02-21-2022, 11:32 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | Realme 5i RMX2030 frp done but show 9008 edl Port Code: Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0D0D080A63B23413, ,FW Ver.: 01.63 CMD Pullup Level:2000 mV CMD Active Level:2433 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010044483644414202D3FC90221724 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2020 Rev.0x2 eMMC NAME: DH6DAB , S/N: 3556544546 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 97482 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): BD24F73C-51C2-6674-1504-4B5F2CDDC9FE Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x0028DB2000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x0049800000 (256.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01E2800000 (50.702GB) , formatting... Done. Done. Done. |
