Old 12-23-2017, 12:03   #586 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
htc 826x red blink done by easy
Z3X EasyJtag Software ver. 2.0.6.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.60
CMD Pullup Level:1691 mV
CMD Active Level:2237 mV
eMMC Device Information
EMMC CID : 90014A4841473265050759D88C6C4202
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 04/2015  Rev.0x7
EMMC NAME: <b>HAG2e </b> , S/N: 1507363948
EMMC NAME (HEX): 48414732652000
EMMC ROM1 (Main User Data)   Capacity: 15032 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
  Extended CSD rev 1.7 (MMC Unknown)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
Backup saved: HAG2e _1507363948_20171103_2215.extcsd
Searching for partition tables...
Detected GPT over MBR...
Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Warning: Entries Count = 52
MMCBLK0P0 (BOARD_INFO) Range:	[0X4400,0X8200] ,Len: 4000
MMCBLK0P1 (PG1FS) Range:	[0X8400,0X408200] ,Len: 400000
MMCBLK0P2 (SBL1) Range:	[0X408400,0X508200] ,Len: 100000
MMCBLK0P3 (RESERVE_1) Range:	[0X508400,0XFFFE00] ,Len: AF7C00
MMCBLK0P4 (MFG) Range:	[0X1000000,0X103FE00] ,Len: 40000
MMCBLK0P5 (PG2FS) Range:	[0X1040000,0X27EFA00] ,Len: 17AFC00
MMCBLK0P6 (RPM) Range:	[0X27EFC00,0X286FA00] ,Len: 80000
MMCBLK0P7 (TZ) Range:	[0X286FC00,0X2A6FA00] ,Len: 200000
MMCBLK0P8 (HYP) Range:	[0X2A6FC00,0X2C6FA00] ,Len: 200000
MMCBLK0P9 (HBOOT) Range:	[0X2C6FC00,0X306FA00] ,Len: 400000
MMCBLK0P10 (TOOL_DIAG) Range:	[0X306FC00,0X346FA00] ,Len: 400000
MMCBLK0P11 (SP1) Range:	[0X346FC00,0X396FA00] ,Len: 500000
MMCBLK0P12 (DDR) Range:	[0X396FC00,0X3977A00] ,Len: 8000
MMCBLK0P13 (WCNSS) Range:	[0X3977C00,0X3E77A00] ,Len: 500000
MMCBLK0P14 (RFG_0) Range:	[0X3E77C00,0X3F77A00] ,Len: 100000
MMCBLK0P15 (RFG_1) Range:	[0X3F77C00,0X4077A00] ,Len: 100000
MMCBLK0P16 (RFG_2) Range:	[0X4077C00,0X4177A00] ,Len: 100000
MMCBLK0P17 (RFG_3) Range:	[0X4177C00,0X4277A00] ,Len: 100000
MMCBLK0P18 (RFG_4) Range:	[0X4277C00,0X4377A00] ,Len: 100000
MMCBLK0P19 (RFG_5) Range:	[0X4377C00,0X4477A00] ,Len: 100000
MMCBLK0P20 (RFG_6) Range:	[0X4477C00,0X4577A00] ,Len: 100000
MMCBLK0P21 (RFG_7) Range:	[0X4577C00,0X4677A00] ,Len: 100000
MMCBLK0P22 (FSG) Range:	[0X4677C00,0X47F7A00] ,Len: 180000
MMCBLK0P23 (RADIO) Range:	[0X47F7C00,0X82F7E00] ,Len: 3B00400
