04-06-2017, 17:05 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: <INDIA> % <CHINA>
Member: 1359320 Status: Offline Sonork: 100.1620477 Thanks Meter: 79 | plz help LG D380 Write fail Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0600D0143142E13D, ,FW Ver.: 01.58 CMD Pullup Level:3042 mV CMD Active Level:3186 mV Box IO Level:3300 mV CLK Rate:1000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040501A13B2A611A EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 06/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27343658 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 27343658_20170406_2014.extcsd ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x01] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x03] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[127]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[126]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[125]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[124]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[123]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[122]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[121]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[120]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[119]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[118]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[117]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[116]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[115]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[114]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[113]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[112]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[111]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[110]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[109]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[108]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[107]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[106]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[105]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[104]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[103]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[102]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[101]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[100]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[99]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[98]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[97]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[96]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[95]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[94]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[93]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[92]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[91]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[90]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[89]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[88]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[87]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[86]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[85]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[84]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[83]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[82]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[81]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[80]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[79]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[78]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[77]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[76]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[75]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[74]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[73]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[72]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[71]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[70]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[69]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[68]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[67]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[66]]: 0x37 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[65]]: 0xff Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[64]]: 0xff Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Context configuration [CONTEXT_CONF[51]]: 0x00 Context configuration [CONTEXT_CONF[50]]: 0x00 Context configuration [CONTEXT_CONF[49]]: 0x00 Context configuration [CONTEXT_CONF[48]]: 0x00 Context configuration [CONTEXT_CONF[47]]: 0x00 Context configuration [CONTEXT_CONF[46]]: 0x00 Context configuration [CONTEXT_CONF[45]]: 0x00 Context configuration [CONTEXT_CONF[44]]: 0x00 Context configuration [CONTEXT_CONF[43]]: 0x00 Context configuration [CONTEXT_CONF[42]]: 0x00 Context configuration [CONTEXT_CONF[41]]: 0x00 Context configuration [CONTEXT_CONF[40]]: 0x00 Context configuration [CONTEXT_CONF[39]]: 0x00 Context configuration [CONTEXT_CONF[38]]: 0x00 Context configuration [CONTEXT_CONF[37]]: 0x00 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Searching for partition tables... Partitioning not detected... Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:3042 mV CMD Active Level:3186 mV Box IO Level:3300 mV CLK Rate:1000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:3042 mV CMD Active Level:3186 mV Input file : C:\Users\Smarttel\Desktop\EMMC_ROM1_H4G1d_27359057 _00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:3042 mV CMD Active Level:3186 mV Input file : C:\Users\Smarttel\Desktop\EMMC_ROM2_H4G1d_27359057 _00000000_00400000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) |
04-07-2017, 17:19 | #2 (permalink) |
Member: 1359320 Status: Offline Sonork: 100.1620477 Thanks Meter: 79 | HOW TO REPAIR THIS ERROR ALLREADY FLASHED BY KDZ FILE BY EAZYJTAG PLUS HiPower mode is OFF CMD Pullup Level: 2103 mV CMD Active Level: 3062 mV EMMC Device Information : EMMC CID: 90014A4834473164040501A13B2A611A EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 01A13B2A , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G1d_01A13B2A_20170407_214823.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is not found Searching MBR ... MBR header is not found Partition table not found |
04-07-2017, 18:07 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
04-16-2017, 21:16 | #8 (permalink) |
Insane Poster Join Date: Aug 2013 Location: west java indonesia Age: 41
Member: 2009275 Status: Offline Sonork: 100.1646190 Thanks Meter: 24 | that D320 Hynix emmc have a probblem with write protection. not like samsung emmc, hynix can not remove write protection. u should change emmc with kmkjs/kmk5u if that hynix emmc work fine, write verify will be no error. |
