12-09-2018, 20:57 | #16 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | |
The Following User Says Thank You to layder For This Useful Post: |
12-09-2018, 23:46 | #18 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
EasyJTAG Plus software are create 2 variant of EFS tar pack, but it can be write only at z3x Samsung Tool software. Efs at tar format are created when you "Read partition table" from eMMC at "Read by vendor - Samsung" If a converter from bin to tar would be simple, we will be created it long time ago. | |
The Following 2 Users Say Thank You to layder For This Useful Post: |
04-07-2019, 13:26 | #19 (permalink) |
Insane Poster Join Date: May 2018 Location: unknown
Member: 2837147 Status: Offline Thanks Meter: 92 | how to backup original imei G532G how to backup original imei G532G EMMC Device Information : EMMC CID: 90014A483847347592010F8258584405 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: 0F825858 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_0F825858_20190407_182502.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x04 30% - 40% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 Partition: nvram, [000000800000 - 000001000000], size: 000000800000 Partition: lk, [000001000000 - 000001200000], size: 000000200000 Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 Partition: secro, [000001400000 - 000001B00000], size: 000000700000 Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 Partition: EFS, [000002800000 - 000003000000], size: 000000800000 Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 Partition: recovery, [000005800000 - 000006800000], size: 000001000000 Partition: boot, [000006800000 - 000007800000], size: 000001000000 Partition: md1img, [000007800000 - 000009800000], size: 000002000000 Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-G532G Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532GDDU1ASA4 Firmware date = Fri Jan 18 18:16:08 KST 2019 |
04-08-2019, 15:12 | #22 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | use google translate, read this https://www.gsmforum.ru/threads/%D0%...amsung.321474/ we work to add those manuals to wiki at English Last edited by layder; 11-07-2020 at 09:26. |
09-06-2020, 05:03 | #24 (permalink) |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Sams g532g dead boot sucess..home work lock down... Too many errors writing has stoped 1st ..repair emmc life by gp partioning zero sizes 2 ..smart report..random verify emmc.. 3 write pit bootoader sucess but not done.still dead 4 write full firmware sucess but not done.still dead 5 write dump from the support finally set revive... 6 flash 4 file .set hang on logo....efs errr... 7.flash efs tar completely on...but no imei no service.. Sent from my SM-A305F using Tapatalk |
09-13-2020, 20:17 | #25 (permalink) |
Junior Member Join Date: Nov 2018
Member: 2880385 Status: Offline Thanks Meter: 6 | [QUOTE=nagesss;14207974]Too many errors writing has stoped 6 flash 4 file .set hang on logo....efs errr... 7.flash efs tar completely on...but no imei no service.. how to recover imei? |
The Following User Says Thank You to ronak7011 For This Useful Post: |
09-14-2020, 16:17 | #27 (permalink) |
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Layder sir..ihave 2 more g532g on dead boot....have checked it and its bac to life after writing dump.but it enters download mode but flashing failed with any firmware. Sent from my SM-A305F using Tapatalk |
09-15-2020, 07:18 | #28 (permalink) | |
read this topic, please https://forum.gsmhosting.com/vbb/f67...-guide-2380666 | |
10-31-2020, 10:40 | #29 (permalink) | |
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | [QUOTE=ronak7011;14214562] Quote:
If nvram efs and protect 1 and 2 is corrupted or not backuped.its like impossible at the moment Sent from my SM-A305F using Tapatalk | |
