04-16-2017, 15:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: India
Member: 1001635 Status: Offline Thanks Meter: 63 | samsung i8552 emmc repair I also download emmc dump from support but this file is corrupted. Please help me to repai this phone. Here is info: EasyJtag Suite Classic ver.: 2.5.0.8 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM69 Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA5A-68F4 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Checking NAND Image : Autodetected RAW data File successefuly loaded! Processing file... Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... CMD Pullup Level:2660 mV CMD Active Level:2743 mV Can't init device, Reason: CMD Timeout Error Done. Processing file... Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2660 mV CMD Active Level:2743 mV Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1557 mV CMD Active Level:2186 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K7U00M_ 730714314_20170416_1835.extcsd Done. Processing file... Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1557 mV CMD Active Level:2186 mV Can't open output file ! Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1557 mV CMD Active Level:2186 mV Box IO Level:2800 mV CLK Rate:7000 kHz Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :O:\Samsung_GT-I8552_I8552XXAMK2_dump_rom1_1gb\EMMC_ROM1_K7U00M_7 30714314_00000000_20000000.bin Retry reading adress 0x00000000 (Attempt #0) Retry Fail! Retry reading adress 0x00000000 (Attempt #0) Retry Fail! Retry reading adress 0x00000000 (Attempt #0) Retry Fail! Retry reading adress 0x00000000 (Attempt #0) Reading flash page stopped by user request Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1598 mV CMD Active Level:2196 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1598 mV CMD Active Level:2196 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1598 mV CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1598 mV CMD Active Level:2196 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1660 mV CMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 Warning: CMD Pullup Level (20 mV) too low , check cables etc.! CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 Warning: CMD Pullup Level (20 mV) too low , check cables etc.! CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:20 mV CMD Active Level:2217 mV Box IO Level:2800 mV CLK Rate:7000 kHz Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:422 mV CMD Active Level:2031 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1505 mV CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K7U00M_ 730714314_20170416_1857.extcsd Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1505 mV CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 kHz Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :O:\Samsung_GT-I8552_I8552XXAMK2_dump_rom1_1gb\EMMC_ROM1_K7U00M_7 30714314_00000000_20000000.bin Retry reading adress 0x04EC0000 (Attempt #0) Retry Success! Retry reading adress 0x05080000 (Attempt #0) Retry Success! Retry reading adress 0x05A00000 (Attempt #0) Retry Success! Retry reading adress 0x05AC0000 (Attempt #0) Retry Success! Retry reading adress 0x05C40000 (Attempt #0) Retry Success! Done. Read Speed: 613 kB/s Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0401200CB286071B, ,FW Ver.: 01.58 CMD Pullup Level:1567 mV CMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004B375530304D0A2B8DD0CA11C0 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0xA EMMC NAME: K7U00M , S/N: 730714314 EMMC NAME (HEX): 4B375530304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: K7U00M_ 730714314_20170416_1916.extcsd Done. |
