05-27-2021, 11:35 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Earth Age: 39
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | problem with ufs socket Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19 Socket Serial: 01239AC90AD8D4E9EE Socket Type: UFS_SOCKET_BGA_153 Can't init device. Error: -54. Reason: BOX: Wrong socket type, this socket licensed for another chip type |
05-29-2021, 06:36 | #4 (permalink) |
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | Did you mean ufs chip inside socket? I tested it without chip also with samsung b0b1 new and used No chip detect any more by socket this problem happend some time befor but after several reconect problem solved |
11-18-2021, 11:52 | #5 (permalink) |
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | I checked box pinout and found (13,7) D1 and D2 are shorted to GND so it has two Cause 1. circuit shorted 2. xc65lx4 ic shorted after removing xc65lx4 pin is ok . Is it xc65lx4 failure???? how I can fix it? that is changeable? who sells it? Report Post |
05-05-2024, 09:06 | #8 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,951 | -56 error like as at eMMC "CMD timeout error" chip not answer for base request from box it may be bad wire solder, bad balls at chip via socket connect , not chip power and so on try to reball IC at socket, clean socket pins, etc Last edited by layder; 05-06-2024 at 15:19. |
