05-12-2017, 17:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 54
Member: 11273 Status: Offline Thanks Meter: 14 | Restore data from eMMC KMVTU000LM-B503 My Samsung Galaxy S3 (I9300) is dead (stuck on Logo), I have desoldered the eMMC and tried to recover my files and infos Easy JTAG Plus but I get always this error: Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]. I use Easy JTAG box with Moorc E-Mate Pro (Adapter 11,5x13) bought from GSMSERVER. the eMMC is good reballed. please guide me to recover my files and other infos. I don't want to repair eMMC or use this old mobile, I just want to get back my files and infos. is there any way (tool or addon in Easy JTAG) to check up if all pinouts or contacts are connected? like ex. EPR Box (look this youtube video https://*********/RjIzx0VppaM ) br |
05-13-2017, 10:24 | #3 (permalink) |
Member: 11273 Status: Offline Thanks Meter: 14 | thank you Jani-Jan for thed reply, how can I be sure 100% that this eMMC is dead? is thier any method to prove it? may be VCC? can you please explain? br |
05-13-2017, 17:12 | #4 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | This error usually pops up when eMMC is sadly dead. Since you already desoldered the chip you can try to read it with testpoint. If it can be read that way you can try to update it's firmware and it might work, but you'll data will be gone. Either way, you'll see if chip is completelly dead or it's in fact only firmware issue. In such case, if data is really important you can send it to a company that does data recovery directly from the NAND chip inside the eMMC but it's a costly procedure and does not guarantee success either. |
The Following 3 Users Say Thank You to KrzychuG For This Useful Post: |
07-23-2017, 15:57 | #5 (permalink) |
Member: 11273 Status: Offline Thanks Meter: 14 | Hi KrzychuG, I could today read this chip with Testpoint: HiPower mode is OFF CMD Pullup Level: 3238 mV CMD Active Level: 3341 mV EMMC Device Information : EMMC CID: 1501003030303030305620110726589C EMMC CSD: 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacture Name: SAMSUNG EMMC NAME: 000000 , S/N: 20110726 , rev. 56 EMMC NAME (HEX): 303030303030 EMMC ROM 1 (Main User Data) Capacity: 16384 MB (000400000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Backup saved: 000000_20110726_20170723_161934.extcsd EMMC Init completed. Warning: Maybe your emmc damaged Scan from: 000000 Vendor: Samsung Searching GPT ... GPT header is not found Searching PIT ... Error reading at address: 000000000000 ... Retry #1 Error reading at address: 000000000000 ... Retry #2 Error reading at address: 000000000000 ... Retry #3 Error reading at address: 000000000000 ... Retry #4 Error reading at address: 000000000000 ... Retry #5 Too many errors. Reading has been stopped What do you think, can I restore my data from this chip? is there any Settings to Change in EasyJTAG Plus to scan the Partition in Explorer? |
07-23-2017, 17:25 | #6 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | It looks like you can read the chip with testpoint and it has a bad name - 00000. This looks like firmware error and if you'd upgrade its firmware then eMMC would probably work but data would be gone. Had one eMMC like that, did those, and data was wiped on mine after firmware update. Connecting the chip with testpoint attached doesn't give you access to data on the chip either, it's only firmware update mode. I don't think there is anything you can do to recover that with EasyJTAG or any other eMMC only box. You'd have to try dumping data directly from the NAND chip inside eMMC package bypassing the controller. Here's an example on how it looks on dead microSD card with Rusolut tools. Process for eMMC is similar. |
The Following User Says Thank You to KrzychuG For This Useful Post: |
07-23-2017, 23:28 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi When you see "OCR" error it's mean FW controller is damaged so you can't read/write even with TP so i think better way is forget your data then just repair your phone |
