:47 AM> Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB) 3/11/2020 1:27:47 AM> Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB) 3/11/2020 1:27:47 AM> Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB) 3/11/2020 1:27:47 AM> Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB) 3/11/2020 1:27:47 AM> Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB) 3/11/2020 1:27:47 AM> Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB) 3/11/2020 1:27:47 AM> Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB) 3/11/2020 1:27:47 AM> Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB) 3/11/2020 1:27:47 AM> Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB) 3/11/2020 1:27:47 AM> Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB) 3/11/2020 1:27:47 AM> Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB) 3/11/2020 1:27:47 AM> Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB) 3/11/2020 1:27:47 AM> Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB) 3/11/2020 1:27:47 AM> Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB) 3/11/2020 1:27:47 AM> Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB) 3/11/2020 1:27:47 AM> Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB) 3/11/2020 1:27:47 AM> Partition: userdata, [000158000000 - 0003A3DFBE00], size: 00024BDFBE00 (9.19 GB) 3/11/2020 1:27:47 AM> GPT header successfully parsed (E) Now You need to flash this version of firmware, CPH1803EX_11_A.17_190323_102b469c Go To Unpack OFP File........ (F) Go To Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Code: Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003A3DFBE00 GPT-partitioning done Partition name: oppodycnvbk Filename: dynamic_nvbk.bin , Offset: 000000005000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 958.73 KB/s Partition name: oppostanvbk Filename: static_nvbk.bin , Offset: 000000A05000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1045.91 KB/s Partition name: persist Filename: persist.img , Offset: 000001705000 , filesize: 5132700 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 32 Done writing partition. Write speed: 999.65 KB/s Partition name: opporeserve1 Filename: emmc_fw.bin , Offset: 000003705000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1020.78 KB/s Partition name: opporeserve2 Filename: opporeserve2.img , Offset: 000003F05000 , filesize: 5300372 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 1029.77 KB/s Partition name: sbl1 Filename: sbl1.mbn , Offset: 000008308000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 786.53 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000008388000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 906.38 KB/s Partition name: tz Filename: tz.mbn , Offset: 000008408000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1033.56 KB/s Partition name: devcfg Filename: devcfg.mbn , Offset: 000008608000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 647.89 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000008648000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1009.25 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 0000086C8000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 916.57 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 000008748000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1034.03 KB/s Partition name: devcfgbak Filename: devcfg.mbn , Offset: 000008948000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 704.44 KB/s Partition name: dsp Filename: adspso.bin , Offset: 000008988000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1030.94 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 00000A18C000 , filesize: 738876 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1008.16 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 00000A28C000 , filesize: 738876 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1030.65 KB/s Partition name: modem Filename: NON-HLOS.bin , Offset: 00000A38C000 , filesize: 134217728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1043.81 KB/s Partition name: dtbo Filename: dtbo.img , Offset: 00001238C000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1036.50 KB/s Partition name: vbmeta Filename: vbmeta.img , Offset: 000012B8C000 , filesize: 4096 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 540.85 KB/s Partition name: boot Filename: boot.img , Offset: 000012B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1041.21 KB/s Partition name: recovery Filename: recovery.img , Offset: 000016B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1045.91 KB/s Partition name: LOGO Filename: logo.bin , Offset: 00001BB00000 , filesize: 878080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 969.18 KB/s Partition name: DRIVER Filename: DRIVER.ISO , Offset: 00001DB00000 , filesize: 23795712 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1053.62 KB/s Partition name: cache Filename: cache.img , Offset: 00001FB00000 , filesize: 6398160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1011.17 KB/s Partition name: mdtp Filename: mdtp.img , Offset: 000030980000 , filesize: 17808306 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1033.31 KB/s Partition name: lksecapp Filename: lksecapp.mbn , Offset: 000033000000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 324.95 KB/s Partition name: cmnlib Filename: cmnlib_30.mbn , Offset: 000033020000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 835.81 KB/s Partition name: cmnlib64 Filename: cmnlib64_30.mbn , Offset: 000033120000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 862.58 KB/s Partition name: keymaster Filename: keymaster64.mbn , Offset: 000033220000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 