Member: 1418143
Thanks Meter: 353 | Samsung A305F dead afrter write by vendor I receive for frp so I use to try write firmware by Emmc .
as some news samsung dont accept to go in Download .
but when I tried write as vendor it not more power on .
I tried wirte with repartition and without repartion . Quote:
12/11/2019 10:58:36 PM>
12/11/2019 10:58:36 PM> eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
12/11/2019 10:58:39 PM> Microsoft Windows 8.1 (64 bit) build 9600 (6.3.9600.18217)
12/11/2019 10:58:39 PM> Looking for EasyJTAG box...
12/11/2019 10:58:39 PM> EasyJTAG API ver. 3307
12/11/2019 10:58:42 PM> OpenUSB returned = 0
12/11/2019 10:58:43 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 10:58:44 PM> Card Serial = AA60949F
12/11/2019 10:58:44 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 10:59:48 PM> Error: First select the Pit-file
12/11/2019 11:06:37 PM> Looking for EasyJTAG box...
12/11/2019 11:06:37 PM> EasyJTAG API ver. 3307
12/11/2019 11:06:37 PM> Setting IO Levels to 1.8V
12/11/2019 11:06:37 PM> Setting frequence to 14 MHz
12/11/2019 11:06:39 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:06:39 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:06:42 PM> HiPower mode is ON
12/11/2019 11:06:42 PM> Error: First select the Pit-file
12/11/2019 11:06:42 PM> Setting frequence to 14 MHz
12/11/2019 11:06:42 PM> CMD Pullup Level: 1753 mV
12/11/2019 11:06:42 PM> CMD Active Level: 1835 mV
12/11/2019 11:06:42 PM> eMMC Init returned = -1
12/11/2019 11:06:42 PM> Can't init device. Reason: CMD Timeout Error
12/11/2019 11:06:48 PM> Error: First select the Pit-file
12/11/2019 11:24:09 PM> Looking for EasyJTAG box...
12/11/2019 11:24:09 PM> EasyJTAG API ver. 3307
12/11/2019 11:24:09 PM> Setting IO Levels to 1.8V
12/11/2019 11:24:09 PM> Setting frequence to 14 MHz
12/11/2019 11:24:10 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:24:10 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:24:13 PM> HiPower mode is ON
12/11/2019 11:24:13 PM> Setting frequence to 14 MHz
12/11/2019 11:24:13 PM> CMD Pullup Level: 195 mV
12/11/2019 11:24:13 PM> CMD Active Level: 1464 mV
12/11/2019 11:24:13 PM> eMMC Init returned = -1
12/11/2019 11:24:13 PM> Can't init device. Reason: CMD Timeout Error
12/11/2019 11:24:28 PM> Looking for EasyJTAG box...
12/11/2019 11:24:28 PM> EasyJTAG API ver. 3307
12/11/2019 11:24:28 PM> Setting IO Levels to 2.8V
12/11/2019 11:24:28 PM> Setting frequence to 14 MHz
12/11/2019 11:24:30 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:24:30 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:24:33 PM> HiPower mode is ON
12/11/2019 11:24:33 PM> Setting frequence to 14 MHz
12/11/2019 11:24:33 PM> CMD Pullup Level: 268 mV
12/11/2019 11:24:33 PM> CMD Active Level: 2062 mV
12/11/2019 11:24:33 PM> eMMC Init returned = -1
12/11/2019 11:24:33 PM> Can't init device. Reason: CMD Timeout Error
12/11/2019 11:25:14 PM> Looking for EasyJTAG box...
12/11/2019 11:25:14 PM> EasyJTAG API ver. 3307
12/11/2019 11:25:14 PM> Setting IO Levels to 3.3V
12/11/2019 11:25:14 PM> Setting frequence to 14 MHz
12/11/2019 11:25:15 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:25:15 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:25:18 PM> HiPower mode is ON
12/11/2019 11:25:18 PM> Setting frequence to 14 MHz
12/11/2019 11:25:18 PM> CMD Pullup Level: 206 mV
12/11/2019 11:25:18 PM> CMD Active Level: 2433 mV
12/11/2019 11:25:18 PM> eMMC Init returned = -1
12/11/2019 11:25:18 PM> Can't init device. Reason: CMD Timeout Error
12/11/2019 11:27:00 PM> Looking for EasyJTAG box...
12/11/2019 11:27:00 PM> EasyJTAG API ver. 3307
12/11/2019 11:27:00 PM> Setting IO Levels to 3.3V
12/11/2019 11:27:00 PM> Setting frequence to 14 MHz
12/11/2019 11:27:01 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:27:01 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:27:04 PM> HiPower mode is ON
12/11/2019 11:27:04 PM> Setting frequence to 14 MHz
12/11/2019 11:27:04 PM> CMD Pullup Level: 371 mV
12/11/2019 11:27:04 PM> CMD Active Level: 2516 mV
12/11/2019 11:27:05 PM> eMMC Init returned = 0
12/11/2019 11:27:05 PM> EMMC Device Information :
12/11/2019 11:27:05 PM> EMMC CID: 15010043555441343200B8084F51760C
12/11/2019 11:27:05 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/11/2019 11:27:05 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/11/2019 11:27:05 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/11/2019 11:27:05 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/11/2019 11:27:05 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/11/2019 11:27:05 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/11/2019 11:27:05 PM> EMMC Permanent Write Protection: No
12/11/2019 11:27:05 PM> EMMC Temporary Write Protection: No
12/11/2019 11:27:05 PM> Extended CSD Information :
12/11/2019 11:27:05 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/11/2019 11:27:05 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/11/2019 11:27:05 PM> Boot Bus Config: 0x01 , width 4bit
12/11/2019 11:27:05 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/11/2019 11:27:05 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/11/2019 11:27:05 PM> Device supports partitioning features
12/11/2019 11:27:05 PM> Device can have enhanced technological features in partitions and user data area
12/11/2019 11:27:05 PM> Device can have extended partitions attribute
12/11/2019 11:27:05 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/11/2019 11:27:05 PM> Backup saved: CUTA42_B8084F51_20191211_232705.extcsd
12/11/2019 11:27:05 PM> EMMC Init completed.
