03-04-2021, 19:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | Samsung A315G boot repair, how to? Code: EMMC ROM1 (Main User Data) Capacity: 119280 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB RPMB Info mmc_init Error, Reason: CARD is Password Locked EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 |
03-04-2021, 20:40 | #2 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | Error trying to write the backup from ROM1 Code: Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:2072 mV CMD Active Level:2236 mV Input file : C:\Users\tavoo\Desktop\SAMSUNG A315G WALTER\EMMC_DV6DMB_ROM1_1GB_000000000000_000040000000.bin Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #1)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #2)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #3)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #4)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #5)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Write Block Failed, Reason: DATA SND CRC Error Done. Done with error(s) |
03-05-2021, 20:28 | #4 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | So, that means that every single time I get this message: RPMB Info mmc_init Error, Reason: CARD is Password Locked, means that there is no way to fix it!!! So and guess that replacing the emmc is not an option or can I replace it if I already got the ROM1 partition back it up? |
