Old 04-12-2017, 17:39   #1 (permalink)
Member: 532180
Thanks Meter: 33
samsung i9192 unbrick help
samsung i9192 emmc chenge 8gb samsung and boot1,boot 2 and userdata complet programm
but phone is dead no dounlode mode (qualcomm hs-usb qdloader 9008) help me
---------- eMMC Device Information ----------
EMMC CID : 15010038574D423352003C545B173150
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 03/2014 Rev.0x0
EMMC NAME: 8WMB3R , S/N: 1012161303
EMMC NAME (HEX): 38574D42335200
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 8WMB3R_1012161303_20170412_2129.extcsd
Searching for partition tables...
Detected GPT over MBR...
Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Warning: Entries Count = 128
MMCBLK0P0 (MODEM) Range: [0X400000,0X3FFFE00] ,Len: 3C00000
MMCBLK0P1 (SBL1) Range: [0X4000000,0X401FE00] ,Len: 20000
MMCBLK0P2 (SBL2) Range: [0X4020000,0X405FE00] ,Len: 40000
MMCBLK0P3 (SBL3) Range: [0X4060000,0X40DFE00] ,Len: 80000
MMCBLK0P4 (ABOOT) Range: [0X40E0000,0X42DFE00] ,Len: 200000
MMCBLK0P5 (RPM) Range: [0X42E0000,0X435FE00] ,Len: 80000
MMCBLK0P6 (TZ) Range: [0X4360000,0X43DFE00] ,Len: 80000
MMCBLK0P7 (PAD) Range: [0X43E0000,0X505FE00] ,Len: C80000
MMCBLK0P8 (PARAM) Range: [0X5060000,0X585FE00] ,Len: 800000
MMCBLK0P9 (EFS) Range: [0X5860000,0X65FFE00] ,Len: DA0000
MMCBLK0P10 (MODEMST1) Range: [0X6600000,0X68FFE00] ,Len: 300000
MMCBLK0P11 (MODEMST2) Range: [0X6900000,0X6BFFE00] ,Len: 300000
MMCBLK0P12 (BOOT) Range: [0X6C00000,0X75FFE00] ,Len: A00000
MMCBLK0P13 (RECOVERY) Range: [0X7600000,0X7FFFE00] ,Len: A00000
MMCBLK0P14 (FOTA) Range: [0X8000000,0X89FFE00] ,Len: A00000
MMCBLK0P15 (BACKUP) Range: [0X8A00000,0X90FDE00] ,Len: 6FE000
MMCBLK0P16 (FSG) Range: [0X90FE000,0X93FDE00] ,Len: 300000
MMCBLK0P17 (SSD) Range: [0X93FE000,0X93FFE00] ,Len: 2000
MMCBLK0P18 (PERSIST) Range: [0X9400000,0X9BFFE00] ,Len: 800000
MMCBLK0P19 (PERSDATA) Range: [0X9C00000,0XA7FFE00] ,Len: C00000
MMCBLK0P20 (SYSTEM) Range: [0XA800000,0X683FFE00] ,Len: 5DC00000
MMCBLK0P21 (CACHE) Range: [0X68400000,0X74BFFE00] ,Len: C800000
MMCBLK0P22 (HIDDEN) Range: [0X74C00000,0X76FFFE00] ,Len: 2400000
MMCBLK0P23 (USERDATA) Range: [0X77000000,0X1D1FFBC00] ,Len: 15AFFBE00
Done...Presets has been updated...
Running:SAMSUNG: Read S.M.A.R.T Report...
Z3X EasyJtag Software ver. 2.5.0.8
Skip loading eMMC Addon Firmware
CMD Pullup Level:1722 mV
CMD Active Level:1794 mV
Box IO Level:1850 mV
CLK Rate:14000 khz
Reading S.M.A.R.T
S.M.A.R.T Ver. 0 , Card Error mode : Normal
Super Block size : 0x00400000 (4194304 bytes)
Super Page size : 0x00004000 (16384 bytes)
Optimal Write size : 0x00004000 (16384 bytes)
Read Reclaim count : 0
Optimal TRIM size : 0x00001000 (4096 bytes)
Total Number of banks : 1
Initial bad blocks per bank : 3,0,0,0
Runtime bad blocks per bank : 0,0,0,0
Reserved blocks left per bank : 49,0,0,0
All Erase counts (min,avg,max): 0,0,48
SLC Erase counts (min,avg,max): 1,11,48
MLC Erase counts (min,avg,max): 0,1,2
S.M.A.R.T Report Done.
something missing pls help me
Old 04-14-2017, 22:41   #2 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Just write latest bootloader.tar by easy plus
make sure your bootlader have full bl specially SBL1,because some TAR file have only update bl
Page generated in 0.14500 seconds with 8 queries