12/11/2019 11:27:12 PM> Looking for EasyJTAG box...
12/11/2019 11:27:12 PM> EasyJTAG API ver. 3307
12/11/2019 11:27:12 PM> Setting IO Levels to 3.3V
12/11/2019 11:27:12 PM> Setting frequence to 14 MHz
12/11/2019 11:27:14 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:27:14 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:27:17 PM> HiPower mode is ON
12/11/2019 11:27:17 PM> Setting frequence to 14 MHz
12/11/2019 11:27:17 PM> CMD Pullup Level: 371 mV
12/11/2019 11:27:17 PM> CMD Active Level: 2516 mV
12/11/2019 11:27:17 PM> eMMC Init returned = 0
12/11/2019 11:27:17 PM> EMMC Device Information :
12/11/2019 11:27:17 PM> EMMC CID: 15010043555441343200B8084F51760C
12/11/2019 11:27:17 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/11/2019 11:27:17 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/11/2019 11:27:17 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/11/2019 11:27:17 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/11/2019 11:27:17 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/11/2019 11:27:17 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/11/2019 11:27:17 PM> EMMC Permanent Write Protection: No
12/11/2019 11:27:17 PM> EMMC Temporary Write Protection: No
12/11/2019 11:27:17 PM> Extended CSD Information :
12/11/2019 11:27:17 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/11/2019 11:27:17 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/11/2019 11:27:17 PM> Boot Bus Config: 0x01 , width 4bit
12/11/2019 11:27:17 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/11/2019 11:27:17 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/11/2019 11:27:17 PM> Device supports partitioning features
12/11/2019 11:27:17 PM> Device can have enhanced technological features in partitions and user data area
12/11/2019 11:27:17 PM> Device can have extended partitions attribute
12/11/2019 11:27:17 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/11/2019 11:27:17 PM> Backup saved: CUTA42_B8084F51_20191211_232717.extcsd
12/11/2019 11:27:17 PM> EMMC Init completed.
12/11/2019 11:27:18 PM> Opening file: C:\Users\psy\Downloads\A30_SWA_OPEN.pit
12/11/2019 11:27:18 PM> Pit: A30_SWA_OPEN.pit
12/11/2019 11:27:18 PM> Entry count: 37
12/11/2019 11:27:18 PM> The size of the last section has been updated
12/11/2019 11:27:40 PM> Selected file: C:\Users\psy\Desktop\A305F\BL_A305FDDU1ASD5_CL1586 1487_QB23257044_REV00_user_low_ship.tar.md5
12/11/2019 11:27:40 PM> BL_A305FDDU1ASD5_CL15861487_QB23257044_REV00_user_ low_ship.tar.md5
12/11/2019 11:27:40 PM> The list of files in the firmware:
12/11/2019 11:27:40 PM> sboot.bin.lz4
12/11/2019 11:27:40 PM> param.bin.lz4
12/11/2019 11:27:40 PM> cm.bin.lz4
12/11/2019 11:27:40 PM> vbmeta.img.lz4
12/11/2019 11:27:45 PM> Selected file: C:\Users\psy\Desktop\A305F\AP_A305FDDU1ASD5_CL1586 1487_QB23257044_REV00_user_low_ship_meta_OS9.tar.m d5
12/11/2019 11:27:45 PM> AP_A305FDDU1ASD5_CL15861487_QB23257044_REV00_user_ low_ship_meta_OS9.tar.md5
12/11/2019 11:27:45 PM> The list of files in the firmware:
12/11/2019 11:27:45 PM> boot.img.lz4
12/11/2019 11:27:45 PM> recovery.img.lz4
12/11/2019 11:27:45 PM> dt.img.lz4
12/11/2019 11:27:45 PM> dtbo.img.lz4
12/11/2019 11:27:45 PM> system.img.lz4
12/11/2019 11:27:45 PM> vendor.img.lz4
12/11/2019 11:27:45 PM> userdata.img.lz4
12/11/2019 11:27:45 PM> vbmeta.img.lz4
12/11/2019 11:27:45 PM> meta-data/
12/11/2019 11:27:45 PM> meta-data/fota.zip
12/11/2019 11:27:45 PM> File: vbmeta.img - skip, as it has already been added
12/11/2019 11:27:49 PM> Selected file: C:\Users\psy\Desktop\A305F\CP_A305FXXU1ASD5_CP1246 9802_CL15861487_QB23257044_REV00_user_low_ship.tar .md5
12/11/2019 11:27:49 PM> CP_A305FXXU1ASD5_CP12469802_CL15861487_QB23257044_ REV00_user_low_ship.tar.md5
12/11/2019 11:27:49 PM> The list of files in the firmware:
12/11/2019 11:27:49 PM> modem.bin.lz4
12/11/2019 11:27:49 PM> modem_debug.bin.lz4
12/11/2019 11:27:53 PM> Selected file: C:\Users\psy\Desktop\A305F\CSC_OMC_OJM_A305FOJM1AS D5_CL15861487_QB23258806_REV00_user_low_ship.tar.m d5
12/11/2019 11:27:53 PM> CSC_OMC_OJM_A305FOJM1ASD5_CL15861487_QB23258806_RE V00_user_low_ship.tar.md5
12/11/2019 11:27:53 PM> The list of files in the firmware:
12/11/2019 11:27:53 PM> a30_swa_open.pit
12/11/2019 11:27:53 PM> cache.img.lz4
12/11/2019 11:27:53 PM> omr.img.lz4
12/11/2019 11:27:53 PM> product.img.lz4
12/11/2019 11:27:53 PM> meta-data/
12/11/2019 11:27:53 PM> meta-data/fota.zip
12/11/2019 11:28:12 PM> Looking for EasyJTAG box...
