08-17-2020, 11:34 | #211 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Oppo a7(cph1901) password unlock done OS ver.: Windows 10 (build 18362), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AA45-6185 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 1 serial devices COM7 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM7) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8289EDC45C3BA0F4, ,FW Ver.: 02.52 CMD Pullup Level:2138 mV CMD Active Level:2382 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A227E96048953D eMMC CSD : D02701328F5903FFFFFFFFEF8A400027 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 669605960 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 4670 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HCG8a4_ 669605960_20200817_1621.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB) Short EXT fs info: Size: 3.905GB Block size: 4.0KB Inode size: 256 Inodes: 256000 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2019-05-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190516.002839 release-keys Backup saved: BuildProp_20200817_1621.txt --------------------------------------------- Detected USERDATA USERDATA : 0x017E800000 (52.264GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: C78F8393 6A9EB46B 26779BEC A63E8733 BF60FDF0 BF750BC6 08062C49 4DC79D12 Ç.ƒ“jž´k&w›ì¦>‡3¿`ýð¿u.Æ..,IMÇ..; FBD74917 9AA5A6FC 5FE3D6B1 D2C5EE49 78E562F5 5B877D3E BBDDB129 54EEE182 û×I.š¥¦ü_ãÖ±ÒÅîIxåbõ[‡}>»Ý±)Tîá‚; 1CB6F105 2D76A55F F09477D8 EB07F5E3 F93B3FA0 A80210EB 990B122C A140E98F .¶ñ.-v¥_ð”wØë.õãù;?*¨..ë...,¡@é.; 5B977CE5 D35408A5 5F21FA50 DD6DDF69 B7F91CDA 59A5B16B F9FC3A5A C5FC7DA2 [—|åÓT.¥_!úPÝmßi·ù.ÚY¥±kùü:ZÅü}¢; 1A9CD2F3 1439DB8E A35FEB97 83D2CE55 00BEF942 EEBC5325 1E681026 A3EF5E5D .œÒó.9ÛŽ£_ë—ƒÒÎU.¾ùBî¼S%.h.&£ï^]; A6C575E5 51E96285 000305D6 DB212EB8 F64F30A4 3D9E4845 29A3ADE3 F1B12A9E ¦ÅuåQéb…...ÖÛ!.¸öO0¤=žHE)£*ãñ±*ž; 26F51964 CC3DA098 A7EB2266 D08CFB9E 48812403 D74E0AB1 F09995D1 3DC6D5A8 &õ.dÌ=*.§ë"fÐŒûžH.$.×N.±ð.•Ñ=ÆÕ¨; 5A4855DA BE792E1F A2EC78EA 5D20E01F 2BF7FF0F 7E98FFE7 1A31C784 AEACB0BF ZHUÚ¾y..¢ìxê] à.+÷ÿ.~.ÿç.1Ç„®¬°¿; Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8289EDC45C3BA0F4, ,FW Ver.: 02.52 CMD Pullup Level:2138 mV CMD Active Level:2384 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A227E96048953D eMMC CSD : D02701328F5903FFFFFFFFEF8A400027 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 669605960 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 4670 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. Last edited by Shohel_sst; 08-17-2020 at 11:35. Reason: add title |
08-17-2020, 14:01 | #212 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme 2 rmx1805 pattern unlock Code: Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2547 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D420163BE96B5A586 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 1673434805 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 143920 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_1673434805_20200817_1344.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (23.690GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: D634632D 85FA29F3 F2E506D2 1CF131FD EACF2DC3 E1F08E83 0779B58B 354A1496 Ö4c-…ú)óòå.Ò.ñ1ýêÏ-ÃáðŽƒ.yµ‹5J.–; 163B8B34 F569C8C0 18301A5F 1179F6D5 30A2C120 5D0028F0 4B87CDE7 6066010C .;‹4õiÈÀ.0._.yöÕ0¢Á ].(ðK‡Íç`f..; C48E1A0E C8FF9E72 CBF154EC CC443BAD 10FF6CFB A6E75C6F 16F8248F 9DB98CC0 ÄŽ..ÈÿžrËñTìÌD;*.ÿlû¦ç\o.ø$..¹ŒÀ; 9792B981 E512C6F1 A59F3BE6 1427F8AC FBAD1447 AF6355A9 F0D2D566 97A82A5C —’¹.å.Æñ¥Ÿ;æ.'