02-20-2020, 16:48
#1 (permalink)
Member: 821646
Thanks Meter: 507 | Realme 3i RMX1827 Reset Pin/Frp Done. Realme 3i RMX1827 Reset Pin/Frp Done.
Detect Emmc. Quote:
Z3X EasyJtag Software ver. 3.6.2.3
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 1616FD215194B2BE, ,FW Ver.: 01.63
CMD Pullup Level:1980 mV
CMD Active Level:1990 mV
Box IO Level:1800 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100474436424D4201A6066A636662
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 06/2019 Rev.0x1
eMMC NAME: GD6BMB , S/N: 2785438307
eMMC NAME (HEX): 474436424D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 1483 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GD6BMB_2785438307_20200220_1904.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0093800000 (4.546GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 293760
Short Android info:
Unable to read prop.plist , code : 2
Backup saved: BuildProp_20200220_1904.txt
Detected USERDATA USERDATA : 0x01D1800000 (21.789GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
| Android FRP Clear. Quote:
Running:Format FRP Partition...
CMD Pullup Level:1990 mV
CMD Active Level:2062 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Formatting FRP...
Detected LINUX(Android) FRP : 0x0009E88000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x01B6800000 (432.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01D1800000 (21.789GB) , formatting...
Done.
Done.
Done. |
ISP Pinout for Realme 3i is located on The CPU for that you need to Carefully Scratch the CPU to gain access to the Pinout.
The Pinout is the same as Realme 3/RMX1825.
Google for Pinout.
Hope this helps. |
