07-08-2019, 09:20 | #46 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Realme C2 (RMX1941) F.R.p & PinCode Reset Done Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:1742 mV CMD Active Level:1825 mV Box IO Level:1800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E0307411C834624 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2019 Rev.0x3 eMMC NAME: hB8aP> , S/N: 121707651 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_init Error, Reason: CMD CRC Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x015B000000 (23.640GB) Mount EXT4 fs... Blocks Reading Error (0x15B000400 , 2 , Reason: CMD CRC Error ) Unable to mount USER , code : 5 --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63 CMD Pullup Level:1732 mV CMD Active Level:1825 mV Box IO Level:1800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68423861503E0307411CA34624 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2019 Rev.0x3 eMMC NAME: hB8aP> , S/N: 121707683 eMMC NAME (HEX): 68423861503E EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 577 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x015B000000 (23.640GB) , formatting... Done. Done. Done. |
The Following 7 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-08-2019, 12:10 | #47 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | OPPO's (Realme, Vivo) FRP/Code/Pattern reset thread. Post succcesfully operations Post succsecfull operations at this thread No need to fill the forum with the same threads Last edited by layder; 06-16-2020 at 13:51. |
07-14-2019, 09:25 | #49 (permalink) |
Banned Join Date: Apr 2008
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | Oppo A3s Factory Reset, Pattern Lock, Passcode Remove With Easy JTAG Oppo A3s Factory Reset, Pattern Lock, Passcode Remove With Easy JTAG |
The Following 5 Users Say Thank You to marhabamobiles For This Useful Post: |
07-14-2019, 13:50 | #50 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Today 4 oppo a3s unlock done easy jtag plus rocking always TODAY 4 OPPO A3S UNLOCK DONE EASY JTAG PLUS ROCKING ALWAYS |
The Following 3 Users Say Thank You to royalnasim For This Useful Post: |
07-14-2019, 19:37 | #52 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Oppo reno passcode done with ic friend Just repost take from moorc ic friend facebook page Maybe First in the world by Hardware method Oppo reno passcode done Ufs 254 by ic friend VIDEO Code: https://www.youtube.com/watch?v=nsrKU3g0Fs0&t=12s |
07-15-2019, 09:01 | #53 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Realme 2 and Oppo K1 remove locks successfully ============================================== Realme 2 logs ============================================== Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:2117 mV CMD Active Level:3162 mV Box IO Level:3300 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:2093 mV CMD Active Level:2695 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D42011EE9683B750F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 518613051 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 19579 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_ 518613051_20190714_1405.extcsd Partition info successfully found ------ Detected 64 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0x5ec3fbe00] Size: 23.690GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190222.123456 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (23.690GB) Unable to mount USERDATA , code : 95 Done. Checking security ... Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:2092 mV CMD Active Level:2696 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D42011EE9683B750F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 518613051 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 19579 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x015B800000 (23.690GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. Checking security ... Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:2094 mV CMD Active Level:2696 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D42011EE9683B750F eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 518613051 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 19579 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. ================================================== ====== Oppo K1 ================================================== ====== Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:1806 mV CMD Active Level:1867 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010044483644414202C47CCCB0A569 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x2 eMMC NAME: DH6DAB , S/N: 3296513200 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1052 