05-18-2021, 15:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | Question about UFS adapter I want to buy this UFS BGA95 adapter https://gsmserver.com/z3x-easy-jtag-...ocket-adapter/ Also i want to use it for ISP connection There are no pins for ISP connection, but i can solder them myself My question is - can i use JTAG sw for ISP by using this adapter There are ISP/Socket in "Connection Type"option When i solder Rx/Tx manually to adapter and select type "ISP" - will this work?? Another words, can i use this adapter instead of ICFRIEND for correct ISP connection ? Thanx |
05-19-2021, 14:26 | #3 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Quote:
easyjtag plus bga 254 ufs adapter black colour.. You can use it for isp and socket also.. | |
05-20-2021, 12:45 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
you need buy special adapter, like BGA254 2in1 | |
05-21-2021, 12:15 | #5 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | This adapter will be good? https://gsmserver.com/z3x-easy-jtag-...ocket-adapter/ Do i correctly understand, it will work with: 1. ISP on phoneboard with UFS types BGA95,153,254 2. ISP on wires-soldered UFS types BGA95,153,254 3. Socked supports only UFS254 or also UFS95,153 ??? Will be grateful for technical help. Last edited by SVH; 05-21-2021 at 12:25. |
05-22-2021, 00:23 | #6 (permalink) | |
it's suppor bga254 ufs and emmc socket connection and all chips isp connection | |