12/11/2019 11:28:12 PM> EasyJTAG API ver. 3307
12/11/2019 11:28:12 PM> Setting IO Levels to 3.3V
12/11/2019 11:28:12 PM> Setting frequence to 14 MHz
12/11/2019 11:28:14 PM> EasyJTAG Box Serial = 07008006EF0A852D
12/11/2019 11:28:14 PM> EasyJTAG Box Firmware = 1.63
12/11/2019 11:28:17 PM> HiPower mode is ON
12/11/2019 11:28:17 PM> Setting frequence to 14 MHz
12/11/2019 11:28:17 PM> CMD Pullup Level: 371 mV
12/11/2019 11:28:17 PM> CMD Active Level: 2526 mV
12/11/2019 11:28:17 PM> eMMC Init returned = 0
12/11/2019 11:28:17 PM> EMMC Device Information :
12/11/2019 11:28:17 PM> EMMC CID: 15010043555441343200B8084F51760C
12/11/2019 11:28:17 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/11/2019 11:28:17 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/11/2019 11:28:17 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/11/2019 11:28:17 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/11/2019 11:28:17 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/11/2019 11:28:17 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/11/2019 11:28:17 PM> EMMC Permanent Write Protection: No
12/11/2019 11:28:17 PM> EMMC Temporary Write Protection: No
12/11/2019 11:28:17 PM> Extended CSD Information :
12/11/2019 11:28:17 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/11/2019 11:28:17 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/11/2019 11:28:17 PM> Boot Bus Config: 0x01 , width 4bit
12/11/2019 11:28:17 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/11/2019 11:28:17 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/11/2019 11:28:17 PM> Device supports partitioning features
12/11/2019 11:28:17 PM> Device can have enhanced technological features in partitions and user data area
12/11/2019 11:28:17 PM> Device can have extended partitions attribute
12/11/2019 11:28:17 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/11/2019 11:28:17 PM> Backup saved: CUTA42_B8084F51_20191211_232817.extcsd
12/11/2019 11:28:17 PM> EMMC Init completed.
12/11/2019 11:28:17 PM> Operation: Write by vendor (Samsung)
12/11/2019 11:28:17 PM> Unpacking file: sboot.bin
12/11/2019 11:28:17 PM> Unpacking Lz4: sboot.bin.lz4
12/11/2019 11:28:17 PM> Unpacking file: cm.bin
12/11/2019 11:28:17 PM> Unpacking Lz4: cm.bin.lz4
12/11/2019 11:28:17 PM> Unpacking file: param.bin
12/11/2019 11:28:17 PM> Unpacking Lz4: param.bin.lz4
12/11/2019 11:28:17 PM> Unpacking file: boot.img
12/11/2019 11:28:17 PM> Unpacking Lz4: boot.img.lz4
12/11/2019 11:28:18 PM> Unpacking file: recovery.img
12/11/2019 11:28:18 PM> Unpacking Lz4: recovery.img.lz4
12/11/2019 11:28:18 PM> Unpacking file: dt.img
12/11/2019 11:28:18 PM> Unpacking Lz4: dt.img.lz4
12/11/2019 11:28:18 PM> Unpacking file: dtbo.img
12/11/2019 11:28:18 PM> Unpacking Lz4: dtbo.img.lz4
12/11/2019 11:28:18 PM> Unpacking file: modem.bin
12/11/2019 11:28:18 PM> Unpacking Lz4: modem.bin.lz4
12/11/2019 11:28:18 PM> Unpacking file: vbmeta.img
12/11/2019 11:28:18 PM> Unpacking Lz4: vbmeta.img.lz4
12/11/2019 11:28:18 PM> Unpacking file: system.img
12/11/2019 11:28:32 PM> Unpacking Lz4: system.img.lz4
12/11/2019 11:28:48 PM> Unpacking file: vendor.img
12/11/2019 11:28:49 PM> Unpacking Lz4: vendor.img.lz4
12/11/2019 11:28:50 PM> Unpacking file: product.img
12/11/2019 11:28:52 PM> Unpacking Lz4: product.img.lz4
12/11/2019 11:28:52 PM> Unpacking file: cache.img
12/11/2019 11:28:52 PM> Unpacking Lz4: cache.img.lz4
12/11/2019 11:28:52 PM> Unpacking file: omr.img
12/11/2019 11:28:52 PM> Unpacking Lz4: omr.img.lz4
12/11/2019 11:28:52 PM> Unpacking file: modem_debug.bin
12/11/2019 11:28:52 PM> Unpacking Lz4: modem_debug.bin.lz4
12/11/2019 11:28:52 PM> Unpacking file: userdata.img
12/11/2019 11:28:55 PM> Unpacking Lz4: userdata.img.lz4
12/11/2019 11:28:57 PM>
12/11/2019 11:28:57 PM> Partition name: BOOTLOADER
12/11/2019 11:28:57 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 4194304 bytes
12/11/2019 11:28:57 PM> eMMC switching to ROM2
12/11/2019 11:28:57 PM> Writing partition...
12/11/2019 11:29:10 PM> Done writing partition. Write speed: 318.07 KB/s
12/11/2019 11:29:10 PM> Partition name: CM
12/11/2019 11:29:10 PM> Filename: cm.bin , Offset: 000004800000 , filesize: 8388608 bytes
12/11/2019 11:29:10 PM> eMMC switching to ROM1
12/11/2019 11:29:10 PM> Writing partition...
12/11/2019 11:29:24 PM> Done writing partition. Write speed: 598.86 KB/s
12/11/2019 11:29:24 PM> Partition name: PARAM
12/11/2019 11:29:24 PM> Filename: param.bin , Offset: 000005D00000 , filesize: 2457600 bytes
12/11/2019 11:29:24 PM> eMMC switching to ROM1
12/11/2019 11:29:24 PM> Writing partition...
12/11/2019 11:29:28 PM> Done writing partition. Write speed: 653.03 KB/s
12/11/2019 11:29:28 PM> Partition name: BOOT
12/11/2019 11:29:28 PM> Filename: boot.img , Offset: 000006F00000 , filesize: 37748736 bytes
12/11/2019 11:29:28 PM> eMMC switching to ROM1
12/11/2019 11:29:28 PM> Writing partition...
12/11/2019 11:30:24 PM> Done writing partition. Write speed: 654.77 KB/s
12/11/2019 11:30:24 PM> Partition name: RECOVERY
12/11/2019 11:30:24 PM> Filename: recovery.img , Offset: 000009300000 , filesize: 55574528 bytes
12/11/2019 11:30:24 PM> eMMC switching to ROM1
12/11/2019 11:30:25 PM> Writing partition...
12/11/2019 11:31:48 PM> Done writing partition. Write speed: 654.39 KB/s
12/11/2019 11:31:48 PM> Partition name: DTB
12/11/2019 11:31:48 PM> Filename: dt.img , Offset: 00000C800000 , filesize: 8388608 bytes
12/11/2019 11:31:48 PM> eMMC switching to ROM1
12/11/2019 11:31:48 PM> Writing partition...
12/11/2019 11:32:00 PM> Done writing partition. Write speed: 654.19 KB/s
12/11/2019 11:32:00 PM> Partition name: DTBO
12/11/2019 11:32:00 PM> Filename: dtbo.img , Offset: 00000D000000 , filesize: 8388608 bytes
12/11/2019 11:32:00 PM> eMMC switching to ROM1
12/11/2019 11:32:00 PM> Writing partition...
12/11/2019 11:32:13 PM> Done writing partition. Write speed: 654.10 KB/s
12/11/2019 11:32:13 PM> Partition name: RADIO
12/11/2019 11:32:13 PM> Filename: modem.bin , Offset: 00000D800000 , filesize: 36649936 bytes
12/11/2019 11:32:13 PM> eMMC switching to ROM1
12/11/2019 11:32:13 PM> Writing partition...
12/11/2019 11:33:08 PM> Done writing partition. Write speed: 654.95 KB/s
12/11/2019 11:33:08 PM> Partition name: VBMETA
12/11/2019 11:33:08 PM> Filename: vbmeta.img , Offset: 000010980000 , filesize: 8592 bytes
12/11/2019 11:33:08 PM> eMMC switching to ROM1
12/11/2019 11:33:08 PM> Writing partition...
12/11/2019 11:33:08 PM> Done writing partition. Write speed: 381.77 KB/s
12/11/2019 11:33:08 PM> Partition name: SYSTEM
12/11/2019 11:33:08 PM> Filename: system.img , Offset: 000011000000 , filesize: 4294963600 bytes
12/11/2019 11:33:08 PM> Sparse image found v.1.0 Total chunks: 31
12/11/2019 11:58:18 PM> Error writing at address: 00004EBD2000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
12/12/2019 1:20:36 AM> Done writing partition. Write speed: 650.50 KB/s
12/12/2019 1:20:36 AM> Partition name: VENDOR
12/12/2019 1:20:37 AM> Filename: vendor.img , Offset: 00013D000000 , filesize: 349876444 bytes
12/12/2019 1:20:37 AM> eMMC switching to ROM1
12/12/2019 1:20:37 AM> Writing partition...
12/12/2019 1:20:37 AM> Sparse image found v.1.0 Total chunks: 16
12/12/2019 1:29:19 AM> Done writing partition. Write speed: 654.44 KB/s
12/12/2019 1:29:19 AM> Partition name: PRODUCT
12/12/2019 1:29:19 AM> Filename: product.img , Offset: 000160800000 , filesize: 129777896 bytes
12/12/2019 1:29:19 AM> eMMC switching to ROM1
12/12/2019 1:29:19 AM> Writing partition...