MMCBLK0P24 (RESERVE_2) Range:	[0X82F8000,0X8FFFE00] ,Len: D08000
MMCBLK0P25 (MISC) Range:	[0X9000000,0X90FFE00] ,Len: 100000
MMCBLK0P26 (MODEM_ST1) Range:	[0X9100000,0X927FE00] ,Len: 180000
MMCBLK0P27 (MODEM_ST2) Range:	[0X9280000,0X93FFE00] ,Len: 180000
MMCBLK0P28 (FATALDEVLOG) Range:	[0X9400000,0XA7FFE00] ,Len: 1400000
MMCBLK0P29 (DEVLOG) Range:	[0XA800000,0XC5FFE00] ,Len: 1E00000
MMCBLK0P30 (PDATA) Range:	[0XC600000,0XC63FE00] ,Len: 40000
MMCBLK0P31 (CONTROL) Range:	[0XC640000,0XC643E00] ,Len: 4000
MMCBLK0P32 (LOCAL) Range:	[0XC644000,0XC784200] ,Len: 140400
MMCBLK0P33 (EXTRA) Range:	[0XC784400,0XC794200] ,Len: 10000
MMCBLK0P34 (CDMA_RECORD) Range:	[0XC794400,0XC894200] ,Len: 100000
MMCBLK0P35 (FSC) Range:	[0XC894400,0XC894600] ,Len: 400
MMCBLK0P36 (SSD) Range:	[0XC894800,0XC896600] ,Len: 2000
MMCBLK0P37 (SENSOR_HUB) Range:	[0XC896800,0XC8D6600] ,Len: 40000
MMCBLK0P38 (BACKUP_HBOOT) Range:	[0XC8D6800,0XCDD6600] ,Len: 500000
MMCBLK0P39 (FRP) Range:	[0XCDD6800,0XCE53600] ,Len: 7D000
MMCBLK0P40 (RESERVE) Range:	[0XCE53800,0XCFFFE00] ,Len: 1AC800
MMCBLK0P41 (CACHE) Range:	[0XD000000,0X1CFFFE00] ,Len: 10000000
MMCBLK0P42 (BOOT) Range:	[0X1D000000,0X1EFFFE00] ,Len: 2000000
MMCBLK0P43 (RECOVERY) Range:	[0X1F000000,0X20FFFE00] ,Len: 2000000
MMCBLK0P44 (SYSTEM) Range:	[0X21000000,0X120FFFE00] ,Len: 100000000
MMCBLK0P45 (USERDATA) Range:	[0X121000000,0X388FFFE00] ,Len: 268000000
MMCBLK0P46 (CARRIER) Range:	[0X389000000,0X38A8FFE00] ,Len: 1900000
MMCBLK0P47 (BATTERY) Range:	[0X38A900000,0X38B2FFE00] ,Len: A00000
MMCBLK0P48 (APPPRELOAD) Range:	[0X38B300000,0X39D4FFE00] ,Len: 12200000
MMCBLK0P49 (COTA) Range:	[0X39D500000,0X3A10FFE00] ,Len: 3C00000
Done...Presets has been updated...
Done.
Old 12-25-2017, 16:05   #587 (permalink)
Member: 2438408
Thanks Meter: 380
How to emmc repair step by step
Deepesh sharma please tell me emmc repair step by step
The Following User Says Thank You to alexid For This Useful Post:
Old 12-25-2017, 19:03   #588 (permalink)
Member: 2718787
thank you very much for all this detail
Old 12-29-2017, 13:58   #589 (permalink)
Member: 454060
Thanks Meter: 12
Originally Posted by NoName® View Post
Where is reports with EasyJTAG Plus Reports ? Guys!!! Come ON!!!
easy jtag plus all time error in windwos 10 why brother what is the problem !
