11-01-2016, 08:35 | #496 (permalink) |
Major Poster Join Date: Apr 2011 Location: Kerala,DRC
Member: 1549945 Status: Offline Thanks Meter: 2 | Gt-s7562 samsung log and restarting issue fixed Loading repair file: 'D:\Samsung\GT-S7270\Samsung GT-S7562_EFS_V1.00.rcp' Repair File ver. : Easy Repair for Mfg: Samsung Model: GT-S7562, Ver.: 1.01 Repair file options. : NONE Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.4.1.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: Samsung GT-S7562 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N: 1212FE15A40537EF ,FW Ver.: 01.55 Connecting to Target... JTAG device: MSM7225A CPU IDCODE : 0x106230E1 Mfg.: 0x070, Part: 0x0623, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: MSM7227A Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x01000015 Name : JJS00A Size : 3.6 G , (7634944) Blocks EMMC #1 : ID : 0x01000015 Name : JJS00A Size : 1.0 M , (2048) Blocks eMMC flash device(s) found, Device ID : 0x00150000 NAND Writing MODEM... eMMC Write OK! Elapsed time: 328.832977s (62.281 KiB/s) NAND Writing MODEM_ST1... eMMC Write OK! Elapsed time: 49.795288s (61.693 KiB/s) NAND Writing MODEM_ST2... eMMC Write OK! Elapsed time: 50.044888s (61.385 KiB/s) All Done. |
11-01-2016, 09:17 | #497 (permalink) | |
Freak Poster Join Date: May 2011 Location: blitar indonesia
Member: 1580119 Status: Offline Sonork: baby Thanks Meter: 7 | Quote:
i have some problem in easyjtag emmc plus v 1.0.0.37 Last edited by samadyo; 11-01-2016 at 09:23. | |
11-01-2016, 23:29 | #498 (permalink) | |
Crazy Poster Join Date: May 2004 Location: HU
Member: 65657 Status: Offline Thanks Meter: 6 | Quote:
Thanks Tybee | |
11-05-2016, 14:23 | #499 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | samsung i9300 emmc repair done Z3X EasyJtag Software ver. 2.4.1.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55 CMD Pullup Level:752 mV CMD Active Level:2145 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1027180166_20161105_1350.extcsd Done. Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2145 mV Input file : E:\9300\EMMC_ROM2_00000000_00200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1292 kB/s Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2145 mV Input file : E:\9300\EMMC_ROM1_00000000_20000000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 6977 kB/s Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2145 mV Box IO Level:3300 mV CLK Rate:21000 khz Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2145 mV Box IO Level:3300 mV CLK Rate:21000 khz Writing eMMC Register... Written: REG : 177 VAL :1 Done. Z3X EasyJtag Software ver. 2.4.1.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55 CMD Pullup Level:763 mV CMD Active Level:2423 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1027180166_20161105_1353.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (PARAM) Range: [0X2000000,0X27FFE00] ,Len: 800000 MMCBLK0P4 (BOOT) Range: [0X2800000,0X2FFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X3000000,0X37FFE00] ,Len: 800000 MMCBLK0P6 (RADIO) Range: [0X3800000,0X57FFE00] ,Len: 2000000 MMCBLK0P7 (CACHE) Range: [0X5800000,0X457FFE00] ,Len: 40000000 MMCBLK0P8 (SYSTEM) Range: [0X45800000,0XA57FFE00] ,Len: 60000000 MMCBLK0P9 (HIDDEN) Range: [0XA5800000,0XC87FFE00] ,Len: 23000000 MMCBLK0P10 (OTA) Range: [0XC8800000,0XC8FFFE00] ,Len: 800000 MMCBLK0P11 (USERDATA) Range: [0XC9000000,0X3AAFFFE00] ,Len: 2E2000000 Done...Presets has been updated... Done. |
The Following User Says Thank You to umarmsn For This Useful Post: |
11-19-2016, 09:15 | #500 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Online Thanks Meter: 28 | HTC M8S 0PKV10000 M8QL_UL Hardly corrupted EMMC,Qualcomm 9008 in device manager only Revived with dump from another one. But problem now is locked to same operator (like dump donor) and no unlock code from operator,and HTC codes doesn't work on that operator. Will be useful dump from unlocked phone. Log from reading working phone. Code: Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: ............, ,FW Ver.: 01.55 CMD Pullup Level:2062 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 150100523832314D4200CD1A56B7C16A EMMC CSD : D02701320F5903FFF6DBFFEF92404008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2014 