06-17-2019, 12:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | oppo r2001 after wipe data fail repair completely dead before phone had problem of wipe data fail, below are the repair logs: 6/17/2019 2:40:55 PM> Looking for EasyJTAG box... 6/17/2019 2:40:55 PM> EasyJTAG API ver. 2201 6/17/2019 2:40:55 PM> Setting IO Levels to 1.8V 6/17/2019 2:40:55 PM> Setting frequence to 18 Mhz 6/17/2019 2:40:55 PM> EasyJTAG Box Serial = 026862FABF5A25EA 6/17/2019 2:40:55 PM> EasyJTAG Box Firmware = 2.38 6/17/2019 2:40:55 PM> Setting interface to EasyJtag2/ISP 6/17/2019 2:40:55 PM> Setting bus width to 1 Bit 6/17/2019 2:40:55 PM> Setting frequence to 18 Mhz 6/17/2019 2:40:55 PM> CMD Pullup Level: 1822 mV 6/17/2019 2:40:55 PM> CMD Active Level: 1881 mV 6/17/2019 2:40:56 PM> eMMC Init returned = 0 6/17/2019 2:40:56 PM> EMMC Device Information : 6/17/2019 2:40:56 PM> EMMC CID: 90014A4838473264040503A260061239 6/17/2019 2:40:56 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 6/17/2019 2:40:56 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A26006 , rev. 0x05 6/17/2019 2:40:56 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2015 6/17/2019 2:40:56 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 6/17/2019 2:40:56 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/17/2019 2:40:56 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/17/2019 2:40:56 PM> EMMC Permanent Write Protection: No 6/17/2019 2:40:56 PM> EMMC Temporary Write Protection: No 6/17/2019 2:40:56 PM> Extended CSD Information : 6/17/2019 2:40:56 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 6/17/2019 2:40:56 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 6/17/2019 2:40:56 PM> Boot Bus Config: 0x00 , width 1bit 6/17/2019 2:40:56 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/17/2019 2:40:56 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/17/2019 2:40:56 PM> Device supports partitioning features 6/17/2019 2:40:56 PM> Device can have enhanced technological features in partitions and user data area 6/17/2019 2:40:56 PM> Device can have extended partitions attribute 6/17/2019 2:40:56 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/17/2019 2:40:56 PM> Backup saved: H8G2d_03A26006_20190617_144056.extcsd 6/17/2019 2:40:56 PM> EMMC Init completed. 6/17/2019 2:40:56 PM> 6/17/2019 2:40:56 PM> Scanning soft partitions 6/17/2019 2:40:56 PM> GPT header is not found 6/17/2019 2:40:56 PM> MBR header is found. Analyzing data ... 6/17/2019 2:40:56 PM> EBR detected at address: 000000080000 6/17/2019 2:40:56 PM> Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000 (10.0 MB) 6/17/2019 2:40:56 PM> Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000 (10.0 MB) 6/17/2019 2:40:56 PM> Partition: mmcblk0p2 [000002D80000 - 000003380000], size: 000000600000 (6.00 MB) 6/17/2019 2:40:56 PM> Partition: mmcblk0p3 [000005880000 - 000006880000], size: 000001000000 6/17/2019 2:40:56 PM> Partition: mmcblk0p4 [000007280000 - 00003F380000], size: 000038100000 6/17/2019 2:40:56 PM> Partition: mmcblk0p5 [00003F380000 - 000047180000], size: 000007E00000 6/17/2019 2:40:56 PM> Partition: mmcblk0p6 [000047180000 - 000087180000], size: 000040000000 6/17/2019 2:40:56 PM> Partition: mmcblk0p7 [000087180000 - 02000007FE00], size: 01FF78EFFE00 6/17/2019 2:40:56 PM> MBR header successfully parsed 6/17/2019 2:40:56 PM> 6/17/2019 2:40:56 PM> Get firmware version 6/17/2019 2:40:56 PM> GPT header is not found 6/17/2019 2:40:56 PM> 6/17/2019 2:40:57 PM> Firmware info not found 6/17/2019 2:41:12 PM> Looking for EasyJTAG box... 6/17/2019 2:41:12 PM> EasyJTAG API ver. 2201 6/17/2019 2:41:12 PM> Setting IO Levels to 1.8V 6/17/2019 2:41:12 PM> Setting frequence to 18 Mhz 6/17/2019 2:41:12 PM> EasyJTAG Box Serial = 026862FABF5A25EA 6/17/2019 2:41:12 PM> EasyJTAG Box Firmware = 2.38 6/17/2019 