10-29-2020, 15:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | samsung a305f dead boot logs with easy jtag classic, detects partition but easy jtag plus doesnt detect? CMD Pullup Level:1259 mV CMD Active Level:1405 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010043555441343200AEF348A146D1 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2019 Rev.0x0 eMMC NAME: CUTA42 , S/N: 2935179425 eMMC NAME (HEX): 435554413432 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is not yet programmed (clear) or RPMB Read failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_2935179425_20201029_1926.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x23800000] Size: 568.0MB P26 (PRODUCT) [0x160800000 0x19000000] Size: 400.0MB P27 (CACHE) [0x179800000 0x19000000] Size: 400.0MB P28 (OMR) [0x192800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x195a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x195f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x197300000 0xcf8000000] Size: 51.875GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (51.875GB) Blocks Reading Error (0x197300400 , 2 , Reason: CMD Timeout Error ) Unable to mount USERDATA , code : 5 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. but easy jtag plus doesnt detect partition: 2020 7:17:08 PM> CMD Pullup Level: 1258 mV 10/29/2020 7:17:08 PM> CMD Active Level: 1406 mV 10/29/2020 7:17:08 PM> eMMC Init returned = 0 10/29/2020 7:17:08 PM> EMMC Device Information : 10/29/2020 7:17:08 PM> EMMC CID: 15010043555441343200AEF348A146D1 10/29/2020 7:17:08 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 10/29/2020 7:17:08 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CUTA42 , HEX: 435554413432 , S/N: AEF348A1 , rev. 0x00 10/29/2020 7:17:08 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 10/29/2020 7:17:08 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 10/29/2020 7:17:08 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/29/2020 7:17:08 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2610 , Response: Not Clean 10/29/2020 7:17:08 PM> EMMC Permanent Write Protection: No 10/29/2020 7:17:08 PM> EMMC Temporary Write Protection: No 10/29/2020 7:17:08 PM> Extended CSD Information : 10/29/2020 7:17:08 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/29/2020 7:17:08 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/29/2020 7:17:08 PM> Boot Bus Config: 0x01 , width 4bit 10/29/2020 7:17:08 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/29/2020 7:17:08 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/29/2020 7:17:08 PM> Device supports partitioning features 10/29/2020 7:17:08 PM> Device can have enhanced technological features in partitions and user data area 10/29/2020 7:17:08 PM> Device can have extended partitions attribute 10/29/2020 7:17:08 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/29/2020 7:17:08 PM> Backup saved: CUTA42_AEF348A1_20201029_191708.extcsd 10/29/2020 7:17:08 PM> EMMC Init completed. 10/29/2020 7:17:08 PM> 10/29/2020 7:17:09 PM> Scanning soft partitions 10/29/2020 7:17:09 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 10/29/2020 7:17:09 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 10/29/2020 7:17:09 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 10/29/2020 7:17:10 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #4 10/29/2020 7:17:10 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #5 10/29/2020 7:17:10 PM> Too many errors. Reading has been stopped 10/29/2020 7:17:10 PM> |
10-29-2020, 19:19 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | you have non-stable ISP connection 1) try to use lower freq (24-18Mhz) 2) try to use hipower mode (power board form USB, not use VCC/VCCQ) 3) try to use pull-up resistors (100-200 ohm for DAT_0/CMD) |
The Following 4 Users Say Thank You to layder For This Useful Post: |