Rev.0x0 EMMC NAME: R821MB , S/N: 3441055415 EMMC NAME (HEX): 523832314D4200 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: R821MB_3441055415_20161103_2251.extcsd ============================================= Extended CSD rev 1.7 (MMC 5.0) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x04] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d1f000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x04 Enable background operations handshake [BKOPS_EN]: 0x01 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x00026d Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[127]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[126]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[125]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[124]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[123]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[122]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[121]]: 0x21 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[120]]: 0x19 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[119]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[118]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[117]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[116]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[115]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[114]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[113]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[112]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[111]]: 0x1d Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[110]]: 0x7d Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[109]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[108]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[107]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[106]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[105]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[104]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[103]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[102]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[101]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[100]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[99]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[98]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[97]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[96]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[95]]: 0x14 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[94]]: 0x14 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[93]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[92]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[91]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[90]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[89]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[88]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[87]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[86]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[85]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[84]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[83]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[82]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[81]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[80]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[79]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[78]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[77]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[76]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[75]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[74]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[73]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[72]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[71]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[70]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[69]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[68]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[67]]: 0x01 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[66]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[65]]: 0x00 Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[64]]: 0x1f Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Context configuration [CONTEXT_CONF[51]]: 0x00 Context configuration [CONTEXT_CONF[50]]: 0x00 Context configuration [CONTEXT_CONF[49]]: 0x00 Context configuration [CONTEXT_CONF[48]]: 0x00 Context configuration [CONTEXT_CONF[47]]: 0x00 Context configuration [CONTEXT_CONF[46]]: 0x00 Context configuration [CONTEXT_CONF[45]]: 0x00 Context configuration [CONTEXT_CONF[44]]: 0x00 Context configuration [CONTEXT_CONF[43]]: 0x00 Context configuration [CONTEXT_CONF[42]]: 0x00 Context configuration [CONTEXT_CONF[41]]: 0x00 Context configuration [CONTEXT_CONF[40]]: 0x00 Context configuration [CONTEXT_CONF[39]]: 0x00 Context configuration [CONTEXT_CONF[38]]: 0x00 Context configuration [CONTEXT_CONF[37]]: 0x00 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 52 MMCBLK0P0 (BOARD_INFO) Range: [0X4400,0X8200] ,Len: 4000 MMCBLK0P1 (PG1FS) Range: [0X8400,0X408200] ,Len: 400000 MMCBLK0P2 (SBL1) Range: [0X408400,0X508200] ,Len: 100000 MMCBLK0P3 (RESERVE_1) Range: [0X508400,0XFFFE00] ,Len: AF7C00 MMCBLK0P4 (MFG) Range: [0X1000000,0X103FE00] ,Len: 40000 MMCBLK0P5 (PG2FS) Range: [0X1040000,0X27EFA00] ,Len: 17AFC00 MMCBLK0P6 (RPM) Range: [0X27EFC00,0X286FA00] ,Len: 80000 MMCBLK0P7 (TZ) Range: [0X286FC00,0X2A6FA00] ,Len: 200000 MMCBLK0P8 (HYP) Range: [0X2A6FC00,0X2C6FA00] ,Len: 200000 MMCBLK0P9 (HBOOT) Range: [0X2C6FC00,0X306FA00] ,Len: 400000 MMCBLK0P10 (TOOL_DIAG) Range: [0X306FC00,0X346FA00] ,Len: 400000 MMCBLK0P11 (SP1) Range: [0X346FC00,0X396FA00] ,Len: 500000 MMCBLK0P12 (DDR) Range: [0X396FC00,0X3977A00] ,Len: 8000 MMCBLK0P13 (WCNSS) Range: [0X3977C00,0X3E77A00] ,Len: 500000 MMCBLK0P14 (RFG_0) Range: [0X3E77C00,0X3F77A00] ,Len: 100000 MMCBLK0P15 (RFG_1) Range: [0X3F77C00,0X4077A00] ,Len: 100000 MMCBLK0P16 (RFG_2) Range: [0X4077C00,0X4177A00] ,Len: 100000 MMCBLK0P17 (RFG_3) Range: [0X4177C00,0X4277A00] ,Len: 100000 MMCBLK0P18 (RFG_4) Range: [0X4277C00,0X4377A00] ,Len: 100000 MMCBLK0P19 (RFG_5) Range: [0X4377C00,0X4477A00] ,Len: 100000 MMCBLK0P20 (RFG_6) Range: [0X4477C00,0X4577A00] ,Len: 100000 MMCBLK0P21 (RFG_7) Range: [0X4577C00,0X4677A00] ,Len: 100000 MMCBLK0P22 (FSG) Range: [0X4677C00,0X47F7A00] ,Len: 180000 MMCBLK0P23 (RADIO) Range: [0X47F7C00,0X82F7E00] ,Len: 3B00400 MMCBLK0P24 (RESERVE_2) Range: [0X82F8000,0X8FFFE00] ,Len: D08000 MMCBLK0P25 (MISC) Range: [0X9000000,0X90FFE00] ,Len: 100000 MMCBLK0P26 (MODEM_ST1) Range: [0X9100000,0X927FE00] ,Len: 180000 MMCBLK0P27 (MODEM_ST2) Range: [0X9280000,0X93FFE00] ,Len: 180000 MMCBLK0P28 (FATALDEVLOG) Range: [0X9400000,0XA7FFE00] ,Len: 1400000 MMCBLK0P29 (DEVLOG) Range: [0XA800000,0XC5FFE00] ,Len: 1E00000 MMCBLK0P30 (PDATA) Range: [0XC600000,0XC63FE00] ,Len: 40000 MMCBLK0P31 (CONTROL) Range: [0XC640000,0XC643E00] ,Len: 4000 MMCBLK0P32 (LOCAL) Range: [0XC644000,0XC784200] ,Len: 140400 MMCBLK0P33 (EXTRA) Range: [0XC784400,0XC794200] ,Len: 10000 MMCBLK0P34 (CDMA_RECORD) Range: [0XC794400,0XC894200] ,Len: 100000 MMCBLK0P35 (FSC) Range: [0XC894400,0XC894600] ,Len: 400 MMCBLK0P36 (SSD) Range: [0XC894800,0XC896600] ,Len: 2000 MMCBLK0P37 (SENSOR_HUB) Range: [0XC896800,0XC916600] ,Len: 80000 MMCBLK0P38 (BACKUP_HBOOT) Range: [0XC916800,0XCE16600] ,Len: 500000 MMCBLK0P39 (FRP) Range: [0XCE16800,0XCE93600] ,Len: 7D000 MMCBLK0P40 (RESERVE) Range: [0XCE93800,0XCFFFE00] ,Len: 16C800 MMCBLK0P41 (CACHE) Range: [0XD000000,0X1CFFFE00] ,Len: 10000000 MMCBLK0P42 (BOOT) Range: [0X1D000000,0X1EFFFE00] ,Len: 2000000 MMCBLK0P43 (RECOVERY) Range: [0X1F000000,0X20FFFE00] ,Len: 2000000 MMCBLK0P44 (SYSTEM) Range: [0X21000000,0X120FFFE00] ,Len: 100000000 MMCBLK0P45 (CARRIER) Range: [0X121000000,0X1228FFE00] ,Len: 1900000 MMCBLK0P46 (BATTERY) Range: [0X122900000,0X1232FFE00] ,Len: A00000 MMCBLK0P47 (APPPRELOAD) Range: [0X123300000,0X1363FFE00] ,Len: 13100000 MMCBLK0P48 (COTA) Range: [0X136400000,0X139FFFE00] ,Len: 3C00000 MMCBLK0P49 (USERDATA) Range: [0X13A000000,0X3A1FFFE00] ,Len: 268000000 MMCBLK0P50 (ABSOLUTE) Range: [0X3A2000000,0X3A2FFFE00] ,Len: 1000000 Done...Presets has been updated... Done. Z3X EasyJtag Software ver. 2.4.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2062 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:7000 khz Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :E:\GSM\Z3X\Downloads\HTC_OneM8S\EMMC_ROM1_R821MB_3441055415_00000000_20000000.bin Done. Read Speed: 730 kB/s |
