05-05-2020, 22:51 | #181 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Oppo A31 CPH2015 Password N FRP Unlock Done Via Easy JTAG Easy Method Phone Brand : Oppo Model : A31 Engineering Model Name : CPH2015 Connection Method :- ISP Device Use : Easy JTAG Plus Tool Use : Easy JTAG Emmc Manager Speed 36MHZ Voltage 2.8V (From GUI) Use USB For Power Supply |
The Following 3 Users Say Thank You to hitech care For This Useful Post: |
05-06-2020, 13:26 | #183 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | https://3.bp.b-logspot.com/-IVAJ7Up6...08581888_o.jpg Remove - from b-logsport copy paste link in browser |
The Following User Says Thank You to hitech care For This Useful Post: |
05-30-2020, 12:49 | #187 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,952 | you can use this thead http://forum.gsmhosting.com/vbb/f672...ammad-2813504/ for understanding how do it many devices use identical procedure to repair it |
The Following User Says Thank You to layder For This Useful Post: |
06-01-2020, 23:22 | #189 (permalink) | |
Freak Poster Join Date: Nov 2009 Location: MOROCCO
Member: 1164285 Status: Offline Sonork: 100.1648187 Thanks Meter: 296 | Oppo a31 reset patern user code and frp Quote:
FOR ALL MAMBER NOT NEED TO OPEN FIL MANGER BLA BLABLA JUST US EasyJTAG Tool SOLDRING PINOUT AND CONCET TO BOX .GOOD LUK FOR ALL | |
06-14-2020, 13:24 | #194 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: rajasthan
Member: 597610 Status: Offline Thanks Meter: 50 | Oppo a3s wipe user data after dead Quote:
please help me OPPO a3s wipe user data after dead show onlu qulacoom mode show only -------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206948097F2B5BE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2491455474 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 88811 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2491455474_20200614_1753.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190624.211613 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. please help me | |
06-14-2020, 17:50 | #195 (permalink) | |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,366 | please see this topic Quote:
https://forum.gsmhosting.com/vbb/f67...ammad-2813504/ | |
