11-07-2018, 11:04 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | redmi note 3 encryption unsuccessfull Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 026862FABF5A25EA Card Serial = AA0B-B341 EasyJTAG Box Firmware = 2.30 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 1804 mV CMD Active Level: 2580 mV Can't init device. Reason: CMD CRC Error classic suite: Z3X EasyJtag Software ver. 3.1.0.0 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.30 CMD Pullup Level:1804 mV CMD Active Level:2576 mV Box IO Level:3300 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD CRC Error Done. please suggest what is the problem? |
11-07-2018, 16:24 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Variants: 1) Try to set low clock 2) Try to connect correct mode (HiPower or ISP) 3) Set correct IO voltage | |
11-07-2018, 20:27 | #4 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Use Hipower ISP mode: 1) Set HiPower_ISP interface, Set 1.8v IO 2) Connecnt only CMD//CLK/D0/GND 3) Connect USB power to phone |
The Following User Says Thank You to layder For This Useful Post: |
11-08-2018, 05:14 | #5 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Tried the above as well, all the things I tried still unable to connect via adapter, before also phones when I connect with ISP pinouts provided in support, I am unable to connect with adaptor but if I desolder emmc and connect via emmc socket, it connects, I think there is the problem in adaptor, I bought a new easy JTAG plus last month n its the new adaptor what we get with box, please suggest how can i check if that adaptor is working properly or not? |
11-08-2018, 09:33 | #6 (permalink) | |
Adapter have only capacitors for 1.8/2.8 lines, all other lines have direct connection | |
11-08-2018, 11:17 | #7 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
Z3X EasyJtag Software ver. 3.1.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.30 CMD Pullup Level:1982 mV CMD Active Level:2521 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 110100303332473334008378D1AC435D eMMC CSD : D02700328F5903FFFFFFFFE7864000A7 eMMC Manufacturer ID: 0011 , OEM ID: 0100 eMMC Date: 04/2016 Rev.0x0 eMMC NAME: 032G34 , S/N: 2205733292 eMMC NAME (HEX): 303332473334 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. and when changing io level then this error: 11/8/2018 3:49:46 PM> Looking for EasyJTAG box... 11/8/2018 3:49:46 PM> EasyJTAG API ver. 2022 11/8/2018 3:49:46 PM> Setting IO Levels to 1.8V 11/8/2018 3:49:46 PM> Setting frequence to 9 Mhz 11/8/2018 3:49:46 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/8/2018 3:49:46 PM> EasyJTAG Box Firmware = 2.30 11/8/2018 3:49:46 PM> Setting interface to EasyJtag2/ISP_HiPower 11/8/2018 3:49:46 PM> Setting bus width to 1 Bit 11/8/2018 3:49:46 PM> HiPower mode is ON 11/8/2018 3:49:51 PM> Setting frequence to 9 Mhz 11/8/2018 3:49:51 PM> CMD Pullup Level: 1766 mV 11/8/2018 3:49:51 PM> CMD Active Level: 1881 mV 11/8/2018 3:49:51 PM> eMMC Init returned = -103 11/8/2018 3:49:51 PM> Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] 11/8/2018 3:39:21 PM> Looking for EasyJTAG box... 11/8/2018 3:39:21 PM> EasyJTAG API ver. 2022 11/8/2018 3:39:21 PM> Setting IO Levels to 1.8V 11/8/2018 3:39:21 PM> Setting frequence to 6 Mhz 11/8/2018 3:39:21 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/8/2018 3:39:21 PM> EasyJTAG Box Firmware = 2.30 11/8/2018 3:39:22 PM> Setting interface to EasyJtag2/ISP 11/8/2018 3:39:22 PM> Setting bus width to 1 Bit 11/8/2018 3:39:33 PM> Setting frequence to 6 Mhz 11/8/2018 3:39:33 PM> CMD Pullup Level: 1770 mV 11/8/2018 3:39:33 PM> CMD Active Level: 1878 mV 11/8/2018 3:39:33 PM> eMMC Init returned = -3 11/8/2018 3:39:33 PM> Can't init device. Reason: DATA RCV Timeout Error sir i am using 1 bit adaptor, should i use 4bits? Last edited by Bhagat20; 11-08-2018 at 11:25. | |