2:41:12 PM> Setting interface to EasyJtag2/ISP 6/17/2019 2:41:12 PM> Setting bus width to 1 Bit 6/17/2019 2:41:12 PM> Setting frequence to 18 Mhz 6/17/2019 2:41:12 PM> CMD Pullup Level: 1823 mV 6/17/2019 2:41:12 PM> CMD Active Level: 1879 mV 6/17/2019 2:41:13 PM> eMMC Init returned = 0 6/17/2019 2:41:13 PM> EMMC Device Information : 6/17/2019 2:41:13 PM> EMMC CID: 90014A4838473264040503A260061239 6/17/2019 2:41:13 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 6/17/2019 2:41:13 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A26006 , rev. 0x05 6/17/2019 2:41:13 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2015 6/17/2019 2:41:13 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 6/17/2019 2:41:13 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/17/2019 2:41:13 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/17/2019 2:41:13 PM> EMMC Permanent Write Protection: No 6/17/2019 2:41:13 PM> EMMC Temporary Write Protection: No 6/17/2019 2:41:13 PM> Extended CSD Information : 6/17/2019 2:41:13 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 6/17/2019 2:41:13 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 6/17/2019 2:41:13 PM> Boot Bus Config: 0x00 , width 1bit 6/17/2019 2:41:13 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/17/2019 2:41:13 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/17/2019 2:41:13 PM> Device supports partitioning features 6/17/2019 2:41:13 PM> Device can have enhanced technological features in partitions and user data area 6/17/2019 2:41:13 PM> Device can have extended partitions attribute 6/17/2019 2:41:13 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/17/2019 2:41:13 PM> Backup saved: H8G2d_03A26006_20190617_144113.extcsd 6/17/2019 2:41:13 PM> EMMC Init completed. 6/17/2019 2:41:13 PM> 6/17/2019 2:41:23 PM> Operation: Universal Factory Format 6/17/2019 2:41:23 PM> Please, wait ... 6/17/2019 2:41:27 PM> 6/17/2019 2:41:27 PM> Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 1821 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A4838473264040503A260061239 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A26006 , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G2d_03A26006_20190617_145631.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 0 MB , WR_REL: 1 , ENH 1 GP2 size: 0 MB , WR_REL: 1 , ENH 1 GP3 size: 0 MB , WR_REL: 1 , ENH 1 GP4 size: 0 MB , WR_REL: 1 , ENH 1 Zero sizes. This may damage your eMMC Do you want to continue? Successfully Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize operation After reconnect, make sure that the size of ROM1 has been changed. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 Mhz CMD Pullup Level: 1823 mV CMD Active Level: 1881 mV EMMC Device Information : EMMC CID: 90014A4838473264040503A260061239 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A26006 , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G2d_03A26006_20190617_151023.extcsd EMMC Init completed. Scanning soft partitions GPT header is not found MBR header is found. Analyzing data ... EBR detected at address: 000000080000 Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000 (10.0 MB) Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000 (10.0 MB) Partition: mmcblk0p2 [000002D80000 - 000003380000], size: 000000600000 (6.00 MB) Partition: mmcblk0p3 [000005880000 - 000006880000], size: 000001000000 Partition: mmcblk0p4 [000007280000 - 00003F380000], size: 000038100000 Partition: mmcblk0p5 [00003F380000 - 000047180000], size: 000007E00000 Partition: mmcblk0p6 [000047180000 - 000087180000], size: 000040000000 Partition: mmcblk0p7 [000087180000 - 02000007FE00], size: 01FF78EFFE00 MBR header successfully parsed Get firmware version GPT header is not found Brand = OPPO Manufacturer = OPPO Device = R2001 Model = R2001 CPU Abi = armeabi-v7a Mediatek platform = MT6582 Android release = 4.2.2 Firmware version = R2001_11_160504 Firmware date = Wed May 4 22:29:41 CST 2016 please suggest what is wrong, phone not getting on, and also not able to flash the phone via usb, phone is connecting as mtk usb device, without pressing boot key... |