ø¬û*.G¯cU©ðÒÕf—¨*\; 54AAE9C9 507C9DD0 8955C4DE D75C09E1 35CEFAE9 5656DEF9 4F47090C E87C37A2 TªéÉP|.ЉUÄÞ×\ á5ÎúéVVÞùOG .è|7¢; 5D12F351 2D86B3A1 588D8AD0 6A576EE1 CE02F2F5 75072D21 F02CB423 D6787727 ].óQ-†³¡X.ŠÐjWnáÎ.òõu.-!ð,´#Öxw'; 04892494 B17B8C51 EE99F429 1E4FF2A7 7376D8E0 4258737C BE6008BC 972D45BD .‰$”±{ŒQî.ô).Oò§svØàBXs|¾`.¼—-E½; D212D155 1F66CB8E 01799907 834BF205 A9B3455B F4B6D995 6F508569 E71C8ED3 Ò.ÑU.fËŽ.y..ƒKò.©³E[ô¶Ù•oP…iç.ŽÓ; Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D420163BE96B5A586 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 1673434805 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 143920 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
08-17-2020, 15:56 | #213 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme 2 rmx1805 pattern unlock another done Code: Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2021 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D4201425968497534 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 1113155657 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 50000 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_1113155657_20200817_2016.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2019-03-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190319.220028 release-keys Backup saved: BuildProp_20200817_2016.txt --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (23.690GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 71AB2545 D70DCD68 963F6857 00419417 B845205D 99B66B3D C033DFB7 2063A99F q«%E×.Íh–?hW.A”.¸E ].¶k=À3ß· c©Ÿ; EA093224 EF3E338F EB518C71 B0581FFB 40B6668E C9D98211 A8659C95 8C6682A1 ê 2$ï>3.ëQŒq°X.û@¶fŽÉÙ‚.¨eœ•Œf‚¡; F7279477 5F153E28 69A8F08A 34D2F56F 16D33AA5 F87A0830 4CD46891 287D3793 ÷'”w_.>(i¨ðŠ4Òõo.Ó:¥øz.0LÔh‘(}7“; AAF50B50 A3B5824A CE51FB56 5333ACCD 746788DB DDCB7ABA 97101A17 91F8A7DD ªõ.P£µ‚JÎQûVS3¬Ítg.ÛÝËzº—...‘ø§Ý; 79FB5124 A61E20D8 9B4527D6 E39E4B10 8180DDB3 FFB40E22 50ADB928 94A7F0F4 yûQ$¦. Ø›E'ÖãžK...ݳÿ´."P*¹(”§ðô; 5258722A E767FECF DF5AACAE 52392758 70FBC33F 6437F8C9 7D0C0CF8 D4630A82 RXr*çgþÏßZ¬®R9'XpûÃ?d7øÉ}..øÔc.‚; FF031268 7F0DCE8C 7719C6E1 3C51FD15 1C315374 25FC5E11 50984D21 47AC4EC5 ÿ..h..ÎŒw.Æá<Qý..1St%ü^.P.M!G¬NÅ; F2CF94FB C1BDDD6F E26212BD E4000435 2AC4E32F 641EFFC2 02660E85 954FD2A7 òÏ”ûÁ½Ýoâb.½ä..5*Äã/d.ÿÂ.f.…•OÒ§; Done. Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D4201425968497534 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: 1113155657 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 50000 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
08-22-2020, 09:33 | #214 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | oppo k1 cph1893 unlock easy jtag eemc file maneger tool Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 3300 mV Scanner Thread Created.. Config: 100111111110111 Setup HiPower CLK: OFF Disable HS Timing: TRUE Connecting To EasyJtag Box: 3300mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 2052 mV CMD Active Level: 2794 mV EasyJtag S/N: 0707031F7AA05FBD EasyJtag Box FirmWare: 1.63 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 15010044483644414202C1C66A39C59A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC VENDOR: SAMSUNG EMMC NAME: DH6DAB EMMC SERIAL: C1C66A39 EMMC REVISION: 02 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 117657 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC Boot Config: 0x38/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 72 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: OPPODYCNVBK [000000005000 - 000000A00000] Size: 10.00 MB GPT: OPPOSTANVBK [000000A05000 - 000000A00000] Size: 