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DH6DAB_3296513200_20190715_1222.extcsd Partition info successfully found ------ Detected 69 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x200000] Size: 2.0MB P3 (MODEMST2) [0x1605000 0x200000] Size: 2.0MB P4 (PERSIST) [0x1805000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3805000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x4005000 0x4000000] Size: 64.0MB P7 (CARRIER) [0x8005000 0x800000] Size: 8.0MB P8 (XBL) [0x9000000 0x380000] Size: 3.500MB P9 (XBLBAK) [0x9380000 0x380000] Size: 3.500MB P10 (TZ) [0x9700000 0x400000] Size: 4.0MB P11 (TZBAK) [0x9b00000 0x400000] Size: 4.0MB P12 (RPM) [0x9f00000 0x80000] Size: 512.0KB P13 (RPMBAK) [0x9f80000 0x80000] Size: 512.0KB P14 (HYP) [0xa000000 0x80000] Size: 512.0KB P15 (HYPBAK) [0xa080000 0x80000] Size: 512.0KB P16 (PMIC) [0xa100000 0x80000] Size: 512.0KB P17 (PMICBAK) [0xa180000 0x80000] Size: 512.0KB P18 (FSG) [0xa200000 0x200000] Size: 2.0MB P19 (BOOT) [0xa800000 0x4000000] Size: 64.0MB P20 (BOOTBAK) [0xe800000 0x4000000] Size: 64.0MB P21 (RECOVERY) [0x12800000 0x4000000] Size: 64.0MB P22 (KEYMASTER) [0x16800000 0x100000] Size: 1.0MB P23 (KEYMASTERBAK) [0x16900000 0x100000] Size: 1.0MB P24 (CMNLIB) [0x16a00000 0x100000] Size: 1.0MB P25 (CMNLIB64) [0x16b00000 0x100000] Size: 1.0MB P26 (CMNLIBBAK) [0x16c00000 0x100000] Size: 1.0MB P27 (CMNLIB64BAK) [0x16d00000 0x100000] Size: 1.0MB P28 (MDTPSECAPP) [0x16e00000 0x400000] Size: 4.0MB P29 (MDTPSECAPPBAK) [0x17200000 0x400000] Size: 4.0MB P30 (MDTP) [0x17600000 0x2000000] Size: 32.0MB P31 (MDTPBAK) [0x19600000 0x2000000] Size: 32.0MB P32 (DSP) [0x1b600000 0x1000000] Size: 16.0MB P33 (DSPBAK) [0x1c600000 0x1000000] Size: 16.0MB P34 (ABL) [0x1d600000 0x100000] Size: 1.0MB P35 (ABLBAK) [0x1d700000 0x100000] Size: 1.0MB P36 (DIP) [0x1d800000 0x100000] Size: 1.0MB P37 (DEVINFO) [0x1d900000 0x1000] Size: 4.0KB P38 (APDP) [0x1d901000 0x40000] Size: 256.0KB P39 (MSADP) [0x1d941000 0x40000] Size: 256.0KB P40 (DPO) [0x1d981000 0x400] Size: 1.0KB P41 (SPLASH) [0x1d982000 0x20a4000] Size: 32.640MB P42 (LIMITS) [0x1fa26000 0x1000] Size: 4.0KB P43 (TOOLSFV) [0x1fa27000 0x100000] Size: 1.0MB P44 (LOGFS) [0x20000000 0x800000] Size: 8.0MB P45 (DDR) [0x20800000 0x100000] Size: 1.0MB P46 (SEC) [0x20900000 0x4000] Size: 16.0KB P47 (BLUETOOTH) [0x20904000 0x100000] Size: 1.0MB P48 (BLUETOOTHBAK) [0x20a04000 0x100000] Size: 1.0MB P49 (FSC) [0x21000000 0x400] Size: 1.0KB P50 (SSD) [0x21001000 0x2000] Size: 8.0KB P51 (MISC) [0x21003000 0x100000] Size: 1.0MB P52 (KEYSTORE) [0x21103000 0x80000] Size: 512.0KB P53 (DEVCFG) [0x21183000 0x100000] Size: 1.0MB P54 (DEVCFGBAK) [0x21283000 0x100000] Size: 1.0MB P55 (FRP) [0x21383000 0x80000] Size: 512.0KB P56 (LOGDUMP) [0x21403000 0x4000000] Size: 64.0MB P57 (STI) [0x25403000 0x200000] Size: 2.0MB P58 (LOGO) [0x25603000 0x1000000] Size: 16.0MB P59 (DRIVER) [0x26603000 0x2000000] Size: 32.0MB P60 (VBMETA) [0x28800000 0x10000] Size: 64.0KB P61 (VBMETABAK) [0x28810000 0x10000] Size: 64.0KB P62 (MODEM) [0x28820000 0x8000000] Size: 128.0MB P63 (CACHE) [0x31000000 0x10000000] Size: 256.0MB P64 (SYSTEM) [0x41000000 0x150000000] Size: 5.250GB P65 (VENDOR) [0x191000000 0x60000000] Size: 1.500GB P66 (ODM) [0x1f1000000 0x10000000] Size: 256.0MB P67 (STORSEC) [0x201000000 0x20000] Size: 128.0KB P68 (USERDATA) [0x201800000 0xc8dffbe00] Size: 50.217GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0041000000 (5.250GB) Build ID: OPM1.171019.011 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: sdm660_64-user 8.1.0 OPM1.171019.011 eng.root.20190523.001645 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0201800000 (50.217GB) Unable to mount USERDATA , code : 95 Done. Checking security ... Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:1805 mV CMD Active Level:1866 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010044483644414202C47CCCB0A569 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x2 eMMC NAME: DH6DAB , S/N: 3296513200 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1052 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x0201800000 (50.217GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. Checking security ... Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 12588BC51D8A7419, ,FW Ver.: 02.44 CMD Pullup Level:1806 mV CMD Active Level:1867 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010044483644414202C47CCCB0A569 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x2 eMMC NAME: DH6DAB , S/N: 3296513200 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1052 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (51) Done. |
