Sudan-Mobiles | 02-21-2022 11:32 | Realme 5i RMX2030 frp done but show 9008 edl Port l think its hard hardware but dont no where's problem need help :confused: Code:
Running:Format FRP Partition...
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0D0D080A63B23413, ,FW Ver.: 01.63
CMD Pullup Level:2000 mV
CMD Active Level:2433 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 15010044483644414202D3FC90221724
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 01/2020 Rev.0x2
eMMC NAME: DH6DAB , S/N: 3556544546
eMMC NAME (HEX): 444836444142
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 97482 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): BD24F73C-51C2-6674-1504-4B5F2CDDC9FE
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
Formatting FRP...
Detected LINUX(Android) FRP : 0x0028DB2000 (512.0KB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0049800000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x01E2800000 (50.702GB) , formatting...
Done.
Done.
Done. |