10.00 MB GPT: MODEMST1 [000001405000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000001605000 - 000000200000] Size: 2.00 MB GPT: PERSIST [000001805000 - 000002000000] Size: 32.00 MB GPT: OPPORESERVE1 [000003805000 - 000000800000] Size: 8.00 MB GPT: OPPORESERVE2 [000004005000 - 000004000000] Size: 64.00 MB GPT: CARRIER [000008005000 - 000000800000] Size: 8.00 MB GPT: XBL [000009000000 - 000000380000] Size: 3.50 MB GPT: XBLBAK [000009380000 - 000000380000] Size: 3.50 MB GPT: TZ [000009700000 - 000000400000] Size: 4.00 MB GPT: TZBAK [000009B00000 - 000000400000] Size: 4.00 MB GPT: RPM [000009F00000 - 000000080000] Size: 512.00 KB GPT: RPMBAK [000009F80000 - 000000080000] Size: 512.00 KB GPT: HYP [00000A000000 - 000000080000] Size: 512.00 KB GPT: HYPBAK [00000A080000 - 000000080000] Size: 512.00 KB GPT: PMIC [00000A100000 - 000000080000] Size: 512.00 KB GPT: PMICBAK [00000A180000 - 000000080000] Size: 512.00 KB GPT: FSG [00000A200000 - 000000200000] Size: 2.00 MB GPT: BOOT [00000A800000 - 000004000000] Size: 64.00 MB GPT: BOOTBAK [00000E800000 - 000004000000] Size: 64.00 MB GPT: RECOVERY [000012800000 - 000004000000] Size: 64.00 MB GPT: KEYMASTER [000016800000 - 000000100000] Size: 1.00 MB GPT: KEYMASTERBAK [000016900000 - 000000100000] Size: 1.00 MB GPT: CMNLIB [000016A00000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64 [000016B00000 - 000000100000] Size: 1.00 MB GPT: CMNLIBBAK [000016C00000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64BAK [000016D00000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP [000016E00000 - 000000400000] Size: 4.00 MB GPT: MDTPSECAPPBAK [000017200000 - 000000400000] Size: 4.00 MB GPT: MDTP [000017600000 - 000002000000] Size: 32.00 MB GPT: MDTPBAK [000019600000 - 000002000000] Size: 32.00 MB GPT: DSP [00001B600000 - 000001000000] Size: 16.00 MB GPT: DSPBAK [00001C600000 - 000001000000] Size: 16.00 MB GPT: ABL [00001D600000 - 000000100000] Size: 1.00 MB GPT: ABLBAK [00001D700000 - 000000100000] Size: 1.00 MB GPT: DIP [00001D800000 - 000000100000] Size: 1.00 MB GPT: DEVINFO [00001D900000 - 000000001000] Size: 4.00 KB GPT: APDP [00001D901000 - 000000040000] Size: 256.00 KB GPT: MSADP [00001D941000 - 000000040000] Size: 256.00 KB GPT: DPO [00001D981000 - 000000000400] Size: 1.00 KB GPT: SPLASH [00001D982000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00001FA26000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00001FA27000 - 000000100000] Size: 1.00 MB GPT: LOGFS [000020000000 - 000000800000] Size: 8.00 MB GPT: DDR [000020800000 - 000000100000] Size: 1.00 MB GPT: SEC [000020900000 - 000000004000] Size: 16.00 KB GPT: BLUETOOTH [000020904000 - 000000100000] Size: 1.00 MB GPT: BLUETOOTHBAK [000020A04000 - 000000100000] Size: 1.00 MB GPT: FSC [000021000000 - 000000000400] Size: 1.00 KB GPT: SSD [000021001000 - 000000002000] Size: 8.00 KB GPT: MISC [000021003000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000021103000 - 000000080000] Size: 512.00 KB GPT: DEVCFG [000021183000 - 000000100000] Size: 1.00 MB GPT: DEVCFGBAK [000021283000 - 000000100000] Size: 1.00 MB GPT: FRP [000021383000 - 000000080000] Size: 512.00 KB GPT: LOGDUMP [000021403000 - 000004000000] Size: 64.00 MB GPT: STI [000025403000 - 000000200000] Size: 2.00 MB GPT: LOGO [000025603000 - 000001000000] Size: 16.00 MB GPT: DRIVER [000026603000 - 000002000000] Size: 32.00 MB GPT: VBMETA [000028800000 - 000000010000] Size: 64.00 KB GPT: VBMETABAK [000028810000 - 000000010000] Size: 64.00 KB GPT: MODEM [000028820000 - 000008000000] Size: 128.00 MB GPT: CACHE [000031000000 - 000010000000] Size: 