and not opening and hanging up
Old 12-30-2017, 04:52   #590 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 345
Huwei Y530-U00 successfull Emmc Repair
Partition name: sbl1
Filename: sbl1.BIN , Offset: 000000004400 , filesize: 524288 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 461.73 KB/s
Partition name: sdi
Filename: sdi.BIN , Offset: 000000084400 , filesize: 32768 bytes
Done writing partition. Write speed: 455.60 KB/s
Partition name: DDR
Filename: DDR.BIN , Offset: 000000400000 , filesize: 32768 bytes
Done writing partition. Write speed: 462.96 KB/s
Partition name: rpm
Filename: rpm.BIN , Offset: 000000800000 , filesize: 512000 bytes
Done writing partition. Write speed: 751.55 KB/s
Partition name: tz
Filename: tz.BIN , Offset: 00000087D000 , filesize: 512000 bytes
Done writing partition. Write speed: 742.16 KB/s
Partition name: aboot
Filename: aboot.BIN , Offset: 0000008FA000 , filesize: 5726208 bytes
Done writing partition. Write speed: 729.74 KB/s
Partition name: pad
Filename: pad.BIN , Offset: 000000E70000 , filesize: 1048576 bytes
Done writing partition. Write speed: 747.42 KB/s
Partition name: oeminfo
Filename: oeminfo.BIN , Offset: 000000F70000 , filesize: 67108864 bytes
Done writing partition. Write speed: 682.68 KB/s
Partition name: modemst1
Filename: modemst1.BIN , Offset: 000004F70000 , filesize: 4194304 bytes
Done writing partition. Write speed: 754.40 KB/s
Partition name: modemst2
Filename: modemst2.BIN , Offset: 000005370000 , filesize: 4194304 bytes
Done writing partition. Write speed: 745.03 KB/s
Filename: modem.BIN , Offset: 000005800000 , filesize: 100663296 bytes
Done writing partition. Write speed: 730.38 KB/s
Partition name: fsg
Filename: fsg.BIN , Offset: 00000B800000 , filesize: 4194304 bytes
Done writing partition. Write speed: 739.02 KB/s
Partition name: fsc
Filename: fsc.BIN , Offset: 00000BC00000 , filesize: 1024 bytes
Done writing partition. Write speed: 29.30 KB/s
Partition name: ssd
Filename: ssd.BIN , Offset: 00000BC00400 , filesize: 8192 bytes
Done writing partition. Write speed: 194.55 KB/s
Partition name: log
Filename: log.BIN , Offset: 00000BC02400 , filesize: 33554432 bytes
Done writing partition. Write speed: 737.22 KB/s
Partition name: bkbootup
Filename: bkbootup.BIN , Offset: 00000E000000 , filesize: 67108864 bytes
Done writing partition. Write speed: 725.95 KB/s
Partition name: persist
Filename: persist.BIN , Offset: 000012000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 741.50 KB/s
Partition name: boot
Filename: boot.BIN , Offset: 000012800000 , filesize: 12582912 bytes
Done writing partition. Write speed: 747.07 KB/s
Partition name: recovery
Filename: recovery.BIN , Offset: 000013400000 , filesize: 16777216 bytes
Partition name: cust
Filename: cust.BIN , Offset: 000014400000 , filesize: 268435456 bytes
Done writing partition. Write speed: 737.09 KB/s
Partition name: cache
Filename: cache.BIN , Offset: 000024400000 , filesize: 201326592 bytes
Done writing partition. Write speed: 746.01 KB/s
Partition name: misc
Filename: misc.BIN , Offset: 000030400000 , filesize: 4194304 bytes
Done writing partition. Write speed: 752.08 KB/s
Partition name: system
Filename: system.BIN , Offset: 000030800000 , filesize: 1073741824 bytes
Error writing at address: 00006EE40000 , error: -8, DATA SND CRC Error ... Retry #1
Done writing partition. Write speed: 744.09 KB/s
Partition name: grow
Filename: grow.BIN , Offset: 0000B0800000 , filesize: 947895808 bytes
Done writing partition. Write speed: 739.46 KB/s
All done time: [01:08:41:621]
The Following User Says Thank You to GsmKotla For This Useful Post:
Old 12-30-2017, 06:52   #591 (permalink)
::SYED MOBILE::'s Avatar
Member: 1427732
Sonork: ˙·٠•●
Thanks Meter: 1,061
@ GsmKotla
fabulous & great job
Old 12-30-2017, 17:25   #592 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Samsung G532G boot repair done with Easy Jtag Plus
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 18 Mhz
CMD Pullup Level: 2093 mV
CMD Active Level: 2468 mV
EMMC Device Information :
EMMC CID: 90014A483847347592010FD7812C448B
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: 0FD7812C , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4u_0FD7812C_20171229_145712.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Done writing partition. Write speed: 540.58 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
Done writing partition. Write speed: 1967.97 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 27.48 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 1805.89 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 1946.25 KB/s
All done time: [00:00:15:448]
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 01-09-2018, 05:52   #593 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 345
S7560 successfull boot Repair done
onnecting to Target...