07-15-2019, 13:03 | #54 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | oppo a3s done wipe userdata and frp done by emmc EasyJtag Suite Classic ver.: 3.6.1.2 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 10 (build 10586), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.10586.306, are OK Z3X Card Serial : AAF9-6E71 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 3 serial devices COM50 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM50) COM4 root\rimports RIM Virtual Serial Port v2 (COM4) COM5 root\rimports RIM Virtual Serial Port v2 (COM5) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:1165 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63 CMD Pullup Level:1691 mV CMD Active Level:2660 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63 CMD Pullup Level:1732 mV CMD Active Level:2887 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420680B8CEFE654C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2159595262 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 69466 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2159595262_20190715_1458.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x02] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x04] i.e. 30% - 40% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x04] i.e. 30% - 40% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x08] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x06 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d1f000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x02 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Found Data areas (firmware parts) count is: 65 --------------------------------------------- P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB P9 (FSC) [0x8305000 0x400] Size: 1.0KB P10 (SSD) [0x8306000 0x2000] Size: 8.0KB P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB P12 (RPM) [0x8388000 0x80000] Size: 512.0KB P13 (TZ) [0x8408000 0x200000] Size: 2.0MB P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB P20 (DDR) [0xa000000 0x8000] Size: 32.0KB P21 (FSG) [0xa008000 0x180000] Size: 1.500MB P22 (SEC) [0xa188000 0x4000] Size: 16.0KB P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB P41 (DIP) [0x30880000 0x100000] Size: 1.0MB P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB P53 (APDP) [0x33800000 0x40000] Size: 256.0KB P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB P55 (DPO) [0x33880000 0x2000] Size: 8.0KB P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB P59 (HYP) [0x38800000 0x800000] Size: 8.0MB P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB P64 (USERDATA) [0x158000000 0x24bdfbe00] Size: 9.184GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63 CMD Pullup Level:1722 mV CMD Active Level:2887 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420680B8CEFE654C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2159595262 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 69466 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting... Done. Done. Done. Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 12FFA012870558E8, ,FW Ver.: 01.63 CMD Pullup Level:1722 mV CMD Active Level:2897 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420680B8CEFE654C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2159595262 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 69466 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) Erasing... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) Erasing... Done. --------------------------------------------- Done. |
07-15-2019, 13:09 | #55 (permalink) |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
07-16-2019, 17:16 | #57 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | Realme C1,A3S Pattern Remove Done With Easy Jtag Realme C1,A3S How To Reset Free Pattern Unlock | How To Hard Reset Realme C1 Easy Jtag |
07-16-2019, 19:24 | #58 (permalink) |
Crazy Poster Join Date: Jun 2011 Location: india (agartala)
Member: 1589436 Status: Offline Sonork: [email protected] Thanks Meter: 8 | realme 2 pin pattern frp unlock done by easy jtag https://www.youtube.com/watch?v=HlErtSLzPog subscribe my channel https://www.youtube.com/watch?v=id8Ql2OZjxI plz subscribe my youtube channel Last edited by layder; 07-16-2019 at 20:10. Reason: merge posts |
The Following 2 Users Say Thank You to pintu gsm For This Useful Post: |
07-16-2019, 20:50 | #59 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | Hello am facing the problem i format oppo f9 [cph1823ex] for unlock s/c then wipe okay i try to on phone phone logo stuck then i format with button then phone no logo stuck after i remove buttery and try to make on phone rebooting on logo and now i dont know what to do please anyone can help me? |