256.00 MB GPT: SYSTEM [000041000000 - 000150000000] Size: 5.25 GB GPT: VENDOR [000191000000 - 000060000000] Size: 1.50 GB GPT: ODM [0001F1000000 - 000010000000] Size: 256.00 MB GPT: STORSEC [000201000000 - 000000020000] Size: 128.00 KB GPT: USERDATA [000201800000 - 000C8DFFBE00] Size: 50.22 GB GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GUID Partition Table is Found. Max Parts: 4 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: CDT [000000004400 - 000000000800] Size: 2.00 KB GPT: LAST_GROW [000000004C00 - 0000003F7200] Size: 3.97 MB GPT: BACKUP_GPT [0000003FBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Partition #9 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #11 mount as [/mnt/vendor/opporeserve] -> 64.00 MB Partition #37 mount as [/dev_37] -> 16.00 MB Partition #38 mount as [/dev_38] -> 16.00 MB Partition #52 mount as [/BLUETOOTH] -> 1.00 MB Partition #53 mount as [/BLUETOOTHBAK] -> 1.00 MB Partition #67 mount as [/MODEM] -> 128.00 MB Partition #68 mount as [/cache] -> 256.00 MB Partition #69 mount as [/dev_69] -> 5.25 GB Partition #70 mount as [/dev_70] -> 1.50 GB ================================= Warning! Partition #73 -> 'USERDATA' is ENCRYPTED! ================================= EmptyCheck: EMPTY -> #11 - [CARRIER] EMPTY -> #22 - [FSG] EMPTY -> #40 - [DIP] EMPTY -> #43 - [MSADP] EMPTY -> #47 - [TOOLSFV] EMPTY -> #48 - [LOGFS] EMPTY -> #55 - [MISC] EMPTY -> #56 - [KEYSTORE] EMPTY -> #60 - [LOGDUMP] EMPTY -> #61 - [STI] EMPTY -> #62 - [LOGO] EMPTY -> #70 - [ODM] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #60 -> FRP ================================= Android Info: Vendor = OPPO CPU ABI = arm64-v8a Android Version = 9 Android Info: Brand = OPPO Device = CPH1893 Model = CPH1893 Product = CPH1893 Firm Version = CPH1893EX_11_C.36 Inc. Version = 1590570701 Firm Date = Wed May 27 17:11:41 CST 2020 Security Patch = 2020-05-05 Android Info: Platform = sdm660 Scanner Thread Terminated Elapsed: 00:00:14:726 Found 78 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2062 mV CMD Active Level: 2805 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Operation Done: [Init Engine], Elapsed: 00:00:02:215 Universal Wipe User Data v1.0 Wiping MISC Partition.. Partition #56 is '/MISC'. Erasing.. Wipe Mode: Oppo/Vivo Factory Reset Wipe 'MISC' Partition Done.. Wiping PARA Partition.. Partition PARA Not Found. Skip.. Done Wiping Data.. Elapsed Time: [00:00:00:100] Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:123 Universal Wipe User Data v1.0 Wiping MISC Partition.. Partition #56 is '/MISC'. Erasing.. Wipe Mode: Oppo/Vivo Factory Reset Wipe 'MISC' Partition Done.. Wiping PARA Partition.. Partition PARA Not Found. Skip.. Done Wiping Data.. Elapsed Time: [00:00:00:093] Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:097 |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
08-24-2020, 15:04 | #215 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo f11 cph1911 pass unlock easy jtag emmc file manger Android Info: Brand = OPPO Device = OP4863 Model = CPH1969 Product = CPH1969 Firm Version = CPH1969EX_11_A.37 Inc. Version = 1573459443 Firm Date = Mon Nov 11 16:04:03 CST 2019 OPPO Name = OPPO F11 Pro INFO OR UNLOCK LOG Code:
08-29-2020, 16:44 | #216 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo f9 cph1881 pass unlock easy Jtag |
08-29-2020, 16:55 | #217 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a31 cph2015 pass unlock easy jtag |
