04-03-2017, 13:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | Pls give me a favour Can I use this to repair dead boot phone? And how to do. Thanks Code: Checking NAND Image : E:\Mobosoft\Thiet bi\EASY-JTAG\Files\Xperia\E6553_Z4\dump z3+\EMMC_ROM1_BGND3R_1931370333_00000000_100000000.bin File successefuly loaded! Checking NAND Image : E:\Mobosoft\Thiet bi\EASY-JTAG\Files\Xperia\E6553_Z4\dump z3+\EMMC_ROM1_BGND3R_1931370333_00000000_100000000.bin Searching for MBR/EFI Partition Data... Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Loading Partitions List... Setting Metadata 0 length are 100 Checking EFI Table CRC fields. Warning! Main and backup partition tables differ! Use the 'c' and 'e' options on the recovery & transformation menu to examine the two tables. Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: APM: not present GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk verification and recovery are STRONGLY recommended. Real (Hardware) Disk/Image size : 7FFFFF sectors 4.0 GiB Soft (Partitioned) Disk/Image size : 3A3DFBC sectors 29.1 GiB Logical sector size: 200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Partition table holds up to 43 First usable sector is 34 Last usable sector is 61071326 Partitions will be aligned on 8 -sector boundaries Data partitions (firmware parts) count is 43 (dec) Meta partitions (partitions storing partition table) count is 1 (dec) Block size is 200 Partitions list is successefuly loaded! |
The Following 2 Users Say Thank You to ..::Thanh_gsm::.. For This Useful Post: |