869.37 KB/s Partition name: lksecappbak Filename: lksecapp.mbn , Offset: 000033320000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 921.66 KB/s Partition name: cmnlibbak Filename: cmnlib_30.mbn , Offset: 000033340000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 964.23 KB/s Partition name: cmnlib64bak Filename: cmnlib64_30.mbn , Offset: 000033440000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 934.60 KB/s Partition name: keymasterbak Filename: keymaster64.mbn , Offset: 000033540000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 917.39 KB/s Partition name: apdp Filename: dpAP.mbn , Offset: 000033800000 , filesize: 13248 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 104.98 KB/s Partition name: system Filename: system.img , Offset: 00003F000000 , filesize: 3208174868 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4714 Done writing partition. Write speed: 1021.47 KB/s Partition name: vendor Filename: vendor.img , Offset: 000115900000 , filesize: 978552928 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2907 Done writing partition. Write speed: 1022.84 KB/s Partition name: userdata Filename: userdata.img , Offset: 000158000000 , filesize: 3422620248 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 901 Done writing partition. Write speed: 1041.68 KB/s Operation: Writing BootConfig ... Reg: 179 Value: 0x08 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [02:21:48:720] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 9 MHz CMD Pullup Level: 2106 mV CMD Active Level: 2749 mV EMMC Device Information : EMMC CID: 150100514536334D4203ADCF07F035FB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: ADCF07F0 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 69475 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_ADCF07F0_20200312_001643.extcsd EMMC Init completed. Code: GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB) Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB) Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB) Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB) Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB) Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB) Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB) Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB) Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB) Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB) Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB) Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB) Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB) Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB) Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB) Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB) Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB) Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB) Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB) Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB) Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB) Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB) Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB) Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB) Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB) Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB) Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB) Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB) Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB) Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB) Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB) Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB) Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB) Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB) Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB) Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB) Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB) Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB) Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB) Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB) Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB) Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB) Partition: userdata, [000158000000 - 0003A3DFBE00], size: 00024BDFBE00 (9.19 GB) GPT header successfully parsed Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Brand = OPPO Device = CPH1803 Model = CPH1803 Firmware version = CPH1803EX_11_A.17 Firmware date = Sat Mar 23 21:42:03 CST 2019 Step 1 Has been Successfully Completed ================================================== ======================= ================================================== ======================= Step 2 :- (E) Unfortunately if You cannot successfully revive your phone. if you have already backup your security area / partitions data. (F) Go to eMMC General / Erase eMMC Wait until Finis....... (G) Just you complete the Step (1) section (D) all job complete. (H) Go to eMMC config / Boot_Partition_EN 0x7 : User area enabled for boot / set partitions config 0x38 (H) Do you complete from the (Step 1) section (C) backup data write by vendor. Hopefully your problem willbe solved. Full_Dump_With User Area_OPPO A3S CPH1803EX_11_A.17_Samsung eMMC _06_03_2020_16_08_12_QE63MB_fsg_part Oppo A3s Repair Tools & QCN Only For JTAG expert users if you want you can flash the User area full Dump throw partitions by partitions. The greatest mind contributing to all the Dump File all the credit goes to him solusi hp Really This job was my long-range work. Best regard for all of Oppo Technician
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 12-30-2023 at 13:29. Reason: Info Updated |
