01-25-2020, 20:54 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Samsung j510f emmc damaged Need help how to change emmc and process J510f log Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100513331334D4200DD20F22A43DD EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: Q313MB , HEX: 513331334D42 , S/N: DD20F22A , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 123205 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: Q313MB_DD20F22A_20200125_150955.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #4 Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #5 Too many errors. Reading has been stopped This redmi 4x emmc log plz check can i use this emmc in j510f Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100524836344142057049DEB6641F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RH64AB , HEX: 524836344142 , S/N: 7049DEB6 , rev. 0x05 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2017 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 18259 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RH64AB_7049DEB6_20200125_151120.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB) Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB) Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB) