11-07-2020, 10:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | same opertation but different results with easy jtag classic and plus tools easy tag classic suite: Checking security ... Running:eMMC: Factory Format Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:2756 mV CMD Active Level:2817 mV Box IO Level:2800 mV CLK Rate:24000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. easy jtag plus: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 2756 mV CMD Active Level: 2817 mV EMMC Device Information : This Card is Removable Secure Digital Card EMMC CID: 1234565344202020000000029B011A9F EMMC CSD: 400E00325B59000075C57F800A400057 EMMC Manufacture : , EMMC NAME: SD , HEX: 534420202000 , S/N: 00029B01 , rev. 0x00 EMMC Manufacture ID: 0x12 , OEM ID: 0x56 , Device Type: Device (removable) , Date: 1/2007 EMMC ROM 1 (Main User Data) Capacity: 15075 MB (0003AE300000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x00 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: SD _00029B01_20201107_142510.extcsd EMMC Init completed. Operation: Erasing eMMC... Erasing for: ROM1 , start: 0x000000000000 , size: 0x0003AE300000 eMMC switching to ROM1 Erasing partition... Error erasing at address: 000000000000 , error: 0, No error ... Retry #1 Error erasing at address: 000000000000 , error: 0, No error ... Retry #2 Error erasing at address: 000000000000 , error: 0, No error ... Retry #3 Too many errors. Erasing has been stopped see the above errors, same operation but fails with easy jtag plus tool, and same thing happens with all the phones, unable to write by vendor, same errors, many times reported, this problem after latest version update, please solve fast, vivo s1 also getting same errors, then finally wrote all the partitions one by one write by vendor, which took full day |
The Following User Says Thank You to Bhagat20 For This Useful Post: |
11-08-2020, 10:57 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | EasyJTAG Plus software always is realy check write/erase for ROM2/3 and for begin of ROM1 EasyJTAG Classic software may be added this function later |
The Following User Says Thank You to layder For This Useful Post: |
11-09-2020, 09:59 | #5 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
below are the successful logs: CMD Pullup Level:2760 mV CMD Active Level:2814 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! SD Card Information SD CID : 1234565344202020000000029B011A9F SD CSD : 400E00325B59000075C57F800A400057 SD Manufacturer ID: 0012 , OEM ID: 3456 SD Date: 10/2017 Rev.0x0 SD NAME: SD , S/N: 667 SD NAME (HEX): 534420202020 SD Capacity: 15075 MB SD Permanent Write Protection: No SD Temporary Write Protection: No SD Password Locked: No Backup saved: SD _ 667_20201106_1859.extcsd Partition info successfully found ------ Detected 2 partitions ------ P0 (PARTITION_P6E) [0xe840f2ca00 0xcae440de00] Size: 811.566GB ------------------------------------ Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:2757 mV CMD Active Level:2817 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR Erasing 10000000 bytes from 00000000 ...ROM1 Erase Done. and many times happens, operation fails with easy jtag plus, but successful with classic suite. | |
11-09-2020, 11:30 | #6 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
11-11-2020, 10:36 | #8 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | EasyJTAG Classic not check erase ROM1 without "set check" I need next info 1) Read please first 32/64/128KB before erase, sent me a file 2) Read please first 32/64/128KB after EasyClassicJTAG erase, sent me a file 3) write some data to first 128kB with verify check, post results 4) sent me extcsd from this chip |