11-08-2018, 13:57 | #8 (permalink) | |||
No differents within adapters. You can use it as like. You need to use rules: 1) Lenght of CMD/CLK/D0 is need to be some (no more then 1-2 sm differents) 2) GND line is need to be told | |||
11-08-2018, 14:18 | #9 (permalink) | |
Please suggest why this error only in easy JTAG classic suite? | |
11-08-2018, 18:55 | #10 (permalink) | |
11-09-2018, 12:22 | #11 (permalink) | |
11/9/2018 3:11:21 PM> Looking for EasyJTAG box... 11/9/2018 3:11:21 PM> EasyJTAG API ver. 2100 11/9/2018 3:11:21 PM> Setting IO Levels to 2.8V 11/9/2018 3:11:21 PM> Setting frequence to 18 Mhz 11/9/2018 3:11:21 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/9/2018 3:11:21 PM> EasyJTAG Box Firmware = 2.30 11/9/2018 3:11:21 PM> Setting interface to EasyJtag2/ISP 11/9/2018 3:11:21 PM> Setting bus width to 1 Bit 11/9/2018 3:11:21 PM> Setting frequence to 18 Mhz 11/9/2018 3:11:21 PM> CMD Pullup Level: 1947 mV 11/9/2018 3:11:21 PM> CMD Active Level: 2497 mV 11/9/2018 3:11:21 PM> eMMC Init returned = 0 11/9/2018 3:11:21 PM> EMMC Device Information : 11/9/2018 3:11:21 PM> EMMC CID: 110100303332473334008378D1AC435D 11/9/2018 3:11:21 PM> EMMC CSD: D02700328F5903FFFFFFFFE7864000A7 11/9/2018 3:11:21 PM> EMMC Manufacture : TOSHIBA , EMMC NAME: 032G34 , HEX: 303332473334 , S/N: 8378D1AC , rev. 0x00 11/9/2018 3:11:21 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016 11/9/2018 3:11:21 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 11/9/2018 3:11:21 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/9/2018 3:11:21 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/9/2018 3:11:21 PM> EMMC Permanent Write Protection: No 11/9/2018 3:11:21 PM> EMMC Temporary Write Protection: No 11/9/2018 3:11:21 PM> Extended CSD Information : 11/9/2018 3:11:21 PM> Extended CSD rev: 1.8 (MMC 5.1) 11/9/2018 3:11:21 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 11/9/2018 3:11:21 PM> Boot Bus Config: 0x00 , width 1bit 11/9/2018 3:11:21 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 11/9/2018 3:11:21 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/9/2018 3:11:21 PM> Device supports partitioning features 11/9/2018 3:11:21 PM> Device can have enhanced technological features in partitions and user data area 11/9/2018 3:11:22 PM> Device can have extended partitions attribute 11/9/2018 3:11:22 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/9/2018 3:11:22 PM> Backup saved: 032G34_8378D1AC_20181109_151122.extcsd 11/9/2018 3:11:22 PM> EMMC Init completed. 11/9/2018 3:11:22 PM> 11/9/2018 3:11:22 PM> Scanning soft partitions 11/9/2018 3:11:22 PM> GPT header is found and is valid 11/9/2018 3:11:22 PM> Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) 11/9/2018 3:11:22 PM> Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB) 11/9/2018 3:11:22 PM> Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB) 11/9/2018 3:11:22 PM> Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB) 11/9/2018 3:11:22 PM> Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB) 11/9/2018 3:11:22 PM> Partition: hyp, [00000C602400 - 00000C682400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: hypbak, [00000C682400 - 00000C702400], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: dsp, [00000C702400 - 00000D702400], size: 000001000000 (16.0 MB) 11/9/2018 3:11:22 PM> Partition: modemst1, [00000D702400 - 00000D882400], size: 000000180000 (1.50 MB) 11/9/2018 3:11:22 PM> Partition: modemst2, [00000D882400 - 00000DA02400], size: 000000180000 (1.50 MB) 11/9/2018 3:11:22 PM> Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB) 11/9/2018 3:11:22 PM> Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB) 11/9/2018 3:11:22 PM> Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB) 11/9/2018 3:11:22 PM> Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 (11.0 MB) 11/9/2018 3:11:22 PM> Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB) 11/9/2018 3:11:22 PM> Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB) 11/9/2018 3:11:22 PM> Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB) 11/9/2018 3:11:22 PM> Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB) 11/9/2018 3:11:22 PM> Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB) 11/9/2018 3:11:22 PM> Partition: system, [000020300000 - 0000C0300000], size: 0000A0000000 (2.50 GB) 11/9/2018 3:11:22 PM> Partition: cache, [0000C4000000 - 0000D4000000], size: 000010000000 (256. MB) 11/9/2018 3:11:22 PM> Partition: persist, [0000D4000000 - 0000D6000000], size: 000002000000 (32.0 MB) 11/9/2018 3:11:22 PM> Partition: misc, [0000D6000000 - 0000D6100000], size: 000000100000 (1.00 MB) 11/9/2018 3:11:22 PM> Partition: keystore, [0000D6100000 - 0000D6180000], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: config, [0000D6180000 - 0000D6188000], size: 000000008000 (32.0 KB) 11/9/2018 3:11:22 PM> Partition: oem, [0000D6188000 - 0000DA188000], size: 000004000000 (64.0 MB) 11/9/2018 3:11:22 PM> Partition: limits, [0000DC000000 - 0000DC008000], size: 000000008000 (32.0 KB) 11/9/2018 3:11:22 PM> Partition: mota, [0000E0000000 - 0000E0080000], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: devcfg, [0000E0080000 - 0000E00C0000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: dip, [0000E00C0000 - 0000E01C0000], size: 000000100000 (1.00 MB) 11/9/2018 3:11:22 PM> Partition: mdtp, [0000E01C0000 - 0000E21C0000], size: 000002000000 (32.0 MB) 11/9/2018 3:11:22 PM> Partition: cust, [0000E21C0000 - 0001021C0000], size: 000020000000 (512. MB) 11/9/2018 3:11:22 PM> Partition: syscfg, [0001021C0000 - 000102240000], size: 000000080000 (512. KB) 11/9/2018 3:11:22 PM> Partition: mcfg, [000102240000 - 000102640000], size: 000000400000 (4.00 MB) 11/9/2018 3:11:22 PM> Partition: cmnlib, [000104000000 - 000104040000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: keymaster, [000104040000 - 000104080000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: cmnlibbak, [000104080000 - 0001040C0000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: keymasterbak, [0001040C0000 - 000104100000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: apdp, [000108000000 - 000108040000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: msadp, [000108040000 - 000108080000], size: 000000040000 (256. KB) 11/9/2018 3:11:22 PM> Partition: dpo, [000108080000 - 000108082000], size: 000000002000 (8.00 KB) 11/9/2018 3:11:22 PM> Partition: userdata, [000108082000 - 000108082000], size: 000000000000 (0 B) 11/9/2018 3:11:22 PM> GPT header successfully parsed 11/9/2018 3:11:22 PM> 11/9/2018 3:11:22 PM> Get firmware version 11/9/2018 3:11:22 PM> 11/9/2018 3:11:23 PM> Error: Mount [data] failed PartType: LINUX 11/9/2018 3:11:23 PM> Brand = Xiaomi 11/9/2018 3:11:23 PM> Manufacturer = Xiaomi 11/9/2018 3:11:23 PM> Model = Redmi Note 3 11/9/2018 3:11:23 PM> Phone platform = msm8952 11/9/2018 3:11:23 PM> CPU Abi = arm64-v8a 11/9/2018 3:11:23 PM> Android release = 6.0.1 11/9/2018 3:11:23 PM> Firmware version = MMB29M 11/9/2018 3:11:23 PM> Firmware date = Fri Mar 24 15:36:11 CST 2017 | |
