06-07-2018, 06:12 | #647 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2130616 Status: Offline Thanks Meter: 8 | always write error in skyhynix emmc pls solve this ..... eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 8346817BEE03BC25 Card Serial = AABB9E0D EasyJTAG Box Firmware = 2.23 Changelog: 17.04.2018 (ver 1.5.0.0) Fix: Bugs that have been found through your crash report Add: Showing Connected Pins for a Socket (Emmc check) Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor) Add: SmartReport for Sandisk Add: Vendor Sony Add: Automatic backup of the TrimArea partition for Sony (read by vendor) Add: Grouping of extracted messages by sender (Explorer) Add: Extract Calendar (Explorer) Add: Checking FullDiskEncryption from Boot (Explorer) Add: Scan FullFlash from devices with UFS-memory (Explorer) Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung) Add: Ext4 formatting is completely rewritten (write by vendor) Add: Reading files with emmc errors (Explorer) Add: Skipping for existing files while saving (Explorer) Add: Write protection for ROM 2/3 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 4 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 797 mV CMD Active Level: 1856 mV EMMC Device Information : EMMC CID: 90014A48344732621101722348CD82D1 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 722348CD , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_722348CD_20180607_103452.extcsd EMMC Init completed. Error: BusWidth is automatically set to 1 Bit Scanning soft partitions Partition table not found Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 1809 mV CMD Active Level: 1866 mV EMMC Device Information : EMMC CID: 90014A48344732621101722348CD82D1 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 722348CD , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_722348CD_20180607_103615.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated BL_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 1810 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 90014A48344732621101722348CD82D1 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 722348CD , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_722348CD_20180607_103622.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Too many errors. Writing has been stopped |
The Following User Says Thank You to abhishekgupt For This Useful Post: |
06-12-2018, 13:32 | #648 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Samsung Galaxy S Duos 3-VE (SM-G316HU) dead boot repair done Samsung Galaxy S Duos 3-VE (SM-G316HU) dead boot repair done [IMG][/IMG] eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 0900301095CE53A5 Card Serial = AAAA6B50 EasyJTAG Box Firmware = 1.62 Changelog: 17.04.2018 (ver 1.5.0.0) Fix: Bugs that have been found through your crash report Add: Showing Connected Pins for a Socket (Emmc check) Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor) Add: SmartReport for Sandisk Add: Vendor Sony Add: Automatic backup of the TrimArea partition for Sony (read by vendor) Add: Grouping of extracted messages by sender (Explorer) Add: Extract Calendar (Explorer) Add: Checking FullDiskEncryption from Boot (Explorer) Add: Scan FullFlash from devices with UFS-memory (Explorer) Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung) Add: Ext4 formatting is completely rewritten (write by vendor) Add: Reading files with emmc errors (Explorer) Add: Skipping for existing files while saving (Explorer) Add: Write protection for ROM 2/3 Setting frequence to 14 Mhz CMD Pullup Level: 3155 mV CMD Active Level: 2021 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 14 Mhz CMD Pullup Level: 3176 mV CMD Active Level: 3227 mV EMMC Device Information : EMMC CID: 90014A48344732621101E713B4123204 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: E713B412 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_E713B412_20180612_132331.extcsd EMMC Init completed. Opening file: VIVALTO_SWA_4GB_20140828.pit Pit: VIVALTO_SWA_4GB_20140828.pit Entry count: 29 The size of the last section has been updated BL_G316HUJVU0ANL3_CL282615_QB3501571_REV02_user_lo w_ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs Setting frequence to 14 Mhz CMD Pullup Level: 3176 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A48344732621101E713B4123204 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: E713B412 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_E713B412_20180612_132341.