07-24-2020, 15:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Oppo A3S CPH1803 Format done successfully Problem : User Lock Solution : Do "Reset Oppo" Operation by Easy Jtag Classic suit Procedure: 1. Connect Device to Easy Jtag box via ISP pinout & Open Easy Jtag Classic Suit 2. Selelect Model Number and Check connection by "Detect" button 3. Do "Reset Oppo" Under EMMC/Advanced Tab 4. Done CPH1803 ISP Pinout: Check Connection: Check device via ISP pinout Log: Code: ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42068614A86AB560 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2249500778 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 99550 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2249500778_20200724_1739.extcsd Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFDA sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30535661 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2018-11-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys Backup saved: BuildProp_20200724_1739.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 3ED9A050 2CFAE7EE D20D8E93 9FB11313 C63FFFFA 1A4C0B75 5ED7FD16 04F27D63 >Ù*P,úçîÒ.Ž“Ÿ±..Æ?ÿú.L.u^×ý..ò}c; B6A12EAC 4F833230 E7FA9297 FFBB3BC1 186C8BD8 009FC962 6B4E895D A23E843D ¶¡.¬Oƒ20çú’—ÿ»;Á.l‹Ø.ŸÉbkN‰]¢>„=; 97A58D7D 027823F6 AD213E32 D7FE486A 3B5DAFC7 87ABF467 6BB4AC2F F47A4B52 —¥.}.x#ö*!>2×þHj;]¯Ç‡«ôgk´¬/ôzKR; 3FDA70EF A3ABC303 D91206AC 98481703 864987A6 B5E0BA6E F81894AD C5B635F3 ?ÚpÃ.Ù..¬.H..†I‡¦µàºnø.”*Ŷ5ó; 18472874 C409D267 53A88F04 4947FD42 DF84541D A4BB81FA 0D4B9130 0FD8D2DC .G(tÄ ÒgS¨..IGýBß„T.¤».ú.K‘0.ØÒÜ; A9D882FB CE84F9D5 8EC58B54 1F945B1C 25249D36 27564F6A 9567100A AFF933B1 ©Ø‚û΄ùÕŽÅ‹T.”[.%$.6'VOj•g..¯ù3±; 22DC1893 2DA4F840 A41D4730 B55F3002 40913F04 4C20E237 AAB7C920 3CE97EB3 "Ü.“-¤ø@¤.G0µ_0.@‘?.L â7ª·É <é~³; AA92F7C0 770C24EA FC53A1A0 1031E586 F718ACAA E09E77DB C18C271A 00E42FCB ª’÷Àw.$êüS¡*.1å†÷.¬ªàžwÛÁŒ'..ä/Ë; Done. Oppo Reset : Reset Oppo Log: Code: Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0505051AFBFD078F, ,FW Ver.: 01.63 CMD Pullup Level:1959 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42068614A86AB560 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2249500778 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 99550 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
The Following 6 Users Say Thank You to technomak For This Useful Post: |
