06-20-2019, 10:34 | #107 (permalink) |
No Life Poster Join Date: Jun 2014 Location: SULTANPUR UP INDIA Age: 28
Member: 2205247 Status: Offline Sonork: 100.1668179 Thanks Meter: 821 | I have 2 phones oppo A3s Hang On Logo......... I have 2 phones oppo A3s Hang On Logo After wipe user data with jtag I try Hard reset in recovery manny time but problem not solve plz give any solution jtag team........... |
06-21-2019, 06:01 | #109 (permalink) |
Freak Poster Join Date: Sep 2015 Location: Bondowoso-Indonesia
Member: 2464063 Status: Offline Thanks Meter: 73 | - Oppo A3s Remove User Lock and Google Account via direct eMMc - Hopefully this can help OPPO A3s Hang Logo https://www.youtube.com/watch?v=FiGmsqgfKkA |
06-22-2019, 06:08 | #110 (permalink) |
Member: 2464063 Status: Offline Thanks Meter: 73 | I hope this video can help the problem of the Oppo A3S Logo hang : https://www.youtube.com/watch?v=FiGmsqgfKkA |
The Following 2 Users Say Thank You to Bond.Flasher For This Useful Post: |
06-23-2019, 20:14 | #111 (permalink) | |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Quote:
If u hve plz share | |
06-27-2019, 11:40 | #114 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
Checking security ... Z3X EasyJtag Software ver. 3.6.0.0 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: DE661578BC5CC95E, ,FW Ver.: 02.42 CMD Pullup Level:2117 mV CMD Active Level:3194 mV Box IO Level:3300 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203DE4DD8316537 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 3729643569 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 48511 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 913030951011876864 Block size: 913030951011876865 Blocks per group: 0 Inodes per group: 37 Inode size: 0 Inodes: 4294967295 Label: Unable to format encrypted FS , try to Wipe it Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 913030951011876864 Block size: 913030951011876865 Blocks per group: 0 Inodes per group: 37 Inode size: 0 Inodes: 4294967295 Label: Unable to format encrypted FS , try to Wipe it --------------------------------------------- Done. | |
06-28-2019, 09:33 | #115 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | Oppo A3s boss when user deta Unable to format encrypted FS , try to Wipe 1 first extract ofp file 2 go to write by vender 3 select qualcom xml & write only user deta file 4 after write go to easy jtag classic setup & wipe user deta mobile 100% ok i solve many phones A3s cph1853 & cph1803 1000000% ok method tested |
The Following 5 Users Say Thank You to akash48 For This Useful Post: |
06-29-2019, 11:53 | #117 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | here's userdata in xml format: https://drive.google.com/file/d/1ThM...Rg68J9ho9/view make sure to UNTICK repartition and erase before writing |
06-30-2019, 09:13 | #119 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | OPPO A3s F.R.p & Pin Lock Remove Done ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys Pin Code Code: Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:1969 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420682F406527524 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2197030482 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 9352 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. F.R.p Code: Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:1980 mV CMD Active Level:2629 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420682F406527524 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2197030482 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 9352 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting... Done. Done. Done. |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