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0000E8FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: param.lfs Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 223.39 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 559.82 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 751.05 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 744.09 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BOOT_PARTITION_EN for the selected vendor All done time: [00:00:53:084] |
The Following 4 Users Say Thank You to pintu_das For This Useful Post: |
06-12-2018, 16:48 | #649 (permalink) |
Freak Poster Join Date: Jun 2011 Location: kolkata Age: 39
Member: 1596162 Status: Offline Sonork: 100.1616391 Thanks Meter: 146 | Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 Mhz Can't init device. Reason: Command Index Error please help |
06-13-2018, 17:40 | #650 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
if give error after what i do any thing need to select for boot config? it is spd cpu so does not need i think but if it samsung ic then ? | |
The Following User Says Thank You to umarmsn For This Useful Post: |
06-14-2018, 09:01 | #651 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Swipe Konnect 5.1 Eco Stuck On Only Swipe Recover Done Change Emmc Swipe Konnect 5.1Eco Stuck On Swipe Logo Only Emmc Change Samsung To Kingstone Image-1 Log Sucessfully Recovered Set My First Opration Emmc Samsung TO Kingstone |
The Following 6 Users Say Thank You to Deepesh Sharma For This Useful Post: |
06-20-2018, 07:57 | #652 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | lyf jio keypaid f81e stuck on logo solve wit change emmc Lyf Keypaid Mobile F81e Stuck On Logo Solve Change Emmc Skhynix To Kingstone Image Log REcover Done |
The Following 8 Users Say Thank You to Deepesh Sharma For This Useful Post: |
06-21-2018, 00:18 | #653 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Aegean Sea
Member: 1520712 Status: Offline Thanks Meter: 19 | please add sony E2303 i have one and after identify with setoolbox2 says that boot1 is mising. i need isp solution thanks in advance and for your time!!!! |
The Following User Says Thank You to SILVER ANJEL For This Useful Post: |
06-25-2018, 17:19 | #654 (permalink) |
Member: 1520712 Status: Offline Thanks Meter: 19 | Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] what is it OCR i am new at jtag isp and i have questions thanks for your time |
06-30-2018, 08:45 | #655 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | samsung GT-I9070 DEAD BOOT REPAIR DONE SAMSUNG GT-I9070 DEAD BOOT REPAIR DONE WITH GREAT EASY- JTAG [IMG][/IMG] EasyJtag Suite Classic ver.: 2.9.0.3 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6682.33362 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AAAA-6B50 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Loading repair file: 'C:\Users\pintu\Desktop\SAMSUNG_GT-I9070_boot_v2_00.rcp' Repair File ver. : FILL ME Repair file options. : NONE Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.9.0.3 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? Fastest Memory Programmer in the word! | EMMC BOX,UFS MEMORY,NAND,PPN, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: SAMSUNG GT-I9070 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N: 0900301095CE53A5 ,FW Ver.: 01.62 Connecting to Target... U8500 USB BOOTROM : device 04CC:8500 opened success: set configuration #1 success: claim_interface #0 Sending XLOADER... success: bulk read 4 bytes Done. JTAG device: U8500 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 JTAG device: U8500 CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6 CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 eMMC Writing GPT... eMMC Write OK! Elapsed time: 0.376021s (340.407 KiB/s) eMMC Writing XLOADER... eMMC Write OK! Elapsed time: 3.589205s (106.987 KiB/s) eMMC Writing PIT... eMMC Write OK! Elapsed time: 4.585262s (223.324 KiB/s) eMMC Writing STE MEM INIT... eMMC Write OK! Elapsed time: 1.929110s (265.407 KiB/s) eMMC Writing PWR MGT... eMMC