The Following User Says Thank You to gabiz_ro For This Useful Post: |
11-19-2016, 12:05 | #501 (permalink) |
Freak Poster Join Date: Sep 2005 Location: EMMC JTAG Age: 44
Member: 180874 Status: Offline Thanks Meter: 20 | Sm-t525 file need urgently!! IM FACING A PROBLEM THAT I AFTER CHANGED SAMSUNG SM-T525 EMMC FILE ,SO I NEED 4 FILES TO SOLVE MY PROBLEM SM-T525 BOOT 1, SM-T525 BOOT 2, SM-T525 EXTCSD , SM-T525 USERAREA FILE . ANY MASTER CAN HELP ME?? |
12-06-2016, 09:38 | #502 (permalink) |
Insane Poster Join Date: Sep 2011 Location: rusia
Member: 1656416 Status: Offline Thanks Meter: 23 | Philips w6610 repair sucess Directly eMMC. Replacement, format, resize, write. Code: eMMC_tool Suite ver. 1.0.0.40 Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.23403) Looking for EasyJTAG box... EasyJTAG API ver. 2007 Setting IO Levels to 3.3V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = xxxxxxxxxxxxxx Card Serial = xxxxxxxxxxxxxx EasyJTAG Box Firmware = 01.56 HiPower mode is OFF CMD Pullup Level: 3176 mV CMD Active Level: 3258 mV EMMC Device Information : EMMC CID: 1501004B4A5330304D036C1A3FBDBF48 EMMC CSD: D02701320F5903FFF6DBFFE78A404056 EMMC Manufacture Name: SAMSUNG EMMC NAME: KJS00M , S/N: 6C1A3FBD , rev. 03 EMMC NAME (HEX): 4B4A5330304D EMMC ROM 1 (Main User Data) Capacity: 3716 MB (0000E8400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: KJS00M_6C1A3FBD_20161205_173054.extcsd EMMC Init completed. Opening file: MT6582_Android_scatter.txt The new format of scatter config_version: V1.1.1 platform: MT6582 preloader_sangfei82_we_jb5.bin Found 2 supported eMMC CID: name = 'SEM04G' hex = 0x53454D303447 [SANDISK] name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] The size of the last section has been updated HiPower mode is OFF CMD Pullup Level: 3186 mV CMD Active Level: 3258 mV EMMC Device Information : EMMC CID: 1501004B4A5330304D036C1A3FBDBF48 EMMC CSD: D02701320F5903FFF6DBFFE78A404056 EMMC Manufacture Name: SAMSUNG EMMC NAME: KJS00M , S/N: 6C1A3FBD , rev. 03 EMMC NAME (HEX): 4B4A5330304D EMMC ROM 1 (Main User Data) Capacity: 3716 MB (0000E8400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: KJS00M_6C1A3FBD_20161205_173104.extcsd EMMC Init completed. Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! HiPower mode is OFF CMD Pullup Level: 3186 mV CMD Active Level: 3258 mV EMMC Device Information : EMMC CID: 45010053454D30344D036C1A3FBDB1F2 EMMC CSD: D02701320F5903FFF6DBFFE78A404056 EMMC Manufacture Name: SANDISK EMMC NAME: SEM04M , S/N: 6C1A3FBD , rev. 03 EMMC NAME (HEX): 53454D30344D EMMC ROM 1 (Main User Data) Capacity: 3716 MB (0000E8400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: SEM04M_6C1A3FBD_20161205_173126.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 3176 mV CMD Active Level: 3269 mV EMMC Device Information : EMMC CID: 45010053454D30344D036C1A3FBDB1F2 EMMC CSD: D02701320F5903FFF6DBFFE78A404056 EMMC Manufacture Name: SANDISK EMMC NAME: SEM04M , S/N: 6C1A3FBD , rev. 03 EMMC NAME (HEX): 53454D30344D EMMC ROM 1 (Main User Data) Capacity: 3716 MB (0000E8400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: SEM04M_6C1A3FBD_20161205_173145.extcsd EMMC Init completed. Partition name: PRELOADER Filename: preloader_sangfei82_we_jb5.bin , Offset: 000000000000 , filesize: 113816 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 133,01 Kb/s Partition name: MBR Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 46,84 Kb/s Partition name: EBR1 Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 37,50 Kb/s Partition name: UBOOT Filename: lk.bin , Offset: 000002920000 , filesize: 267448 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 718,95 Kb/s Partition name: BOOTIMG Filename: boot.img , Offset: 000002980000 , filesize: 4661248 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 929,56 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000002F80000 , filesize: 5181440 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 934,93 Kb/s Partition name: SEC_RO Filename: secro.img , Offset: 000003580000 , filesize: 135168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1230,86 