05-06-2017, 12:34 | #1 (permalink) |
Registered User Join Date: May 2006
Member: 270171 Status: Offline Thanks Meter: 24 | problem with backup mainuserdata i can backup from boot 1 and boot 2 but cant backup from main user data ---------------------------- Z3X EasyJtag Software ver. 2.5.0.9 Skip loading eMMC Addon Firmware CMD Pullup Level:2237 mV CMD Active Level:3217 mV Box IO Level:3300 mV CLK Rate:7000 kHz Reading 0x000000200000 bytes from 0x000000000000 ...ROM2 ( BOOT1 ROM) Output file :B:\EMMC_ROM2_MAG2GA_3793580896_00000000_00200000. bin Done. Read Speed: 777 kB/s Z3X EasyJtag Software ver. 2.5.0.9 Skip loading eMMC Addon Firmware CMD Pullup Level:2237 mV CMD Active Level:3217 mV Box IO Level:3300 mV CLK Rate:7000 kHz Reading 0x0002CF400000 bytes from 0x0000D4A00000 ...ROM1 ( USER ROM) Output file :B:\EMMC_ROM1_MAG2GA_3793580896_D4A00000_2CF400000 .bin Retry reading adress 0xD4A00000 (Attempt #0) Retry Fail! Retry reading adress 0xD4A00000 (Attempt #0) Retry Fail! Retry reading adress 0xD4A00000 (Attempt #0) Retry Fail! Retry reading adress 0xD4A00000 (Attempt #0) Retry Fail! Retry reading adress 0xD4A00000 (Attempt #0) ----------------------------------------------- ----------------------------------------------- Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0F0090098793C8D7, ,FW Ver.: 01.58 CMD Pullup Level:2248 mV CMD Active Level:3227 mV Box IO Level:3300 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D414732474100E21D7360116E EMMC CSD : D02701320F5903FFF6DBFFFF8A404006 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: MAG2GA , S/N: 3793580896 EMMC NAME (HEX): 4D414732474100 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MAG2GA_3793580896_20170506_1604.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x1b] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x11] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x50] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d1f000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x03] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000ba Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Partition table scan: GPT: not present Found invalid GPT and valid MBR; converting MBR to GPT format Detected 15 meta partitions : Meta partition 0 Meta partition C000 Meta partition C001 Meta partition C002 Meta partition C003 Meta partition C004 Meta partition C005 Meta partition C006 Meta partition C007 Meta partition C008 Meta partition C009 Meta partition C00A Meta partition C00B Meta partition C00C Meta partition C00D You will need to delete this partition or resize it in another utility. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): A92C0C99-5055-69A7-6D38-AD2A7F81CD6F First usable sector: 34 Last usable sector: 30535646 Partition info successfully found --------------------------------------------- P0 (PARTITION_PF0) [0x200 0x200000] Size: 2.0MB P1 (PARTITION_P4D) [0x200200 0x80000] Size: 512.0KB P2 (PARTITION_P48) [0x400000 0x1400000] Size: 20.0MB P4 (PARTITION_P46) [0x1880000 0x80000] Size: 512.0KB P5 (PARTITION_P4A) [0x1a00000 0x300000] Size: 3.0MB P6 (PARTITION_P4B) [0x1e00000 0x300000] Size: 3.0MB P7 (PARTITION_P59) [0x2200000 0x300000] Size: 3.0MB P8 (PARTITION_P5A) [0x2600000 0x300000] Size: 3.0MB P9 (PARTITION_P5B) [0x2a00000 0x300000] Size: 3.0MB P10 (PARTITION_P58) [0x2e00000 0x300000] Size: 3.0MB P11 (PARTITION_P70) [0x3200000 0x500000] Size: 5.0MB P12 (PARTITION_P83) [0x3800000 0x800000] Size: 8.0MB P13 (PARTITION_PF0) [0x4000000 0x1000000] Size: 16.0MB P14 (PARTITION_P83) [0x5000000 0x40000000] Size: 1.0GB P15 (PARTITION_P83) [0x45000000 0xfa00000] Size: 250.0MB P16 (PARTITION_P83) [0x54a00000 0x80000000] Size: 2.0GB P17 (PARTITION_P0C) [0xd4a00000 0x2cf400000] Size: 11.238GB ------ Android information ------ --------------------------------------------- Done. |