Write OK! Elapsed time: 2.790160s (183.502 KiB/s) eMMC Writing SBL... eMMC Write OK! Elapsed time: 12.865736s (159.182 KiB/s) eMMC Writing SBL2... eMMC Write OK! Elapsed time: 14.145809s (144.778 KiB/s) eMMC Writing PARAM... eMMC Write OK! Elapsed time: 10.813619s (94.695 KiB/s) eMMC Writing IPL MODEM... eMMC Write OK! Elapsed time: 8.906510s (229.944 KiB/s) All Done. Loading repair file: 'C:\Users\pintu\Desktop\SAMSUNG_GT-I9070_efs_v2_00.rcp' Repair File ver. : FILL ME Repair file options. : NONE Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.9.0.3 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? Fastest Memory Programmer in the word! | EMMC BOX,UFS MEMORY,NAND,PPN, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: SAMSUNG GT-I9070 Config ver.:1.01 I/O Level set to : 2600 mV Box S/N: 0900301095CE53A5 ,FW Ver.: 01.62 Connecting to Target... U8500 USB BOOTROM : device 04CC:8500 opened success: set configuration #1 success: claim_interface #0 Sending XLOADER... success: bulk read 4 bytes Done. JTAG device: U8500 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 JTAG device: U8500 CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6 CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 eMMC Writing EFS... eMMC Write OK! Elapsed time: 49.077808s (208.648 KiB/s) eMMC Writing MODEM_FS... eMMC Write OK! Elapsed time: 77.068405s (212.590 KiB/s) eMMC Writing STE_MEM_INIT... eMMC Write OK! Elapsed time: 2.257130s (226.837 KiB/s) eMMC Writing PWR_MGT... eMMC Write OK! Elapsed time: 3.007172s (170.260 KiB/s) eMMC Writing IPL_MODEM... eMMC Write OK! Elapsed time: 10.190583s (200.970 KiB/s) eMMC Writing MODEM... eMMC Write OK! Elapsed time: 214.596268s (76.348 KiB/s) All Done. |
The Following User Says Thank You to pintu_das For This Useful Post: |
07-03-2018, 05:03 | #656 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Redmi 2 Stuck on Logo Done Change Emmc Redmi 2 Stuck On Logo SucessFully Recovered Replace Emmc Micron To Micron Image-1 Log Image-2 Image-3 |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
07-05-2018, 02:57 | #657 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | check boot partition en for the selected vendor g532m boot this device after flash boot with easy jtag no show it partition this solution easy with easy jtag check it video |
07-05-2018, 13:15 | #658 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua selfie dead recover change emmc intex aqua selfie dead recover change emmc samsung to samsung Code: 7/5/2018 3:29:08 PM> 7/5/2018 3:29:08 PM> eMMC_tool Suite ver. 1.5.1.0 (release date: 25.04.2018) 7/5/2018 3:29:09 PM> Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) 7/5/2018 3:29:09 PM> 7/5/2018 3:29:09 PM> Looking for EasyJTAG box... 7/5/2018 3:29:09 PM> EasyJTAG API ver. 2100 7/5/2018 3:29:09 PM> OpenUSB returned = 0 7/5/2018 3:29:10 PM> EasyJTAG Box Serial = 5B99395BEB0C6184 7/5/2018 3:29:11 PM> Card Serial = AAEAE4C3 7/5/2018 3:29:11 PM> EasyJTAG Box Firmware = 2.23 7/5/2018 3:29:11 PM> 7/5/2018 3:29:15 PM> Looking for EasyJTAG box... 7/5/2018 3:29:15 PM> EasyJTAG API ver. 2100 7/5/2018 3:29:15 PM> Setting IO Levels to 2.8V 7/5/2018 3:29:15 PM> Setting frequence to 42 Mhz 7/5/2018 3:29:15 PM> EasyJTAG Box Serial = 5B99395BEB0C6184 7/5/2018 3:29:15 PM> EasyJTAG Box Firmware = 2.23 7/5/2018 3:29:16 PM> Setting interface to EasyJtag2/E-Socket 7/5/2018 3:29:16 PM> Setting bus width to 8 Bit 7/5/2018 3:29:16 PM> Setting frequence to 42 Mhz 7/5/2018 3:29:16 PM> eMMC Init returned = 0 7/5/2018 3:29:16 PM> EMMC Device Information : 7/5/2018 3:29:16 PM> EMMC CID: 150100523832314D4200E915CC604221 7/5/2018 3:29:16 PM> EMMC CSD: D02701320F5903FFF6DBFFEF92404009 7/5/2018 3:29:16 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: R821MB , HEX: 523832314D42 , S/N: E915CC60 , rev. 0x00 7/5/2018 3:29:16 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2015 7/5/2018 3:29:16 PM> EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) 7/5/2018 3:29:16 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/5/2018 3:29:16 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 7/5/2018 3:29:16 PM> EMMC Permanent Write Protection: No 7/5/2018 3:29:16 PM> EMMC Temporary Write Protection: No 7/5/2018 3:29:16 PM> Extended CSD Information : 7/5/2018 3:29:16 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 7/5/2018 3:29:16 PM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 7/5/2018 3:29:16 PM> Boot Bus Config: 0x00 , width 1bit 7/5/2018 3:29:16 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 7/5/2018 3:29:16 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/5/2018 3:29:16 PM> Device supports partitioning features 7/5/2018 3:29:16 PM> Device can have enhanced technological features in partitions and user data area 7/5/2018 3:29:16 PM> Device can have extended partitions attribute 7/5/2018 3:29:16 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/5/2018 3:29:16 PM> Backup saved: R821MB_E915CC60_20180705_152916.extcsd 7/5/2018 3:29:16 PM> EMMC Init completed. 7/5/2018 3:29:16 PM> 7/5/2018 3:29:16 PM> Scanning soft partitions 7/5/2018 3:29:16 PM> GPT header is found and is valid 7/5/2018 3:29:16 PM> Partition: prodnv, [000000100000 - 000000600000], size: 000000500000 (5.00 MB) 7/5/2018 3:29:16 PM> Partition: miscdata, [000000600000 - 000000700000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: l_fixnv1, [000000700000 - 000000800000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: l_fixnv2, [000000800000 - 000000900000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: l_runtimenv1, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: l_runtimenv2, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: l_modem, [000000B00000 - 000001E00000], size: 000001300000 (19.0 MB) 7/5/2018 3:29:16 PM> Partition: l_ldsp, [000001E00000 - 000002100000], size: 000000300000 (3.00 MB) 7/5/2018 3:29:16 PM> Partition: l_gdsp, [000002100000 - 000002400000], size: 000000300000 (3.00 MB) 7/5/2018 3:29:16 PM> Partition: l_warm, [000002400000 - 000002700000], size: 000000300000 (3.00 MB) 7/5/2018 3:29:16 PM> Partition: pm_sys, [000002700000 - 000002800000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: logo, [000002800000 - 000002900000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: fbootlogo, [000002900000 - 000002A00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: wcnfdl, [000002A00000 - 000002B00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: wcnmodem, [000002B00000 - 000003500000], size: 000000A00000 (10.0 MB) 7/5/2018 3:29:16 PM> Partition: boot, [000003500000 - 000004900000], size: 000001400000 (20.0 MB) 7/5/2018 3:29:16 PM> Partition: persist, [000004900000 - 000004B00000], size: 000000200000 (2.00 MB) 7/5/2018 3:29:16 PM> Partition: trustos, [000004B00000 - 000004C00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: vmm, [000004C00000 - 000004D00000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: system, [000004D00000 - 0000BA100000], size: 0000B5400000 (2.83 GB) 7/5/2018 3:29:16 PM> Partition: sysinfo, [0000BA100000 - 0000BA700000], size: 000000600000 (6.00 MB) 7/5/2018 3:29:16 PM> Partition: cache, [0000BA700000 - 0000C3D00000], size: 000009600000 (150. MB) 7/5/2018 3:29:16 PM> Partition: recovery, [0000C3D00000 - 0000C5100000], size: 000001400000 (20.0 MB) 7/5/2018 3:29:16 PM> Partition: misc, [0000C5100000 - 0000C5200000], size: 000000100000 (1.00 MB) 7/5/2018 3:29:16 PM> Partition: userdata, [0000C5200000 - 0003A3500000], size: 0002DE300000 (11.4 GB) 7/5/2018 3:29:16 PM> GPT header successfully parsed 7/5/2018 3:29:16 PM> 7/5/2018 3:29:16 PM> Get firmware version 7/5/2018 3:29:16 PM> 7/5/2018 3:29:17 PM> Brand = INTEX 7/5/2018 3:29:17 PM> Manufacturer = INTEX 7/5/2018 3:29:17 PM> Model = INTEX AQUA SELFIE 7/5/2018 3:29:17 PM> Phone platform = sc8830 7/5/2018 3:29:17 PM> CPU Abi = armeabi-v7a 7/5/2018 3:29:17 PM> Android release = 7.0 7/5/2018 3:29:17 PM> Firmware version = INTEX_AQUA_SELFIE_V10_INDIAN_SER 7/5/2018 3:29:17 PM> Firmware date = Thu Nov 2 09:05:36 CST 2017 |
07-13-2018, 08:51 | #659 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Zen M72Smart Dead Recover Change Emmc Zen M72 Smart Dead Recover Change Emmc Kingstone TO Samsung Set Recover Done Image Log Recover Handset Alive |
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post: |
07-28-2018, 12:35 | #660 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Samsung G350e Dead recover With Repair Emmc Samsung G350e Dead Repair Repair Emmc Job Done Log Sucessfully Alive Handset |