06-17-2019, 15:49 | #2 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | when trying to cionnect on miracle its showing emmc size 0, please check: Waiting for USB Port... Set MediaTek USB Port (COM5) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x0000000000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 >>Not support Flash ID how suddenly phone got dead and not even flashing now, please experts help, please tell how to recover set |
06-19-2019, 04:25 | #6 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Yes sir trying to communicate with easy JTAG support, this is the official forum for easy JTAG, but there is no one to help in the official forum. |
06-19-2019, 09:21 | #7 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1430201 Status: Offline Thanks Meter: 0 | bro ur formate whole emmc u need to reprogramm emmc read log carefully 6/17/2019 2:41:12 PM> Looking for EasyJTAG box... 6/17/2019 2:41:12 PM> EasyJTAG API ver. 2201 6/17/2019 2:41:12 PM> Setting IO Levels to 1.8V 6/17/2019 2:41:12 PM> Setting frequence to 18 Mhz 6/17/2019 2:41:12 PM> EasyJTAG Box Serial = 026862FABF5A25EA 6/17/2019 2:41:12 PM> EasyJTAG Box Firmware = 2.38 6/17/2019 2:41:12 PM> Setting interface to EasyJtag2/ISP 6/17/2019 2:41:12 PM> Setting bus width to 1 Bit 6/17/2019 2:41:12 PM> Setting frequence to 18 Mhz 6/17/2019 2:41:12 PM> CMD Pullup Level: 1823 mV 6/17/2019 2:41:12 PM> CMD Active Level: 1879 mV 6/17/2019 2:41:13 PM> eMMC Init returned = 0 6/17/2019 2:41:13 PM> EMMC Device Information : 6/17/2019 2:41:13 PM> EMMC CID: 90014A4838473264040503A260061239 6/17/2019 2:41:13 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 6/17/2019 2:41:13 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A26006 , rev. 0x05 6/17/2019 2:41:13 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2015 6/17/2019 2:41:13 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 6/17/2019 2:41:13 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/17/2019 2:41:13 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/17/2019 2:41:13 PM> EMMC Permanent Write Protection: No 6/17/2019 2:41:13 PM> EMMC Temporary Write Protection: No 6/17/2019 2:41:13 PM> Extended CSD Information : 6/17/2019 2:41:13 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 6/17/2019 2:41:13 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 6/17/2019 2:41:13 PM> Boot Bus Config: 0x00 , width 1bit 6/17/2019 2:41:13 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/17/2019 2:41:13 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/17/2019 2:41:13 PM> Device supports partitioning features 6/17/2019 2:41:13 PM> Device can have enhanced technological features in partitions and user data area 6/17/2019 2:41:13 PM> Device can have extended partitions attribute 6/17/2019 2:41:13 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/17/2019 2:41:13 PM> Backup saved: H8G2d_03A26006_20190617_144113.extcsd 6/17/2019 2:41:13 PM> EMMC Init completed. 6/17/2019 2:41:13 PM> [U]6/17/2019 2:41:23 PM> Operation: Universal Factory Format 6/17/2019 2:41:23 PM> Please, wait ... 6/17/2019 2:41:27 PM> 6/17/2019 2:41:27 PM> Successfully |
06-19-2019, 19:14 | #8 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Yes sir, after universal factory format, I did write by vendor, r2001 scatter file, so at least phone should be hang on logo or at least I should be able to flash with sp flash tool, but getting error as I posted in the logs in post #2..... Please easy jtag experts please suggest something? |