11-09-2018, 19:16 | #13 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Sir please review this thread-- same problem..... http://forum.gsmhosting.com/vbb/f672...licon-2499885/ That person has given this resolution-- Look Userdata size=0. Need format Userdata partition. Emmc File Manager or EasyJtag Classic - regions......? Please suggest? If unable to mount data phone will be hang on logo only? |
11-10-2018, 09:23 | #14 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | sir now phone not powering on, only red led blinking please see the logs after flash: Z3X EasyJtag Software ver. 3.1.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.30 CMD Pullup Level:1962 mV CMD Active Level:2508 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 110100303332473334008378D1AC435D eMMC CSD : D02700328F5903FFFFFFFFE7864000A7 eMMC Manufacturer ID: 0011 , OEM ID: 0100 eMMC Date: 04/2016 Rev.0x0 eMMC NAME: 032G34 , S/N: 2205733292 eMMC NAME (HEX): 303332473334 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G34_2205733292_20181110_1236.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Found Data areas (firmware parts) count is: 46 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x4000000 0x5400000] Size: 84.0MB P1 (FSC) [0xc000000 0x400] Size: 1.0KB P2 (SSD) [0xc000400 0x2000] Size: 8.0KB P3 (SBL1) [0xc002400 0x80000] Size: 512.0KB P4 (SBL1BAK) [0xc082400 0x80000] Size: 512.0KB P5 (RPM) [0xc102400 0x80000] Size: 512.0KB P6 (RPMBAK) [0xc182400 0x80000] Size: 512.0KB P7 (TZ) [0xc202400 0x200000] Size: 2.0MB P8 (TZBAK) [0xc402400 0x200000] Size: 2.0MB P9 (HYP) [0xc602400 0x80000] Size: 512.0KB P10 (HYPBAK) [0xc682400 0x80000] Size: 512.0KB P11 (DSP) [0xc702400 0x1000000] Size: 16.0MB P12 (MODEMST1) [0xd702400 0x180000] Size: 1.500MB P13 (MODEMST2) [0xd882400 0x180000] Size: 1.500MB P14 (DDR) [0x10000000 0x8000] Size: 32.0KB P15 (FSG) [0x10008000 0x180000] Size: 1.500MB P16 (SEC) [0x10188000 0x4000] Size: 16.0KB P17 (SPLASH) [0x14000000 0xb00000] Size: 11.0MB P18 (ABOOT) [0x18000000 0x100000] Size: 1.0MB P19 (ABOOTBAK) [0x18100000 0x100000] Size: 1.0MB P20 (BOOT) [0x18200000 0x4000000] Size: 64.0MB P21 (RECOVERY) [0x1c200000 0x4000000] Size: 64.0MB P22 (DEVINFO) [0x20200000 0x100000] Size: 1.0MB P23 (SYSTEM) [0x20300000 0xa0000000] Size: 2.500GB P24 (CACHE) [0xc4000000 0x10000000] Size: 256.0MB P25 (PERSIST) [0xd4000000 0x2000000] Size: 32.0MB P26 (MISC) [0xd6000000 0x100000] Size: 1.0MB P27 (KEYSTORE) [0xd6100000 0x80000] Size: 512.0KB P28 (CONFIG) [0xd6180000 0x8000] Size: 32.0KB P29 (OEM) [0xd6188000 0x4000000] Size: 64.0MB P30 (LIMITS) [0xdc000000 0x8000] Size: 32.0KB P31 (MOTA) [0xe0000000 0x80000] Size: 512.0KB P32 (DEVCFG) [0xe0080000 0x40000] Size: 256.0KB P33 (DIP) [0xe00c0000 0x100000] Size: 1.0MB P34 (MDTP) [0xe01c0000 0x2000000] Size: 32.0MB P35 (CUST) [0xe21c0000 0x20000000] Size: 512.0MB P36 (SYSCFG) [0x1021c0000 0x80000] Size: 512.0KB P37 (MCFG) [0x102240000 0x400000] Size: 4.0MB P38 (CMNLIB) [0x104000000 0x40000] Size: 256.0KB P39 (KEYMASTER) [0x104040000 0x40000] Size: 256.0KB P40 (CMNLIBBAK) [0x104080000 0x40000] Size: 256.0KB P41 (KEYMASTERBAK) [0x1040c0000 0x40000] Size: 256.0KB P42 (APDP) [0x108000000 0x40000] Size: 256.0KB P43 (MSADP) [0x108040000 0x40000] Size: 256.0KB P44 (DPO) [0x108080000 0x2000] Size: 8.0KB P45 (USERDATA) [0x108082000 0x63fb79c00] Size: 24.995GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0020300000 (2.500GB) Build ID: MMB29M Display Build ID: MMB29M Release ID: 6.0.1 Device Model: Redmi Note 3 Device Name: kenzo Architecture ABI: arm64-v8a Device Platform: msm8952 Product ID: kenzo Build Description: kenzo-user 6.0.1 MMB29M V8.2.2.0.MHOMIDL release-keys Device manufacturer: Xiaomi --------------------------------------------- Done. |