Kb/s Partition name: LOGO Filename: logo.bin , Offset: 000003C00000 , filesize: 273091 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 769,94 Kb/s Partition name: EBR2 Filename: EBR2 , Offset: 000003F00000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 97,10 Kb/s Partition name: ANDROID Filename: system.img , Offset: 000004980000 , filesize: 590226632 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1465 Done writing partition. Write speed: 867,12 Kb/s Partition name: CACHE Filename: cache.img , Offset: 000030580000 , filesize: 6316180 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 1510,85 Kb/s Partition name: USRDATA Filename: userdata.img , Offset: 000038380000 , filesize: 56480276 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 42 Done writing partition. Write speed: 1052,71 Kb/s Writing DL_Info... Writing DL_Info done Writing eMMC Register ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x48 All done |
12-21-2016, 13:51 | #505 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Samsung Galaxy S Duos 2 S7582 Boot Repair Done |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
01-10-2017, 07:08 | #506 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | n7100 dead emmc repair successfully Code: Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:1144 mV CMD Active Level:1577 mV Can't init device, Reason: CMD CRC Error Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:2650 mV CMD Active Level:2743 mV Can't init device, Reason: CMD CRC Error Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:2640 mV CMD Active Level:2732 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: <b>000000</b> , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 000000_ 537986854_20170109_1821.extcsd Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3135 mV CMD Active Level:3238 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: <b>000000</b> , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 000000_ 537986854_20170109_1822.extcsd Searching for partition tables... Partitioning not detected... Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3145 mV CMD Active Level:3238 mV Setup firmware update mode, wait 2..30 sec... Can't setup firmware normal update mode, Reason: CARD Status Error Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3145 mV CMD Active Level:3217 mV Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3145 mV CMD Active Level:3227 mV Can't init device, Reason: CMD CRC Error Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:2640 mV CMD Active Level:2732 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: <b>000000</b> , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 000000_ 537986854_20170109_1823.extcsd Searching for partition tables... Partitioning not detected... Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3135 mV CMD Active Level:3217 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! <font color="green">eMMC firmware is updated now! </font> <font color="green">Please reconnect all eMMC lines before next operation!</font> <font color="green">Please don't forget to repair <b>extCSD</b> from backup!</font> <font color="green">Please don't forget to configure <b>BOOT</b> sizes!</font> Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:3135 mV CMD Active Level:3217 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it! <font color="red">Please don't forget to repair extCSD from backup!</font> Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:3135 mV CMD Active Level:3217 mV EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! <font color="red">Please don't forget to repair extCSD from backup!</font> Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:3135 mV CMD Active Level:3217 mV Writing... Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3145 mV CMD Active Level:3238 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: <b>VTU000</b> , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU000_ 538150534_20170109_1825.extcsd Searching for partition tables... Partitioning not detected... Done. Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:3145 mV CMD Active Level:3238 mV Input file : D:\beckup old laptop data\n7100 tested hanif\N7100 BOOT1.