JTAG device: MSM7225A
CPU IDCODE : 0x106230E1 Mfg.: 0x070, Part: 0x0623, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: MSM7227A
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x01000015 Name : JJS00A Size : 3.6 G , (7634944) Blocks
EMMC #1 : ID : 0x01000015 Name : JJS00A Size : 1.0 M , (2048) Blocks
eMMC flash device(s) found, Device ID : 0x00150000
NAND Writing MBR, QCSBL...
eMMC Write OK! Elapsed time: 3.738213s (45.610 KiB/s)
NAND Writing MODEM...
eMMC Write OK! Elapsed time: 396.813690s (51.611 KiB/s)
NAND Writing EBR...
eMMC Write OK! Elapsed time: 33.713928s (116.436 KiB/s)
NAND Writing OEMSBL...
eMMC Write OK! Elapsed time: 14.290817s (69.975 KiB/s)
NAND Writing APPSBL...
eMMC Write OK! Elapsed time: 14.069805s (71.074 KiB/s)
NAND Writing PIT...
eMMC Write OK! Elapsed time: 4.479256s (114.305 KiB/s)
All Done.
Old 01-17-2018, 10:25   #594 (permalink)
Member: 2800645
I need help promoting my online store someone please help me. We sell everything to help you unlock, flash, debrand and service mobile phones.
We also supply the latest mobile phone accessories, phone parts, and repair tools too.
As well as our mobile phone unlocking, flashing and repair services, we offer a huge range of the latest phone forensics, unlocking, flashing, and service tools available to buy online !!
Old 01-22-2018, 13:51   #595 (permalink)
Member: 1791645
Sonork: 119.01.15.66
Thanks Meter: 44
I8160P boot repair done vie Eazy Jtag
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Loading repair file: 'E:\Прошивки\EasyJTAG\Samsung\I8160P\SAMSUNG_GT-I8160P_boot_v2_00.rcp'
Repair File ver. : FILL ME
Repair file options. : NONE
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
EasyJtag Suite Classic ver.: 2.9.0.0 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edi
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...
OK
Initialising: SAMSUNG GT-I8160P Config ver.:1.00
I/O Level set to : 2600 mV
Box S/N: 160000023B7953FA ,FW Ver.: 01.62
Connecting to Target...
U8500 USB BOOTROM : device 04CC:8500 opened
success: set configuration #1
success: claim_interface #0
Sending XLOADER...
success: bulk read 4 bytes
Done.
JTAG device: U8500
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
JTAG device: U8500
CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6
CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC
Halting CPU...
EMMC #0 : ID : 0x00000045 Name : SEM04G Size : 3,7 G , (7733248) Blocks
EMMC #1 : ID : 0x00000045 Name : SEM04G Size : 1,0 M , (2048) Blocks
eMMC flash device(s) found, Device ID : 0x00450000
eMMC Writing GPT...
eMMC Write OK! Elapsed time: 0,579033s (221,058 KiB/s)
eMMC Writing XLOADER...
eMMC Write OK! Elapsed time: 3,519202s (109,116 KiB/s)
eMMC Writing PIT...
eMMC Write OK! Elapsed time: 5,752329s (178,015 KiB/s)
eMMC Writing STE MEM INIT...
eMMC Write OK! Elapsed time: 3,071176s (166,711 KiB/s)
eMMC Writing PWR MGT...
eMMC Write OK! Elapsed time: 3,115178s (164,357 KiB/s)
eMMC Writing SBL...
eMMC Write OK! Elapsed time: 15,934911s (128,523 KiB/s)
eMMC Writing SBL2...
eMMC Write OK! Elapsed time: 16,039917s (127,681 KiB/s)
eMMC Writing PARAM...
eMMC Write OK! Elapsed time: 101,170784s (161,944 KiB/s)
eMMC Writing IPL MODEM...
eMMC Write OK! Elapsed time: 12,311704s (166,346 KiB/s)
All Done.