12/12/2019 1:29:19 AM> Sparse image found v.1.0 Total chunks: 17
12/12/2019 1:32:34 AM> Done writing partition. Write speed: 651.57 KB/s
12/12/2019 1:32:34 AM> Partition name: CACHE
12/12/2019 1:32:34 AM> Filename: cache.img , Offset: 000179800000 , filesize: 78020 bytes
12/12/2019 1:32:34 AM> eMMC switching to ROM1
12/12/2019 1:32:34 AM> Writing partition...
12/12/2019 1:32:34 AM> Sparse image found v.1.0 Total chunks: 14
12/12/2019 1:32:34 AM> Done writing partition. Write speed: 411.35 KB/s
12/12/2019 1:32:34 AM> Partition name: OMR
12/12/2019 1:32:34 AM> Filename: omr.img , Offset: 000192800000 , filesize: 45156 bytes
12/12/2019 1:32:34 AM> Sparse image found v.1.0 Total chunks: 6
12/12/2019 1:32:34 AM> Done writing partition. Write speed: 558.89 KB/s
12/12/2019 1:32:34 AM> Partition name: CP_DEBUG
12/12/2019 1:32:34 AM> Filename: modem_debug.bin , Offset: 000195A00000 , filesize: 5242880 bytes
12/12/2019 1:32:42 AM> Done writing partition. Write speed: 653.56 KB/s
12/12/2019 1:32:42 AM> Partition name: USERDATA
12/12/2019 1:32:42 AM> Filename: userdata.img , Offset: 000197300000 , filesize: 773145036 bytes
12/12/2019 1:32:42 AM> eMMC switching to ROM1
12/12/2019 1:32:42 AM> Writing partition...
12/12/2019 1:32:42 AM> Sparse image found v.1.0 Total chunks: 36
12/12/2019 1:51:57 AM> Done writing partition. Write speed: 654.09 KB/s
12/12/2019 1:51:57 AM> Check BootConfig for the selected vendor
12/12/2019 1:51:57 AM> All done time: [02:22:59:797]
12/12/2019 7:17:54 AM> Looking for EasyJTAG box...
12/12/2019 7:17:54 AM> EasyJTAG API ver. 3307
12/12/2019 7:17:54 AM> Setting IO Levels to 3.3V
12/12/2019 7:17:54 AM> Setting frequence to 14 MHz
12/12/2019 7:17:55 AM> EasyJTAG Box Serial = 07008006EF0A852D
12/12/2019 7:17:55 AM> EasyJTAG Box Firmware = 1.63
12/12/2019 7:17:58 AM> HiPower mode is ON
12/12/2019 7:17:58 AM> Setting frequence to 14 MHz
12/12/2019 7:17:58 AM> CMD Pullup Level: 299 mV
12/12/2019 7:17:58 AM> CMD Active Level: 2619 mV
12/12/2019 7:18:05 AM> eMMC Init returned = -103
12/12/2019 7:18:05 AM> Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
12/12/2019 7:18:23 AM> Looking for EasyJTAG box...
12/12/2019 7:18:23 AM> EasyJTAG API ver. 3307
12/12/2019 7:18:23 AM> Setting IO Levels to 3.3V
12/12/2019 7:18:23 AM> Setting frequence to 14 MHz
12/12/2019 7:18:24 AM> EasyJTAG Box Serial = 07008006EF0A852D
12/12/2019 7:18:24 AM> EasyJTAG Box Firmware = 1.63
12/12/2019 7:18:27 AM> HiPower mode is ON
12/12/2019 7:18:28 AM> Setting frequence to 14 MHz
12/12/2019 7:18:28 AM> CMD Pullup Level: 371 mV
12/12/2019 7:18:28 AM> CMD Active Level: 2516 mV
12/12/2019 7:18:28 AM> eMMC Init returned = 0
12/12/2019 7:18:28 AM> EMMC Device Information :
12/12/2019 7:18:28 AM> EMMC CID: 15010043555441343200B8084F51760C
12/12/2019 7:18:28 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/12/2019 7:18:28 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/12/2019 7:18:28 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/12/2019 7:18:28 AM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/12/2019 7:18:28 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/12/2019 7:18:28 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/12/2019 7:18:28 AM> EMMC Permanent Write Protection: No
12/12/2019 7:18:28 AM> EMMC Temporary Write Protection: No
12/12/2019 7:18:28 AM> Extended CSD Information :
12/12/2019 7:18:28 AM> Extended CSD rev: 1.8 (MMC 5.1)
12/12/2019 7:18:28 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/12/2019 7:18:28 AM> Boot Bus Config: 0x01 , width 4bit
12/12/2019 7:18:28 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/12/2019 7:18:28 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/12/2019 7:18:28 AM> Device supports partitioning features
12/12/2019 7:18:28 AM> Device can have enhanced technological features in partitions and user data area
12/12/2019 7:18:28 AM> Device can have extended partitions attribute
12/12/2019 7:18:28 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/12/2019 7:18:28 AM> Backup saved: CUTA42_B8084F51_20191212_071828.extcsd
12/12/2019 7:18:28 AM> EMMC Init completed.
12/12/2019 7:18:35 AM> Looking for EasyJTAG box...