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1256 kB/s Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:3145 mV CMD Active Level:3238 mV Input file : D:\beckup old laptop data\n7100 tested hanif\N7100 USERAREA.bin Writing 0001000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1321 kB/s Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3135 mV CMD Active Level:3227 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: <b>VTU000</b> , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU000_ 538150534_20170109_1826.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (M9KEFS1) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P4 (M9KEFS2) Range: [0X2400000,0X27FFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS3) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P6 (PARAM) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P7 (BOOT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P8 (RECOVERY) Range: [0X3C00000,0X43FFE00] ,Len: 800000 MMCBLK0P9 (RADIO) Range: [0X4400000,0X9BFFE00] ,Len: 5800000 MMCBLK0P10 (TOMBSTONES) Range: [0X9C00000,0X9FFFE00] ,Len: 400000 MMCBLK0P11 (CACHE) Range: [0XA000000,0X5F7FFE00] ,Len: 55800000 MMCBLK0P12 (SYSTEM) Range: [0X5F800000,0XDF7FFE00] ,Len: 80000000 MMCBLK0P13 (HIDDEN) Range: [0XDF800000,0X1027FFE00] ,Len: 23000000 MMCBLK0P14 (OTA) Range: [0X102800000,0X102FFFE00] ,Len: 800000 MMCBLK0P15 (USERDATA) Range: [0X103000000,0X3AAFFFE00] ,Len: 2A8000000 Done...Presets has been updated... Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:3135 mV CMD Active Level:3227 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: <b>VTU000</b> , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU000_ 538150534_20170109_1826.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (M9KEFS1) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P4 (M9KEFS2) Range: [0X2400000,0X27FFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS3) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P6 (PARAM) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P7 (BOOT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P8 (RECOVERY) Range: [0X3C00000,0X43FFE00] ,Len: 800000 MMCBLK0P9 (RADIO) Range: [0X4400000,0X9BFFE00] ,Len: 5800000 MMCBLK0P10 (TOMBSTONES) Range: [0X9C00000,0X9FFFE00] ,Len: 400000 MMCBLK0P11 (CACHE) Range: [0XA000000,0X5F7FFE00] ,Len: 55800000 MMCBLK0P12 (SYSTEM) Range: [0X5F800000,0XDF7FFE00] ,Len: 80000000 MMCBLK0P13 (HIDDEN) Range: [0XDF800000,0X1027FFE00] ,Len: 23000000 MMCBLK0P14 (OTA) Range: [0X102800000,0X102FFFE00] ,Len: 800000 MMCBLK0P15 (USERDATA) Range: [0X103000000,0X3AAFFFE00] ,Len: 2A8000000 Done...Presets has been updated... Done. |
01-11-2017, 06:17 | #507 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Samsung Galaxy S Duos-2 Dead Boot Reapir Samsung Galaxy S Duos-2 Dead Boot Reapir(S-7582) Image |
The Following 5 Users Say Thank You to Deepesh Sharma For This Useful Post: |
02-01-2017, 20:34 | #508 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: CAIRO.EGYPT
Member: 1981679 Status: Offline Thanks Meter: 86 | Lg g3 d855 32g,3g emmc replaced and repaired by easy jtag 1-KNOW DAMAGED EMMC INFORMATION AND MAKE A BACKUP. 2-CHANGE EMMC BY DIGING CARFULLY. 3-CHOSE SUITABLE EMMC IC {I CHOSED Z2 EMMC IC}. 4-FLASH PHONE WHITH ANY ROM AFTER RESTORE THE BACKUP. https://drive.google.com/open?id=0Bw...lnSGp6VEExUklR https://drive.google.com/open?id=0Bw...RYcVFsZjZic2Nj https://drive.google.com/open?id=0Bw...lPMnE5ZGxzSzlR https://drive.google.com/open?id=0Bw...g4akl3X3hSS09R https://drive.google.com/open?id=0Bw...FiRlYwTFA3c0ZB https://drive.google.com/open?id=0Bw...25hWkdyeENyd1k https://drive.google.com/open?id=0Bw...kM0VmM5c3lseFk Quote:
02-08-2017, 14:43 | #509 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672131 Status: Offline Thanks Meter: 16 | Another n7100 emmc repair done Code: EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU00M_1027180166_20170208_1853.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (M9KEFS1) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P4 (M9KEFS2) Range: [0X2400000,0X27FFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS3) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P6 (PARAM) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P7 (BOOT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P8 (RECOVERY) Range: [0X3C00000,0X43FFE00] ,Len: 800000 MMCBLK0P9 (RADIO) Range: [0X4400000,0X9BFFE00] ,Len: 5800000 MMCBLK0P10 (TOMBSTONES) Range: [0X9C00000,0X9FFFE00] ,Len: 400000 MMCBLK0P11 (CACHE) Range: [0XA000000,0X5F7FFE00] ,Len: 55800000 MMCBLK0P12 (SYSTEM) Range: [0X5F800000,0XDF7FFE00] ,Len: 80000000 MMCBLK0P13 (HIDDEN) Range: [0XDF800000,0X1027FFE00] ,Len: 23000000 MMCBLK0P14 (OTA) Range: [0X102800000,0X102FFFE00] ,Len: 800000 MMCBLK0P15 (USERDATA) Range: [0X103000000,0X3AAFFFE00] ,Len: 2A8000000 Done...Presets has been updated... Done. Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1330 mV CMD Active Level:2681 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 12 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 2,3,1,2 Runtime bad blocks per bank : 3,3,1,5 Reserved blocks left per bank : 46,45,49,45 All Erase counts (min,avg,max): 1,18,1504 SLC Erase counts (min,avg,max): 3,209,1504 MLC Erase counts (min,avg,max): 1,8,25 S.M.A.R.T Report Done. Running:SAMSUNG: eMMC firmware update... EMMC NAME: VTU00M Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:1330 mV CMD Active Level:2670 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Running:SAMSUNG: eMMC firmware update... EMMC NAME: VTU000 Confirmed eMMC Part Number: KMVTU000LM-B503 Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:1320 mV CMD Active Level:2670 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:1340 mV CMD Active Level:2670 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU000_ 538150534_20170208_1857.extcsd Searching for partition tables... Partitioning not detected... Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1340 mV CMD Active Level:2670 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1340 mV CMD Active Level:2670 mV EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. extCSD file...D:\EMMC REPAIR\n7100 tested hanif\N7100 EXTCSD\N7100 EXTCSD.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1340 mV CMD Active Level:2670 mV Writing... Done. Checking NAND Image : D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin File successefuly loaded! Processing file...D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1340 mV CMD Active Level:2670 mV Input file : D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1268 kB/s Checking NAND Image : D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin File successefuly loaded! Processing file...D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1340 mV CMD Active Level:2670 mV Input file : D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin Writing 0001000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1272 kB/s Z3X EasyJtag Software ver. 2.0.6.6 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56 CMD Pullup Level:1330 mV CMD Active Level:2660 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU000_ 538150534_20170208_1859.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (M9KEFS1) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P4 (M9KEFS2) Range: [0X2400000,0X27FFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS3) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P6 (PARAM) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P7 (BOOT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P8 (RECOVERY) Range: [0X3C00000,0X43FFE00] ,Len: 800000 MMCBLK0P9 (RADIO) Range: [0X4400000,0X9BFFE00] ,Len: 5800000 MMCBLK0P10 (TOMBSTONES) Range: [0X9C00000,0X9FFFE00] ,Len: 400000 MMCBLK0P11 (CACHE) Range: [0XA000000,0X5F7FFE00] ,Len: 55800000 MMCBLK0P12 (SYSTEM) Range: [0X5F800000,0XDF7FFE00] ,Len: 80000000 MMCBLK0P13 (HIDDEN) Range: [0XDF800000,0X1027FFE00] ,Len: 23000000 MMCBLK0P14 (OTA) Range: [0X102800000,0X102FFFE00] ,Len: 800000 MMCBLK0P15 (USERDATA) Range: [0X103000000,0X3AAFFFE00] ,Len: 2A8000000 Done...Presets has been updated... Done. Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.6.6 Skip loading eMMC Addon Firmware CMD Pullup Level:1330 mV CMD Active Level:2660 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 6,6,2,6 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 45,45,49,45 All Erase counts (min,avg,max): 0,0,2 SLC Erase counts (min,avg,max): 0,0,2 MLC Erase counts (min,avg,max): 0,0,2 S.M.A.R.T Report Done. |