Old 02-10-2018, 07:17   #596 (permalink)
Member: 1743002
Sonork: 123456
Thanks Meter: 26
sir help me 1557 dump file plz
help
Old 02-10-2018, 07:45   #597 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
Q MOBILE i5 MTK DEAD RECOVERD DONE
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 1784 mV
CMD Active Level: 2670 mV
EMMC CID: 90014A4834473164040502A10285410C
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 4/2014 , Rev: 05
EMMC NAME: H4G1d , S/N: 02A10285 , rev. 05
EMMC NAME (HEX): 483447316404
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G1d_02A10285_20180209_181621.extcsd
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 1794 mV
CMD Active Level: 2681 mV
Backup saved: H4G1d_02A10285_20180209_181636.extcsd
Operation: Write Dump
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Input file: C:\Users\CHAND\Desktop\i5dump\EMMC_H4G1d_ROM2_0000 00000000_000000400000.bin
Done writing partition. Write speed: 560.38 Kb/s
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H4G1d_02A10285_20180209_181659.extcsd
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Input file: C:\Users\CHAND\Desktop\i5dump\EMMC_H4G1d_ROM3_0000 00000000_000000400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 578.45 Kb/s
HiPower mode is OFF
Frequence: 21 Mhz
CMD Pullup Level: 1804 mV
Backup saved: H4G1d_02A10285_20180209_181725.extcsd
Opening file: MT6582_Android_scatter.txt
The new format of scatter
config_version: V1.1.1
platform: MT6582
preloader_s4700.bin
Found 3 supported eMMC CID:
name = 'H4G1d' hex = 0x483447316404 [SKHYNIX]
eNAND_H26M31002GPR/4GB @FBGA153
eNAND_H9DP32A4JJBCGR-KEM/4GB @FBGA153
eNAND_H9TP32A4GDBCPR-KGM/4GB @FBGA162
eNAND_H9TP32A8JDACPR-KGM/4GB @FBGA162
name = '004G90' hex = 0x303034473930 [TOSHIBA]
eSD_THGBM5G5A1JBAIR/4GB @FBGA153
eSD_THGBMAG5A1JBAIR/4GB @FBGA153
TYC0FH121597RA/4GB @FBGA153
TYD0FH221618RA/4GB @FBGA162
TYD0FH221618RA-4G @BGA162
name = 'H8G2d' hex = 0x483847326404 [SKHYNIX]
eNAND_H26M42003GMR/8GB @FBGA153
eNAND_H9TP65A8JDACPR-KGM/8GB @FBGA162
eNAND_H9TP65A8JDMCPR-KGM/8GB @FBGA162
eNAND_H9TQ65A8GTMCUR-KTM/8GB @BGA221
The size of the last section has been updated
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H4G1d_02A10285_20180209_181731.extcsd
Operation: Write by vendor (MediaTek)
Partition name: PRELOADER
Filename: preloader_s4700.bin , Offset: 000000000000 , filesize: 117492 bytes
Done writing partition. Write speed: 325.08 Kb/s
Partition name: MBR
Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes
Done writing partition. Write speed: 24.99 Kb/s
Partition name: EBR1
Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes
Done writing partition. Write speed: 37.03 Kb/s
Partition name: UBOOT
Filename: lk.bin , Offset: 000002920000 , filesize: 245240 bytes
Done writing partition. Write speed: 416.62 Kb/s
Partition name: BOOTIMG
Filename: boot.img , Offset: 000002980000 , filesize: 5896192 bytes
Done writing partition. Write speed: 917.00 Kb/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000003980000 , filesize: 6217728 bytes
Done writing partition. Write speed: 924.34 Kb/s
Partition name: SEC_RO
Filename: secro.img , Offset: 000004980000 , filesize: 135168 bytes
Done writing partition. Write speed: 1441.69 Kb/s
Partition name: LOGO
Filename: logo.bin , Offset: 000005000000 , filesize: 406156 bytes
Done writing partition. Write speed: 787.74 Kb/s
Partition name: ANDROID
Filename: system.img , Offset: 000005D00000 , filesize: 976977328 bytes
Sparse image found v.1.0 Total chunks: 1655
Done writing partition. Write speed: 871.82 Kb/s
Partition name: CACHE
Filename: cache.img , Offset: 000055D00000 , filesize: 6316180 bytes
Sparse image found v.1.0 Total chunks: 10
Done writing partition. Write speed: 1502.21 Kb/s
Partition name: USRDATA
Filename: userdata.img , Offset: 00005DB00000 , filesize: 17392076 bytes
Sparse image found v.1.0 Total chunks: 36
Done writing partition. Write speed: 1502.88 Kb/s
Writing DL_Info...