10-06-2020, 08:05 | #221 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | oppo a3s pattern reset done Code: Config: 100111111110111 Setup HiPower CLK: OFF Disable HS Timing: TRUE Connecting To EasyJtag Box: 3300mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 2041 mV CMD Active Level: 3000 mV EasyJtag S/N: 0707031F7++++++= EasyJtag Box FirmWare: 1.63 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 150100514536334D420616B7D8306556 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC VENDOR: SAMSUNG EMMC NAME: QE63MB EMMC SERIAL: 16B7D830 EMMC REVISION: 06 EMMC ROM1 Size: 30535680 Block(s)/14910 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 8192 Block(s)/4096 KB EMMC RPMB Counter: 71398 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x03 -> 20% - 30% Life Time Used EMMC SLC Life Time: 0x03 -> 20% - 30% Life Time Used EMMC Boot Config: 0x38/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 68 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: OPPODYCNVBK [000000005000 - 000000A00000] Size: 10.00 MB GPT: OPPOSTANVBK [000000A05000 - 000000A00000] Size: 10.00 MB GPT: MODEMST1 [000001405000 - 000000180000] Size: 1.50 MB GPT: MODEMST2 [000001585000 - 000000180000] Size: 1.50 MB GPT: PERSIST [000001705000 - 000002000000] Size: 32.00 MB GPT: OPPORESERVE1 [000003705000 - 000000800000] Size: 8.00 MB GPT: OPPORESERVE2 [000003F05000 - 000004000000] Size: 64.00 MB GPT: RESERVE_EXP1 [000007F05000 - 000000200000] Size: 2.00 MB GPT: RESERVE_EXP2 [000008105000 - 000000200000] Size: 2.00 MB GPT: FSC [000008305000 - 000000000400] Size: 1.00 KB GPT: SSD [000008306000 - 000000002000] Size: 8.00 KB GPT: SBL1 [000008308000 - 000000080000] Size: 512.00 KB GPT: RPM [000008388000 - 000000080000] Size: 512.00 KB GPT: TZ [000008408000 - 000000200000] Size: 2.00 MB GPT: DEVCFG [000008608000 - 000000040000] Size: 256.00 KB GPT: SBL1BAK [000008648000 - 000000080000] Size: 512.00 KB GPT: RPMBAK [0000086C8000 - 000000080000] Size: 512.00 KB GPT: TZBAK [000008748000 - 000000200000] Size: 2.00 MB GPT: DEVCFGBAK [000008948000 - 000000040000] Size: 256.00 KB GPT: DSP [000008988000 - 000001000000] Size: 16.00 MB GPT: DDR [00000A000000 - 000000008000] Size: 32.00 KB GPT: FSG [00000A008000 - 000000180000] Size: 1.50 MB GPT: SEC [00000A188000 - 000000004000] Size: 16.00 KB GPT: ABOOT [00000A18C000 - 000000100000] Size: 1.00 MB GPT: ABOOTBAK [00000A28C000 - 000000100000] Size: 1.00 MB GPT: MODEM [00000A38C000 - 000008000000] Size: 128.00 MB GPT: DTBO [00001238C000 - 000000800000] Size: 8.00 MB GPT: VBMETA [000012B8C000 - 000000010000] Size: 64.00 KB GPT: BOOT [000012B9C000 - 000004000000] Size: 64.00 MB GPT: RECOVERY [000016B9C000 - 000004000000] Size: 64.00 MB GPT: DEVINFO [00001AB9C000 - 000000100000] Size: 1.00 MB GPT: SPLASH [00001B000000 - 000000B00000] Size: 11.00 MB GPT: LOGO [00001BB00000 - 000002000000] Size: 32.00 MB GPT: DRIVER [00001DB00000 - 000002000000] Size: 32.00 MB GPT: CACHE [00001FB00000 - 000010000000] Size: 256.00 MB GPT: MISC [00002FB00000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [00002FC00000 - 000000080000] Size: 512.00 KB GPT: CONFIG [00002FC80000 - 000000008000] Size: 32.00 KB GPT: OEM [00002FC88000 - 000000100000] Size: 1.00 MB GPT: LIMITS [000030000000 - 000000008000] Size: 32.00 KB GPT: MOTA [000030800000 - 000000080000] Size: 512.00 KB GPT: DIP [000030880000 - 000000100000] Size: 1.00 MB GPT: MDTP [000030980000 - 000002000000] Size: 32.00 MB GPT: SYSCFG [000032980000 - 000000080000] Size: 512.00 KB GPT: MCFG [000032A00000 - 000000400000] Size: 4.00 MB GPT: LKSECAPP [000033000000 - 000000020000] Size: 128.00 KB GPT: CMNLIB [000033020000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64 [000033120000 - 000000100000] Size: 1.00 MB GPT: KEYMASTER [000033220000 - 000000100000] Size: 1.00 MB GPT: LKSECAPPBAK [000033320000 - 000000020000] Size: 128.00 KB GPT: CMNLIBBAK [000033340000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64BAK [000033440000 - 000000100000] Size: 1.00 MB GPT: KEYMASTERBAK [000033540000 - 000000100000] Size: 1.00 MB GPT: APDP [000033800000 - 000000040000] Size: 256.00 KB GPT: MSADP [000033840000 - 000000040000] Size: 256.00 KB GPT: DPO [000033880000 - 000000002000] Size: 8.00 KB GPT: LOGDUMP [000033882000 - 000004000000] Size: 64.00 MB GPT: VM-KYSTORE [000037882000 - 000000100000] Size: 1.00 MB GPT: VM-DATA [000037982000 - 000000A00000] Size: 10.00 MB GPT: HYP [000038800000 - 000000800000] Size: 8.00 MB GPT: VM-SYSTEM [000039000000 - 000004000000] Size: 64.00 MB GPT: VM-LINUX [00003D000000 - 000002000000] Size: 32.00 MB GPT: SYSTEM [00003F000000 - 0000D6900000] Size: 3.35 GB GPT: VENDOR [000115900000 - 000041F60000] Size: 1.03 GB GPT: USERDATA [000158000000 - 00024BDFBE00] Size: 9.19 GB GPT: BACKUP_GPT [0003A3DFBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GUID Partition Table is Found. Max Parts: 4 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: CDT [000000004400 - 000000000800] Size: 2.00 KB GPT: LAST_GROW [000000004C00 - 0000003F7200] Size: 3.97 MB GPT Backup Header Not Found Reading Table Completed Partition #9 mount as [/persist] -> 32.00 MB Partition #11 mount as [/opporeserve] -> 64.00 MB Partition #24 mount as [/dev_24] -> 16.00 MB Partition #30 mount as [/MODEM] -> 128.00 MB Partition #39 mount as [/cache] -> 256.00 MB Partition #67 mount as [/system] -> 3.35 GB Partition #68 mount as [/vendor] -> 1.03 GB ================================= Warning! Partition #69 -> 'USERDATA' is ENCRYPTED! ================================= EmptyCheck: EMPTY -> #11 - [RESERVE_EXP1] EMPTY -> #12 - [RESERVE_EXP2] EMPTY -> #25 - [FSG] EMPTY -> #35 - [SPLASH] EMPTY -> #39 - [MISC] EMPTY -> #40 - [KEYSTORE] EMPTY -> #42 - [OEM] EMPTY -> #43 - [LIMITS] EMPTY -> #44 - [MOTA] EMPTY -> #45 - [DIP] EMPTY -> #47 - [SYSCFG] EMPTY -> #48 - [MCFG] EMPTY -> #58 - [MSADP] EMPTY -> #59 - [DPO] EMPTY -> #60 - [LOGDUMP] EMPTY -> #61 - [VM-KYSTORE] EMPTY -> #62 - [VM-DATA] EMPTY -> #63 - [HYP] EMPTY -> #64 - [VM-SYSTEM] EMPTY -> #65 - [VM-LINUX] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #42 -> CONFIG ================================= Android Info: Vendor = OPPO CPU ABI = arm64-v8a Android Version = 8.1.0 Security Patch = 2020-07-05 Android Info: Brand = OPPO Device = CPH1803 Model = CPH1803 Product = CPH1803 Firm Version = CPH1803EX_11_A.29 Inc. Version = 1594315643 Firm Date = Fri Jul 10 01:27:23 CST 2020 OPPO Name = OPPO A3s Android Info: Platform = msm8953 Scanner Thread Terminated Elapsed: 00:00:16:375 Found 73 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2041 mV CMD Active Level: 3104 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Operation Done: [Init Engine], Elapsed: 00:00:02:273 Error Reading Sector: 0, Count: 1, Err: -4/R_DATA_CRC_ERR Try Again #1 Universal Wipe User Data v1.0 Wiping MISC Partition.. Partition #40 is '/MISC'. Erasing.. Wipe Mode: Oppo/Vivo Factory Reset Wipe 'MISC' Partition Done.. Wiping PARA Partition.. Partition PARA Not Found. Skip.. Done Wiping Data.. Elapsed Time: [00:00:00:077] Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:090 |