12/12/2019 7:18:35 AM> EasyJTAG API ver. 3307
12/12/2019 7:18:35 AM> Setting IO Levels to 3.3V
12/12/2019 7:18:35 AM> Setting frequence to 14 MHz
12/12/2019 7:18:36 AM> EasyJTAG Box Serial = 07008006EF0A852D
12/12/2019 7:18:36 AM> EasyJTAG Box Firmware = 1.63
12/12/2019 7:18:39 AM> HiPower mode is ON
12/12/2019 7:18:39 AM> Setting frequence to 14 MHz
12/12/2019 7:18:39 AM> CMD Pullup Level: 381 mV
12/12/2019 7:18:39 AM> CMD Active Level: 2505 mV
12/12/2019 7:18:40 AM> eMMC Init returned = 0
12/12/2019 7:18:40 AM> EMMC Device Information :
12/12/2019 7:18:40 AM> EMMC CID: 15010043555441343200B8084F51760C
12/12/2019 7:18:40 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/12/2019 7:18:40 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/12/2019 7:18:40 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/12/2019 7:18:40 AM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/12/2019 7:18:40 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/12/2019 7:18:40 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/12/2019 7:18:40 AM> EMMC Permanent Write Protection: No
12/12/2019 7:18:40 AM> EMMC Temporary Write Protection: No
12/12/2019 7:18:40 AM> Extended CSD Information :
12/12/2019 7:18:40 AM> Extended CSD rev: 1.8 (MMC 5.1)
12/12/2019 7:18:40 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/12/2019 7:18:40 AM> Boot Bus Config: 0x01 , width 4bit
12/12/2019 7:18:40 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/12/2019 7:18:40 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/12/2019 7:18:40 AM> Device supports partitioning features
12/12/2019 7:18:40 AM> Device can have enhanced technological features in partitions and user data area
12/12/2019 7:18:40 AM> Device can have extended partitions attribute
12/12/2019 7:18:40 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/12/2019 7:18:40 AM> Backup saved: CUTA42_B8084F51_20191212_071840.extcsd
12/12/2019 7:18:40 AM> EMMC Init completed.
12/12/2019 7:18:40 AM> Get firmware version
12/12/2019 7:19:02 AM> Looking for EasyJTAG box...
12/12/2019 7:19:02 AM> EasyJTAG API ver. 3307
12/12/2019 7:19:02 AM> Setting IO Levels to 3.3V
12/12/2019 7:19:02 AM> Setting frequence to 14 MHz
12/12/2019 7:19:04 AM> EasyJTAG Box Serial = 07008006EF0A852D
12/12/2019 7:19:04 AM> EasyJTAG Box Firmware = 1.63
12/12/2019 7:19:07 AM> HiPower mode is ON
12/12/2019 7:19:07 AM> Setting frequence to 14 MHz
12/12/2019 7:19:07 AM> CMD Pullup Level: 381 mV
12/12/2019 7:19:07 AM> CMD Active Level: 2516 mV
12/12/2019 7:19:07 AM> eMMC Init returned = 0
12/12/2019 7:19:07 AM> EMMC Device Information :
12/12/2019 7:19:07 AM> EMMC CID: 15010043555441343200B8084F51760C
12/12/2019 7:19:07 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/12/2019 7:19:07 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/12/2019 7:19:07 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/12/2019 7:19:07 AM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/12/2019 7:19:07 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/12/2019 7:19:07 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/12/2019 7:19:07 AM> EMMC Permanent Write Protection: No
12/12/2019 7:19:07 AM> EMMC Temporary Write Protection: No
12/12/2019 7:19:07 AM> Extended CSD Information :
12/12/2019 7:19:07 AM> Extended CSD rev: 1.8 (MMC 5.1)
12/12/2019 7:19:07 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/12/2019 7:19:07 AM> Boot Bus Config: 0x01 , width 4bit
12/12/2019 7:19:07 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/12/2019 7:19:07 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/12/2019 7:19:07 AM> Device supports partitioning features
12/12/2019 7:19:07 AM> Device can have enhanced technological features in partitions and user data area
12/12/2019 7:19:07 AM> Device can have extended partitions attribute
12/12/2019 7:19:07 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/12/2019 7:19:07 AM> Backup saved: CUTA42_B8084F51_20191212_071907.extcsd
12/12/2019 7:19:07 AM> EMMC Init completed.
12/12/2019 7:19:07 AM> Opening file: C:\Users\psy\Downloads\A30_SWA_OPEN.pit
12/12/2019 7:19:07 AM> Pit: A30_SWA_OPEN.pit
12/12/2019 7:19:07 AM> Entry count: 37
12/12/2019 7:19:07 AM> The size of the last section has been updated
12/12/2019 7:19:25 AM> Selected file: C:\Users\psy\Desktop\A305F\BL_A305FDDU1ASD5_CL1586 1487_QB23257044_REV00_user_low_ship.tar.md5
12/12/2019 7:19:25 AM> BL_A305FDDU1ASD5_CL15861487_QB23257044_REV00_user_ low_ship.tar.md5
12/12/2019 7:19:25 AM> The list of files in the firmware:
12/12/2019 7:19:25 AM> sboot.bin.lz4
12/12/2019 7:19:25 AM> param.bin.lz4
12/12/2019 7:19:25 AM> cm.bin.lz4
12/12/2019 7:19:25 AM> vbmeta.img.lz4
12/12/2019 7:19:26 AM>
12/12/2019 7:19:31 AM> Selected file: C:\Users\psy\Desktop\A305F\AP_A305FDDU1ASD5_CL1586 1487_QB23257044_REV00_user_low_ship_meta_OS9.tar.m d5
12/12/2019 7:19:31 AM> AP_A305FDDU1ASD5_CL15861487_QB23257044_REV00_user_ low_ship_meta_OS9.tar.md5
12/12/2019 7:19:31 AM> The list of files in the firmware:
12/12/2019 7:19:31 AM> boot.img.lz4
12/12/2019 7:19:31 AM> recovery.img.lz4
12/12/2019 7:19:31 AM> dt.img.lz4
12/12/2019 7:19:31 AM> dtbo.img.lz4
12/12/2019 7:19:31 AM> system.img.lz4
12/12/2019 7:19:31 AM> vendor.img.lz4
12/12/2019 7:19:31 AM> userdata.img.lz4
12/12/2019 7:19:31 AM> vbmeta.img.lz4
12/12/2019 7:19:31 AM> meta-data/
12/12/2019 7:19:31 AM> meta-data/fota.zip
12/12/2019 7:19:31 AM> File: vbmeta.img - skip, as it has already been added
12/12/2019 7:19:53 AM> Looking for EasyJTAG box...