Writing DL_Info done
Writing eMMC Register ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
All done
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H4G1d_02A10285_20180209_183858.extcsd
HiPower mode is OFF
Frequence: 21 Mhz
Backup saved: H4G1d_02A10285_20180209_183908.extcsd
Scanning soft partitions
MBR header is found. Analyzing data ...
EBR detected at address: 000000080000
Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000
Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000
Partition: mmcblk0p2 [000003D80000 - 000004380000], size: 000000600000
Partition: mmcblk0p3 [000005100000 - 000055100000], size: 000050000000
Partition: mmcblk0p4 [000055100000 - 00005CF00000], size: 000007E00000
Partition: mmcblk0p5 [00005CF00000 - 02000007FE00], size: 01FFA317FE00
MBR header successfully parsed
Get firmware version
Brand = QMobile
Model = QMobile i5
CPU Abi = armeabi-v7a
Mediatek platform = MT6582
Android release = 4.4.2
Firmware version = ALPS.KK1.MP1.V2.10
Firmware date = 2014? 08? 27? ??? 19:37:54 CST
Old 02-14-2018, 05:06   #598 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 166
j710mn frp done
j710mn frp new sec bin 4 frp done by easy jtag
https://www.youtube.com/watch?v=nxqzqT5Yrcs&fs=1" width="644" height="390">https://www.youtube.com/watch?v=nxqzqT5Yrcs&fs=1" />https://www.youtube.com/watch?v=nxqzqT5Yrcs">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=nxqzqT5Yrcs
12/02/2018 10:54:18 p.m.>
12/02/2018 10:54:18 p.m.> eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
12/02/2018 10:54:18 p.m.> Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.23403)
12/02/2018 10:54:18 p.m.> Looking for EasyJTAG box...
12/02/2018 10:54:18 p.m.> EasyJTAG API ver. 2022
12/02/2018 10:54:19 p.m.> OpenUSB returned = 0
12/02/2018 10:54:21 p.m.> EasyJTAG Box Serial =
12/02/2018 10:54:25 p.m.> Card Serial =
12/02/2018 10:54:25 p.m.> CardAttr =
12/02/2018 10:54:25 p.m.> EasyJTAG Box Firmware = 1.62
12/02/2018 10:54:42 p.m.> Looking for EasyJTAG box...
12/02/2018 10:54:42 p.m.> EasyJTAG API ver. 2022
12/02/2018 10:54:42 p.m.> Setting IO Levels to 3.3V
12/02/2018 10:54:42 p.m.> Setting frequence to 14 Mhz
12/02/2018 10:54:42 p.m.> EasyJTAG Box Serial =
12/02/2018 10:54:42 p.m.> EasyJTAG Box Firmware = 1.62
12/02/2018 10:54:43 p.m.> HiPower mode is ON
12/02/2018 10:54:43 p.m.> Setting frequence to 14 Mhz
12/02/2018 10:54:44 p.m.> CMD Pullup Level: 453 mV
12/02/2018 10:54:44 p.m.> CMD Active Level: 2516 mV
12/02/2018 10:54:44 p.m.> eMMC Init returned = 0
12/02/2018 10:54:44 p.m.> EMMC Device Information :
12/02/2018 10:54:44 p.m.> EMMC CID: 150100414A4E42335203F06AECD384C8
12/02/2018 10:54:44 p.m.> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/02/2018 10:54:44 p.m.> EMMC Manufacture Name: SAMSUNG , EMMC NAME: AJNB3R , EMMC NAME (HEX): 414A4E423352 , S/N: , rev. 0x03
12/02/2018 10:54:44 p.m.> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 8/2017
12/02/2018 10:54:44 p.m.> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
12/02/2018 10:54:44 p.m.> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/02/2018 10:54:44 p.m.> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/02/2018 10:54:44 p.m.> EMMC Permanent Write Protection: No
12/02/2018 10:54:44 p.m.> EMMC Temporary Write Protection: No
12/02/2018 10:54:44 p.m.> Extended CSD Information :
12/02/2018 10:54:44 p.m.> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
12/02/2018 10:54:44 p.m.> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/02/2018 10:54:44 p.m.> Boot Bus Config: 0x01 , width 4bit
12/02/2018 10:54:44 p.m.> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
12/02/2018 10:54:44 p.m.> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/02/2018 10:54:44 p.m.> Device supports partitioning features
12/02/2018 10:54:44 p.m.> Device can have enhanced technological features in partitions and user data area
12/02/2018 10:54:44 p.m.> Device can have extended partitions attribute
12/02/2018 10:54:44 p.m.> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/02/2018 10:54:44 p.m.> Backup saved: AJNB3R_F06AECD3_20180212_225444.extcsd
12/02/2018 10:54:44 p.m.> EMMC Init completed.
