03-29-2017, 12:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2431503 Status: Offline Thanks Meter: 9 | problem white screen after write dump n8000 hi i have tab n8000 problem logo work SAMSUNG:MoviNAND Format and Reset SAMSUNG:MoviNAND Factory Reset UNIVERSAL:Repair exCSD and write dump N8000_Rom1_Main_Dump_BN N8000_Rom2_Boot_BN N8000_Rom2_Boot_BN_2 done write dumb now power the mobile white screen and flash rom problem pit file help me |
03-29-2017, 15:36 | #2 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685630 Status: Offline Thanks Meter: 6 | Hi.. are you done by ISP? if yes..you may cracked some resistors N8000 using 0201 1/20watt resistors.. very small and may break easily check resistors value for D0(51K) CMD(10K) Clock(10R) use DMM for accurate measurement |
The Following User Says Thank You to jimmygyl For This Useful Post: |
03-29-2017, 20:10 | #3 (permalink) | |
Member: 2431503 Status: Offline Thanks Meter: 9 | Quote:
problem in emmc partition The bord clean need how write pit with esay jtag | |
03-30-2017, 02:59 | #4 (permalink) |
Member: 2685630 Status: Offline Thanks Meter: 6 | Hi you can either using Samsung direct emmc flasher or easy jtag plus -- write by vendor to do that. but are you check your emmc partition after write main dump by check read soft partition option? partition must be OK including pit after write main dump. if not you may have bad dump or hardware issue. p.s. resistor cant be inspected by eyes , use measuring instrument instead. |