12/12/2019 7:19:53 AM> EasyJTAG API ver. 3307
12/12/2019 7:19:53 AM> Setting IO Levels to 3.3V
12/12/2019 7:19:53 AM> Setting frequence to 14 MHz
12/12/2019 7:19:54 AM> EasyJTAG Box Serial = 07008006EF0A852D
12/12/2019 7:19:54 AM> EasyJTAG Box Firmware = 1.63
12/12/2019 7:19:58 AM> HiPower mode is ON
12/12/2019 7:19:58 AM> Setting frequence to 14 MHz
12/12/2019 7:19:58 AM> CMD Pullup Level: 371 mV
12/12/2019 7:19:58 AM> CMD Active Level: 2505 mV
12/12/2019 7:19:58 AM> eMMC Init returned = 0
12/12/2019 7:19:58 AM> EMMC Device Information :
12/12/2019 7:19:58 AM> EMMC CID: 15010043555441343200B8084F51760C
12/12/2019 7:19:58 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
12/12/2019 7:19:58 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: B8084F51 , rev. 0x00
12/12/2019 7:19:58 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2019
12/12/2019 7:19:58 AM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/12/2019 7:19:58 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/12/2019 7:19:58 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1140 , Response: Not Clean
12/12/2019 7:19:58 AM> EMMC Permanent Write Protection: No
12/12/2019 7:19:58 AM> EMMC Temporary Write Protection: No
12/12/2019 7:19:58 AM> Extended CSD Information :
12/12/2019 7:19:58 AM> Extended CSD rev: 1.8 (MMC 5.1)
12/12/2019 7:19:58 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
12/12/2019 7:19:58 AM> Boot Bus Config: 0x01 , width 4bit
12/12/2019 7:19:58 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/12/2019 7:19:58 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/12/2019 7:19:58 AM> Device supports partitioning features
12/12/2019 7:19:58 AM> Device can have enhanced technological features in partitions and user data area
12/12/2019 7:19:58 AM> Device can have extended partitions attribute
12/12/2019 7:19:58 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/12/2019 7:19:58 AM> Backup saved: CUTA42_B8084F51_20191212_071958.extcsd
12/12/2019 7:19:58 AM> EMMC Init completed.
12/12/2019 7:19:58 AM> Operation: Write by vendor (Samsung)
12/12/2019 7:19:58 AM> Creating GPT-partitioninig
12/12/2019 7:19:58 AM> Writing PrimaryGPT at address: 000000000000
12/12/2019 7:19:58 AM> Writing BackupGPT at address: 000E8F7FBE00
12/12/2019 7:19:58 AM> Writing PIT at address: 000000004400
12/12/2019 7:19:58 AM> GPT-partitioning done
12/12/2019 7:19:58 AM> Unpacking file: sboot.bin
12/12/2019 7:19:58 AM> Unpacking Lz4: sboot.bin.lz4
12/12/2019 7:19:58 AM> Unpacking file: cm.bin
12/12/2019 7:19:58 AM> Unpacking Lz4: cm.bin.lz4
12/12/2019 7:19:58 AM> Unpacking file: param.bin
12/12/2019 7:19:58 AM> Unpacking Lz4: param.bin.lz4
12/12/2019 7:19:58 AM> Unpacking file: boot.img
12/12/2019 7:19:58 AM> Unpacking Lz4: boot.img.lz4
12/12/2019 7:19:58 AM> Unpacking file: recovery.img
12/12/2019 7:19:58 AM> Unpacking Lz4: recovery.img.lz4
12/12/2019 7:19:59 AM> Unpacking file: dt.img
12/12/2019 7:19:59 AM> Unpacking Lz4: dt.img.lz4
12/12/2019 7:19:59 AM> Unpacking file: dtbo.img
12/12/2019 7:19:59 AM> Unpacking Lz4: dtbo.img.lz4
12/12/2019 7:19:59 AM> Unpacking file: vbmeta.img
12/12/2019 7:19:59 AM> Unpacking Lz4: vbmeta.img.lz4
12/12/2019 7:19:59 AM> Unpacking file: system.img
12/12/2019 7:20:14 AM> Unpacking Lz4: system.img.lz4
12/12/2019 7:20:41 AM> Unpacking file: vendor.img
12/12/2019 7:20:43 AM> Unpacking Lz4: vendor.img.lz4
12/12/2019 7:20:44 AM>
12/12/2019 7:20:44 AM> Partition name: BOOTLOADER
12/12/2019 7:20:44 AM> Filename: sboot.bin , Offset: 000000000000 , filesize: 4194304 bytes
12/12/2019 7:20:44 AM> eMMC switching to ROM2
12/12/2019 7:20:44 AM> Erasing partition...