12/02/2018 10:54:44 p.m.> Scanning soft partitions
12/02/2018 10:54:44 p.m.> GPT header is found and is valid
12/02/2018 10:54:44 p.m.> Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: EFS, [000000C00000 - 000002000000], size: 000001400000
12/02/2018 10:54:44 p.m.> Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000
12/02/2018 10:54:44 p.m.> Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000
12/02/2018 10:54:44 p.m.> Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000
12/02/2018 10:54:44 p.m.> Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000
12/02/2018 10:54:44 p.m.> Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000
12/02/2018 10:54:44 p.m.> Partition: OTA, [000008300000 - 000008B00000], size: 000000800000
12/02/2018 10:54:44 p.m.> Partition: CDMA-RADIO, [000008B00000 - 000008F00000], size: 000000400000
12/02/2018 10:54:44 p.m.> Partition: RADIO, [000008F00000 - 00000E700000], size: 000005800000
12/02/2018 10:54:44 p.m.> Partition: TOMBSTONES, [00000E700000 - 00000E800000], size: 000000100000
12/02/2018 10:54:44 p.m.> Partition: DNT, [00000E800000 - 00000E900000], size: 000000100000
12/02/2018 10:54:44 p.m.> Partition: PERSISTENT, [00000E900000 - 00000E980000], size: 000000080000
12/02/2018 10:54:44 p.m.> Partition: PERSDATA, [00000E980000 - 00000F580000], size: 000000C00000
12/02/2018 10:54:44 p.m.> Partition: RESERVED2, [00000F580000 - 00000F800000], size: 000000280000
12/02/2018 10:54:44 p.m.> Partition: SYSTEM, [00000F800000 - 0000CB000000], size: 0000BB800000
12/02/2018 10:54:44 p.m.> Partition: CACHE, [0000CB000000 - 0000D7800000], size: 00000C800000
12/02/2018 10:54:44 p.m.> Partition: HIDDEN, [0000D7800000 - 0000DB400000], size: 000003C00000
12/02/2018 10:54:44 p.m.> Partition: CP_DEBUG, [0000DB400000 - 0000DB900000], size: 000000500000
12/02/2018 10:54:44 p.m.> Partition: USERDATA, [0000DB900000 - 0003AAD00000], size: 0002CF400000
12/02/2018 10:54:44 p.m.> GPT header successfully parsed
12/02/2018 10:54:44 p.m.> Get firmware version
12/02/2018 10:54:47 p.m.> Brand = samsung
12/02/2018 10:54:47 p.m.> Manufacturer = samsung
12/02/2018 10:54:47 p.m.> Model = SM-J710MN
12/02/2018 10:54:47 p.m.> Phone platform = exynos5
12/02/2018 10:54:47 p.m.> CPU Abi = armeabi-v7a
12/02/2018 10:54:47 p.m.> Android release = 7.0
12/02/2018 10:54:47 p.m.> Firmware version = NRD90M.J710MNUBU4BRA1
12/02/2018 10:54:47 p.m.> Firmware date = Thu Jan 11 08:11:59 KST 2018
12/02/2018 10:55:41 p.m.>
12/02/2018 10:55:41 p.m.> Looking for EasyJTAG box...
