07-27-2020, 10:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Samsung A107F A10S dead boot repair full solution Samsung A107F A10S dead boot repair full solution First Connect ISP points or raise memory for programming A107F ISP PINOUT Download the A107FXXU6BTF1 dumb file Secondly Explanation Back up 1GB dump to restore imei later -1 We format the memory - 2 Write the full attached dumb - 3 Write the protection files from the backup in step 1 only to retriece the -4 basic imei of the imei device Note: Without thes step the device turns off normally but without the baseband or imei Run the device in download mode and make software - 5 Now all Done best regard by pintu_das |
The Following 29 Users Say Thank You to pintu_das For This Useful Post: |
07-28-2020, 05:32 | #2 (permalink) | |
Insane Poster Join Date: Mar 2018 Location: iran
Member: 2823930 Status: Offline Thanks Meter: 45 | Quote:
Sent from my LG-H815 using Tapatalk | |
The Following 5 Users Say Thank You to saft For This Useful Post: |
12-09-2020, 13:30 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | wrong step order ....with this order you get unknown basband to fix imei you need : 1- connect your emmc and backup 1GB dump 2- formate the emmc 3- write downloaded dump ( A107FXXU6BTF1.rar) 4- reset frp 5- desolder pinout and put phone in download mode and flash it wth ( A107FXXU6BTF1_A107FMBC6BTF1_MBC ) firmware and power on it (unknown basband) dont worry 5- resolder easy jtag pinout and go to write by vendor select from image take your original dump ( first dump readed by easy jtage in 1 step ) 6- check : ( nv-ram, efs , sec_efs , nvcfg , nvdata ,protect1 , protect2 ,persist , proinfo) 7- write this checked partition and power on phone and now you get original imei and basband all ok. tested by me foufou34 br |
The Following 16 Users Say Thank You to foufou34 For This Useful Post: |
03-13-2022, 09:17 | #7 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | Quote:
The Following User Says Thank You to gsmkiller173 For This Useful Post: |