12/12/2019 7:20:57 AM> Writing partition...
12/12/2019 7:21:10 AM> Done writing partition. Write speed: 328.39 KB/s
12/12/2019 7:21:10 AM> Partition name: CM
12/12/2019 7:21:10 AM> Filename: cm.bin , Offset: 000004800000 , filesize: 8388608 bytes
12/12/2019 7:21:10 AM> eMMC switching to ROM1
12/12/2019 7:21:10 AM> Erasing partition...
12/12/2019 7:21:13 AM> Writing partition...
12/12/2019 7:21:26 AM> Done writing partition. Write speed: 631.49 KB/s
12/12/2019 7:21:26 AM> Partition name: PARAM
12/12/2019 7:21:26 AM> Filename: param.bin , Offset: 000005D00000 , filesize: 2457600 bytes
12/12/2019 7:21:26 AM> eMMC switching to ROM1
12/12/2019 7:21:26 AM> Erasing partition...
12/12/2019 7:21:27 AM> Writing partition...
12/12/2019 7:21:31 AM> Done writing partition. Write speed: 650.82 KB/s
12/12/2019 7:21:31 AM> Partition name: BOOT
12/12/2019 7:21:31 AM> Filename: boot.img , Offset: 000006F00000 , filesize: 37748736 bytes
12/12/2019 7:21:31 AM> eMMC switching to ROM1
12/12/2019 7:21:31 AM> Erasing partition...
12/12/2019 7:21:36 AM> Writing partition...
12/12/2019 7:22:32 AM> Done writing partition. Write speed: 654.47 KB/s
12/12/2019 7:22:32 AM> Partition name: RECOVERY
12/12/2019 7:22:32 AM> Filename: recovery.img , Offset: 000009300000 , filesize: 55574528 bytes
12/12/2019 7:22:32 AM> eMMC switching to ROM1
12/12/2019 7:22:33 AM> Erasing partition...
12/12/2019 7:22:40 AM> Writing partition...
12/12/2019 7:24:03 AM> Done writing partition. Write speed: 653.59 KB/s
12/12/2019 7:24:03 AM> Partition name: DTB
12/12/2019 7:24:03 AM> Filename: dt.img , Offset: 00000C800000 , filesize: 8388608 bytes
12/12/2019 7:24:03 AM> eMMC switching to ROM1
12/12/2019 7:24:03 AM> Erasing partition...
12/12/2019 7:24:04 AM> Writing partition...
12/12/2019 7:24:17 AM> Done writing partition. Write speed: 653.59 KB/s
12/12/2019 7:24:17 AM> Partition name: DTBO
12/12/2019 7:24:17 AM> Filename: dtbo.img , Offset: 00000D000000 , filesize: 8388608 bytes
12/12/2019 7:24:17 AM> eMMC switching to ROM1
12/12/2019 7:24:17 AM> Erasing partition...
12/12/2019 7:24:19 AM> Writing partition...
12/12/2019 7:24:31 AM> Done writing partition. Write speed: 655.21 KB/s
12/12/2019 7:24:31 AM> Partition name: VBMETA
12/12/2019 7:24:31 AM> Filename: vbmeta.img , Offset: 000010980000 , filesize: 8592 bytes
12/12/2019 7:24:31 AM> eMMC switching to ROM1
12/12/2019 7:24:31 AM> Erasing partition...
12/12/2019 7:24:32 AM> Writing partition...
12/12/2019 7:24:32 AM> Done writing partition. Write speed: 385.25 KB/s
12/12/2019 7:24:32 AM> Partition name: SYSTEM
12/12/2019 7:24:32 AM> Filename: system.img , Offset: 000011000000 , filesize: 4294963600 bytes
12/12/2019 7:24:32 AM> eMMC switching to ROM1
12/12/2019 7:24:32 AM> Erasing partition...
12/12/2019 7:24:46 AM> Error erasing at address: 000018700000 , error: -1, CMD Timeout Error ... Retry #1
12/12/2019 7:34:23 AM> Writing partition...
12/12/2019 7:34:23 AM> Sparse image found v.1.0 Total chunks: 31
12/12/2019 9:21:50 AM> Done writing partition. Write speed: 650.53 KB/s
12/12/2019 9:21:51 AM> Partition name: VENDOR
12/12/2019 9:21:51 AM> Filename: vendor.img , Offset: 00013D000000 , filesize: 349876444 bytes
12/12/2019 9:21:51 AM> eMMC switching to ROM1
12/12/2019 9:21:51 AM> Erasing partition...
12/12/2019 9:23:02 AM> Writing partition...
12/12/2019 9:23:02 AM> Sparse image found v.1.0 Total chunks: 16
12/12/2019 9:31:44 AM> Done writing partition. Write speed: 654.31 KB/s
12/12/2019 9:31:45 AM> Check BootConfig for the selected vendor
12/12/2019 9:31:45 AM> All done time: [02:11:00:355]
12/12/2019 9:31:45 AM> | |
