07-03-2019, 11:20 | #16 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | ))) remove resistor and make jumper..... remove USB block charger from AC power and make jumper ..... Do you understand what you doing? |
The Following User Says Thank You to layder For This Useful Post: |
07-03-2019, 22:54 | #18 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 591084 Status: Offline Thanks Meter: 41 | oppo a3s error identify Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0D01300C9DDE17D1, ,FW Ver.: 01.63 CMD Pullup Level:2093 mV CMD Active Level:2557 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E03169A992975FE eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2018 Rev.0x3 eMMC NAME: hB8aP> , S/N: 379230505 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hB8aP>_ 379230505_20190703_2351.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to mount USERDATA , code : 95 Done. what is that error RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error |
07-04-2019, 05:01 | #19 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | disconnect the jtag connections and turn on the phone wait till it starts then turn it off and start over again the jtag process . I it must be user data partitions not initialized properly due to abnormal shut downs. |
The Following User Says Thank You to gayansuranga For This Useful Post: |
07-05-2019, 11:56 | #20 (permalink) |
No Life Poster Join Date: Oct 2010 Location: phone repairing
Member: 1409573 Status: Offline Sonork: 100.1615416 Thanks Meter: 84 | oppo a3s not conect oppo a3s not conect MMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) 7/5/2019 12:56:52 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) 7/5/2019 12:56:52 PM> 7/5/2019 12:56:52 PM> Looking for EasyJTAG box... 7/5/2019 12:56:52 PM> EasyJTAG API ver. 3307 7/5/2019 12:56:55 PM> OpenUSB returned = 0 7/5/2019 12:56:56 PM> EasyJTAG Box Serial = 07FFA00BB62EEC02 7/5/2019 12:56:57 PM> Card Serial = AA3D83FD 7/5/2019 12:56:57 PM> EasyJTAG Box Firmware = 1.63 7/5/2019 12:56:57 PM> 7/5/2019 12:57:15 PM> Looking for EasyJTAG box... 7/5/2019 12:57:15 PM> EasyJTAG API ver. 3307 7/5/2019 12:57:15 PM> Setting IO Levels to 1.8V 7/5/2019 12:57:15 PM> Setting frequence to 21 MHz 7/5/2019 12:57:16 PM> EasyJTAG Box Serial = 07FFA00BB62EEC02 7/5/2019 12:57:16 PM> EasyJTAG Box Firmware = 1.63 7/5/2019 12:57:19 PM> HiPower mode is ON 7/5/2019 12:57:19 PM> Setting frequence to 21 MHz 7/5/2019 12:57:19 PM> CMD Pullup Level: 247 mV 7/5/2019 12:57:19 PM> CMD Active Level: 2000 mV 7/5/2019 12:57:19 PM> eMMC Init returned = -1 7/5/2019 12:57:19 PM> Can't init device. Reason: CMD Timeout Error 7/5/2019 12:57:19 PM> |
07-05-2019, 12:29 | #21 (permalink) |
Member: 1409573 Status: Offline Sonork: 100.1615416 Thanks Meter: 84 | now clk resister missing by my mistake now stuck on quellcomm port only phone not power on is compatible MOORCK emmc adapter for emmc repair ? I have not good skill to emmc repair but I am trying to with easy jtag experts so please help me as a newcomer |
07-05-2019, 13:41 | #22 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Just make short clk lines your phone should on After clk lines short |
The Following User Says Thank You to ChandruChiyyan For This Useful Post: |
07-05-2019, 13:48 | #23 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | do we need to remove CLK resistor to connect via direct emmc? i have 2 unit A3s 1803 model 16gb samsung emmc done via oppo reset but the unit with 32gb hynix emmc cannot connect, always say "Can't init device, Reason: CARD Ready Timeout Error ".. |
07-05-2019, 13:52 | #24 (permalink) |
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | No need to remove clk resistor for direct connect Emmc...Maybe your connection not well in cmd line please check .. |
07-05-2019, 13:57 | #25 (permalink) |
Member: 159757 Status: Offline Thanks Meter: 461 | same problem here, A3s (1803) 32Gb Hynix eMMC always "Can't init device, Reason: CARD Ready Timeout Error" |
The Following User Says Thank You to rico_deep For This Useful Post: |
07-05-2019, 14:27 | #29 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | Quote: | |