10-07-2020, 05:47 | #222 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Oppo a1k Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2000 mV Box S/N: ,FW Ver.: 02.53 CMD Pullup Level:1934 mV CMD Active Level:2004 mV Box IO Level:2000 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2000 mV Box S/N: , ,FW Ver.: 02.53 CMD Pullup Level:1933 mV CMD Active Level:2004 mV Box IO Level:2000 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 99A6985582C3A1F2, ,FW Ver.: 02.53 CMD Pullup Level:2114 mV CMD Active Level:2469 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514436334D4203EC6E9A20A67B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2019 Rev.0x3 eMMC NAME: QD63MB , S/N: 3966671392 eMMC NAME (HEX): 514436334D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1784 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x01A0800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01BB800000 (22.132GB) , formatting... Done. Done. Done. |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
10-09-2020, 15:05 | #223 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | OPPO A3S Password Remove DOne Code: Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 99A6985582xxxxxx, ,FW Ver.: 02.53 CMD Pullup Level:2130 mV CMD Active Level:2681 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206DCA006AAB5CB eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 3701474986 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 71564 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_3701474986_20201009_1541.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Detected 64 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0x2485fbe00] Size: 9.129GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-08-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20200725.032959 release-keys Backup saved: BuildProp_20201009_1541.txt --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: A6C88693 B25B6866 B9FB9957 FA81F27B 65A41DFA B6957109 19E9E322 0E78DE1B ¦È†“²[hf¹û.Wú.ò{e¤.ú¶•q .éã".xÞ.; 9E7BA771 0F09FD0C 655CA8F7 C255CA78 22F77027 44FDCEB0 CBFB0362 8E972E3F ž{§q. ý.e\¨÷ÂUÊx"÷p'DýΰËû.bŽ—.?; 304D6E00 81F78D86 69B57709 F97E1EB4 90D9E908 761A423E 5A0D61A0 4C68C277 0Mn..÷.†iµw ù~.´.Ùé.v.B>Z.a LhÂw; 7CCC92D6 81DDD77F 2939BE84 07D1B0F4 6A06788C 06AA7114 BA718B37 4EA815FD |Ì’Ö.Ý×.)9¾„.Ñ°ôj.xŒ.ªq.ºq‹7N¨.ý; 3A26F510 E02124F9 257D3E1A 44FBB764 222F7913 CFF270E6 FC7E707B FF1102CD :&õ.à!$ù%}>.Dû·d"/y.Ïòpæü~p{ÿ..Í; 6D7DC08D F3D466AA 94BF29AF 3947754F 56B2A424 4E88B768 28EF9CAD 5453A03F m}À.óÔfª”¿)¯9GuOV²¤$N.·h(ïœ*TS ?; D322ADE3 620DB1A9 565072F8 F1D0DBEA 14B50750 FCD00AD2 61CDACA1 13DEE782 Ó"*ãb.±©VPrøñÐÛê.µ.PüÐ.Òaͬ¡.Þç‚; 9C809151 CE9A80A6 095A8EB4 4DD5BA01 63828628 291EE453 F1725D63 F998C35F œ.‘QΚ.¦ ZŽ´MÕº.c‚†().äSñr]cù.Ã_; Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 99A6985582xxxxx, ,FW Ver.: 02.53 CMD Pullup Level:2128 mV CMD Active Level:2680 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206DCA006AAB5CB eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 3701474986 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 71564 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
10-16-2020, 15:37 | #225 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | oppo a9 cph1938 password and frp successfully done Code: 3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0D0D080A63B23413, ,FW Ver.: 01.63 CMD Pullup Level:2175 mV CMD Active Level:3073 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E53304A394B39101100D55F664E eMMC CSD : D05F01328F5913FFFFFFFFEF964000A8 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2019 Rev.0x10 eMMC NAME: S0J9K9 , S/N: 285267295 eMMC NAME (HEX): 53304A394B39 EMMC ROM1 (Main User Data) Capacity: 119280 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 4084 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: S0J9K9_ 285267295_20201016_1434.