12/02/2018 10:55:41 p.m.> EasyJTAG API ver. 2022
12/02/2018 10:55:41 p.m.> Setting IO Levels to 3.3V
12/02/2018 10:55:41 p.m.> Setting frequence to 14 Mhz
12/02/2018 10:55:41 p.m.> EasyJTAG Box Serial =
12/02/2018 10:55:41 p.m.> EasyJTAG Box Firmware = 1.62
12/02/2018 10:55:43 p.m.> HiPower mode is ON
12/02/2018 10:55:43 p.m.> Setting frequence to 14 Mhz
12/02/2018 10:55:43 p.m.> CMD Pullup Level: 453 mV
12/02/2018 10:55:43 p.m.> CMD Active Level: 2505 mV
12/02/2018 10:55:43 p.m.> eMMC Init returned = 0
12/02/2018 10:55:43 p.m.> EMMC Device Information :
12/02/2018 10:55:43 p.m.> EMMC CID: 150100414A4E42335203F06AECD384C8
12/02/2018 10:55:43 p.m.> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/02/2018 10:55:43 p.m.> EMMC Manufacture Name: SAMSUNG , EMMC NAME: AJNB3R , EMMC NAME (HEX): 414A4E423352 , S/N: , rev. 0x03
12/02/2018 10:55:43 p.m.> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 8/2017
12/02/2018 10:55:43 p.m.> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
12/02/2018 10:55:43 p.m.> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/02/2018 10:55:43 p.m.> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/02/2018 10:55:43 p.m.> EMMC Permanent Write Protection: No
12/02/2018 10:55:43 p.m.> EMMC Temporary Write Protection: No
12/02/2018 10:55:43 p.m.> Extended CSD Information :
12/02/2018 10:55:43 p.m.> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
12/02/2018 10:55:43 p.m.> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/02/2018 10:55:43 p.m.> Boot Bus Config: 0x01 , width 4bit
12/02/2018 10:55:43 p.m.> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
12/02/2018 10:55:43 p.m.> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/02/2018 10:55:43 p.m.> Device supports partitioning features
12/02/2018 10:55:43 p.m.> Device can have enhanced technological features in partitions and user data area
12/02/2018 10:55:43 p.m.> Device can have extended partitions attribute
12/02/2018 10:55:43 p.m.> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/02/2018 10:55:43 p.m.> Backup saved: AJNB3R_F06AECD3_20180212_225543.extcsd
12/02/2018 10:55:43 p.m.> EMMC Init completed.
12/02/2018 10:55:43 p.m.> Operation 'Remove FRP'
12/02/2018 10:55:43 p.m.> Searching GPT ...
12/02/2018 10:55:43 p.m.> GPT header is found and is valid
12/02/2018 10:55:44 p.m.> FRP partition found
12/02/2018 10:55:44 p.m.> Erasing FRP partition ...
12/02/2018 10:55:44 p.m.> Done erasing partition.
12/02/2018 10:55:44 p.m.> All done
The Following User Says Thank You to kzafquiel For This Useful Post:
Old 02-15-2018, 13:53   #599 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Intex Aqua Young Dead Recover With Repair Emmc
One More Hot Story With Easy Jtag
Intex Aqua Young [Spd Cpu] Dead Recover With Repair Emmc
Sucessfully Repair Emmc And Alive Set
The Following 9 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 02-18-2018, 12:30   #600 (permalink)
kay_pencenk's Avatar
Member: 1380137
Thanks Meter: 122
Thumbs up frp LG Q6 M700 DONE
---------- eMMC Device Information ----------
EMMC CID : 90014A484247346132A443375AA9A4E8
EMMC CSD : D02701328F5903FFFFFFFFE78A400016
EMMC Date: 10/2017 Rev.0xA4
EMMC NAME: HBG4a2 , S/N: 1127701161
EMMC NAME (HEX): 48424734613200
EMMC ROM1 (Main User Data) Capacity: 29820 MB
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
GPT Entries Count = 64
Searching for FRP Data...
Marker of 7000000 is: 19901873
FRP/Persistent Storage Format Success!
Searching for KillSwitch Specific FRP Data...
mmc_read_blocks(0x747C2FC00 > 0x747C00000 ), Read address is invalid
LG Custom Data is not found!
Done.
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 2.9.0.0
Box S/N: , ,FW Ver.: 01.62
CMD Pullup Level:2010 mV
CMD Active Level:2330 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
HiPower mode is ON!
EMMC Password Locked: No
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) USERDATA : 0x0188000000 (22.995GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Page generated in 0.28122 seconds with 9 queries
