06-14-2019, 05:07 | #91 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 575576 Status: Offline Thanks Meter: 25 | Read EXT fs info Blocks Reading Error (0x15B800400 , 2 , Reason: CMD Timeout Error ) Read EXT fs info Created filesystem with parameters: Size: 1108347307729878368 Block size: 1108347309489929940 Blocks per group: 7 Inodes per group: 0 Inode size: 0 Inodes: 0 Label: (null) Unable to format encrypted FS , try to Wipe it --------------------------------------------- Done. even i try to wipe...still hang in logo.. |
06-16-2019, 16:11 | #97 (permalink) |
No Life Poster Join Date: Jun 2014 Location: SULTANPUR UP INDIA Age: 28
Member: 2205247 Status: Offline Sonork: 100.1668179 Thanks Meter: 821 | oppo a3s hang on logo after wipe userdata................ oppo a3s hang on logo after wipe userdata................ |
06-17-2019, 12:35 | #99 (permalink) |
Member: 2205247 Status: Offline Sonork: 100.1668179 Thanks Meter: 821 | hard reset done manny time but set hang on logo............ hard reset done manny time but set hang on logo............ |
06-17-2019, 18:09 | #101 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2288140 Status: Offline Thanks Meter: 46 | doing wrong step done 50 plus set with eeasy jtag no problem.show info in easy jtag plus see gpt damage aur anything else so i can help you |
The Following User Says Thank You to gsm50238301 For This Useful Post: |
06-18-2019, 16:55 | #104 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | i do only a3s and set hang in logo after hard reset set ok but ufi box set ok no almost norisk |
The Following User Says Thank You to umar342 For This Useful Post: |
06-18-2019, 19:42 | #105 (permalink) | |
No Life Poster Join Date: May 2009 Location: Bangladesh Age: 30
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | Quote:
try but not worked Code: eMMC_tool Suite ver. 1.5.3.0 (release date: 28.12.2018) Microsoft Windows XP (32 bit) build 2600 (5.1.2600.5512) Looking for EasyJTAG box... EasyJTAG API ver. 2201 EasyJTAG Box Serial = 0EFF901ADE07A5AB Card Serial = AA43C247 EasyJTAG Box Firmware = 1.63 Changelog: 28.12.2018 (ver 1.5.3.0) Fix: Bugs that have been found through your crash report Fix: Scatter file processing (MTK) Fix: Contact Extractor Fix: Preloader parser Fix: FAT partitions mounting Fix: Minor interface changes Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP) Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks) Add: Auto/Manual loaders select for Qualcom HS-USB QDLoader 9008 interface Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung) Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm) Add: Unpack Bootloader.img archive from Motorola firmware files Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions) Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions) Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC) Add: Explorer: Pin and Password decoding (only English and Russian letters) Setting frequence to 21 Mhz CMD Pullup Level: 2650 mV CMD Active Level: 2732 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 2650 mV CMD Active Level: 2732 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 2650 mV CMD Active Level: 2732 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 278 mV CMD Active Level: 1815 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 2031 mV CMD Active Level: 2578 mV EMMC Device Information : EMMC CID: 90014A484147346132A5457B6651453A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 457B6651 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_457B6651_20190618_231611.extcsd EMMC Init completed. Opening file: rawprogram0.xml Large file size: C:\Documents and Settings\Shaon\My Documents\Downloads\Compressed\CPH1803EX_11_A.03_180720_88dff542_QFIL\CPH1803EX_11_A.03_180720_88dff542_QFIL\userdata.img The size of the last section has been updated Setting frequence to 21 Mhz CMD Pullup Level: 2031 mV CMD Active Level: 2650 mV EMMC Device Information : EMMC CID: 90014A484147346132A5457B6651453A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 457B6651 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_457B6651_20190618_231748.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: cache Filename: cache.img , Offset: 00001FB00000 , filesize: 6398160 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 540.86 KB/s Partition name: userdata Filename: userdata.img , Offset: 000158000000 , filesize: 3126204116 bytes eMMC switching to ROM1 Writing partition... Error writing at address: 00020AE80000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00020B240000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00020B480000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00020B480000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 Done writing partition. Write speed: 646.61 KB/s All done time: [01:18:53:627] | |
The Following 2 Users Say Thank You to shaongsm For This Useful Post: |