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F8000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F7FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244285406 Partition info successfully found ------ Detected 44 partitions ------ P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x4000000] Size: 64.0MB P2 (PARA) [0x4108000 0x80000] Size: 512.0KB P3 (OPPORESERVE1) [0x4188000 0x800000] Size: 8.0MB P4 (OPPORESERVE2) [0x4988000 0x4000000] Size: 64.0MB P5 (OPPORESERVE3) [0x8988000 0x4000000] Size: 64.0MB P6 (OPPO_CUSTOM) [0xc988000 0x100000] Size: 1.0MB P7 (EXPDB) [0xca88000 0x1400000] Size: 20.0MB P8 (FRP) [0xde88000 0x100000] Size: 1.0MB P9 (NVCFG) [0xdf88000 0x2000000] Size: 32.0MB P10 (NVDATA) [0xff88000 0x4000000] Size: 64.0MB P11 (METADATA) [0x13f88000 0x2000000] Size: 32.0MB P12 (PROTECT1) [0x15f88000 0x800000] Size: 8.0MB P13 (PROTECT2) [0x16788000 0x878000] Size: 8.468MB P14 (SECCFG) [0x17000000 0x800000] Size: 8.0MB P15 (PERSIST) [0x17800000 0x3000000] Size: 48.0MB P16 (SEC1) [0x1a800000 0x200000] Size: 2.0MB P17 (PROINFO) [0x1aa00000 0x300000] Size: 3.0MB P18 (MD1IMG) [0x1ad00000 0x6400000] Size: 100.0MB P19 (SPMFW) [0x21100000 0x100000] Size: 1.0MB P20 (SCP1) [0x21200000 0x600000] Size: 6.0MB P21 (SCP2) [0x21800000 0x600000] Size: 6.0MB P22 (SSPM_1) [0x21e00000 0x100000] Size: 1.0MB P23 (SSPM_2) [0x21f00000 0x100000] Size: 1.0MB P24 (CAM_VPU1) [0x22000000 0xf00000] Size: 15.0MB P25 (CAM_VPU2) [0x22f00000 0xf00000] Size: 15.0MB P26 (CAM_VPU3) [0x23e00000 0xf00000] Size: 15.0MB P27 (GZ1) [0x24d00000 0x1000000] Size: 16.0MB P28 (GZ2) [0x25d00000 0x1000000] Size: 16.0MB P29 (NVRAM) [0x26d00000 0x4000000] Size: 64.0MB P30 (LK) [0x2ad00000 0x500000] Size: 5.0MB P31 (LK2) [0x2b200000 0x500000] Size: 5.0MB P32 (BOOT) [0x2b700000 0x2000000] Size: 32.0MB P33 (LOGO) [0x2d700000 0x1000000] Size: 16.0MB P34 (DTBO) [0x2e700000 0x1000000] Size: 16.0MB P35 (TEE1) [0x2f700000 0x500000] Size: 5.0MB P36 (TEE2) [0x2fc00000 0xc00000] Size: 12.0MB P37 (ODM) [0x30800000 0x10000000] Size: 256.0MB P38 (VENDOR) [0x40800000 0x43000000] Size: 1.46GB P39 (SYSTEM) [0x83800000 0x14d000000] Size: 5.203GB P40 (CACHE) [0x1d0800000 0x1b000000] Size: 432.0MB P41 (USERDATA) [0x1eb800000 0x1b2fcfbe00] Size: 108.746GB P42 (OTP) [0x1d1b4fbe00 0x2b00000] Size: 43.0MB P43 (FLASHINFO) [0x1d1dffbe00 0x1000000] Size: 16.0MB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0083800000 (5.203GB) Short EXT fs info: Size: 5.120GB Block size: 4.0KB Inode size: 256 Inodes: 335872 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01EB800000 (108.746GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. CMD Active Level:3073 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E53304A394B39101100D55F664E eMMC CSD : D05F01328F5913FFFFFFFFEF964000A8 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2019 Rev.0x10 eMMC NAME: S0J9K9 , S/N: 285267295 eMMC NAME (HEX): 53304A394B39 EMMC ROM1 (Main User Data) Capacity: 119280 MB , 0xE8F8000 pages , 0x1D1F000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 4094 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F8000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F7FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244285406 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000DE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x01D0800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01EB800000 (108.746GB) , formatting... Done. Done. Done. |
The Following User Says Thank You to Sudan-Mobiles For This Useful Post: |