The Following 63 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-04-2020, 09:06 | #3 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | NICE SHER BRO, BUT CONFUSED..... JTAG PLUS NOT ACTIVATED, EasyJtag Suite Classic ver.: 3.6.2.0 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7600). Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA27-78BA , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED JTAG PLUS WORKED eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 1717020DE19BFA4A Card Serial = AA2778BA EasyJTAG Box Firmware = 1.63 GOOD SIR |
03-04-2020, 09:23 | #4 (permalink) |
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | No need JTAG Plus for this category of hard work. Just you need perseverance [03+ Hour] time: [03:17:30:071] my PC Config is Core i5 with 4GB RAM. Amazing thing it's Fast Easy JTAG Z3X team 1'st Generation JTAG when it was released by GPG hardware. But it's reality z3x team is perfectly, acculturating, combined for old & new hardware coding . http://easy-jtag.com/easyjtag-in-plastic-case/
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 6 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-04-2020, 09:24 | #5 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
little slow to writing speed. | |
The Following 4 Users Say Thank You to kothamamun For This Useful Post: |
04-03-2020, 10:27 | #6 (permalink) |
Junior Member Join Date: Jun 2011 Location: India
Member: 1596349 Status: Offline Sonork: [email protected] Thanks Meter: 7 | Great bro....Thanks |
04-09-2020, 19:52 | #8 (permalink) |
Junior Member Join Date: May 2016
Member: 2569919 Status: Offline Thanks Meter: 1 | oppo a57 hi could you please help me on how i can flash oppo a57 dead and how to remove password on screen of oppo A1K. thak you |
The Following User Says Thank You to otiblo For This Useful Post: |
04-09-2020, 20:19 | #9 (permalink) |
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | @ otiblo You can get idea about A57 flashing via Easy Jtag http://forum.gsmhosting.com/vbb/13505969-post10.html also flow my 1'st post, Above the same way. Download your phone correct model factory firmware, then extract with Easy jtag then you can flash via ISP connection. Your another phone A1K is MTK Based phone.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
05-31-2020, 01:30 | #11 (permalink) |
Crazy Poster Join Date: Oct 2018 Location: algera
Member: 2871948 Status: Offline Thanks Meter: 3 | thank you for this useful post is the procedure same with Oppo a7 dead after password reset? |
The Following User Says Thank You to talebamine8 For This Useful Post: |
05-31-2020, 12:21 | #12 (permalink) |
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | @ khaleddz19 & talebamine8 Both of you need tested dump file for theses of model phones. before any operation must created security area back by your self. Also you can flow my procedure, try with your correct model Dump & firmware. Best of luck
06-09-2020, 18:27 | #13 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | for mtk you need also backup NVRAM and "protect _xxx" partition (B) How to backup security area / partitions. Read by vendor ? Answer:- Run ''EasyJTAG Plus'' set voltage manually which voltage sweet-able for your eMMC detected also set the frequency 1 mhz + Bus 1 bit. Go to Read soft partitions then Check ''eMMC / UFS'' if you get all partitions is okay only your phone dose not run or EDL mode detected by 'PC" device manager. No problem ! don't be upset ! Go to Read by vendor operation ''TAB" there are already all partitions are visible. (C) Pay attention, You have need to be create Below the partitions backup very carefully. *) config *) fsg *) sec *) modem *) modemst1 *) modemst2 *) oppodycnvbk *) opporeserve2 *) oppostanvbk *) Persist |
06-10-2020, 17:08 | #14 (permalink) |
Junior Member Join Date: Jul 2017 Location: home
Member: 2735217 Status: Offline Thanks Meter: 4 | This is a really good and informative solution, thank you for helping other make their job well done... |
The Following User Says Thank You to mhayketech For This Useful Post: |
06-10-2020, 17:47 | #15 (permalink) |
Banned Join Date: Jan 2007 Location: morroco rabat massira n67 sect Age: 51
Member: 443140 Status: Offline Thanks Meter: 45 | Hello Mr any help for slove this problm im step by step if you possible THANKS MAN HiPower mode is ON Setting frequence to 14 MHz CMD Pullup Level: 2010 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A484147346132A5C3375C748594 EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: C3375C74 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1237 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_C3375C74_20200610_163554.extcsd EMMC Init completed. Get firmware version Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #4 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #5 Too many errors. Reading has been stopped .................................................. .................................................. ........................ ERASER EMMC HiPower mode is ON Setting frequence to 14 MHz CMD Pullup Level: 2000 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A484147346132A5C3375C748594 EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: C3375C74 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1237 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_C3375C74_20200610_165209.extcsd EMMC Init completed. Operation: Erasing eMMC... Erasing for: ROM1 , start: 0x000000000000 , size: 0x000000020000 eMMC switching to ROM1 Erasing partition... Error erasing at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 Error erasing at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Erasing has been stopped Last edited by GSMSHOP1; 06-10-2020 at 17:53. |
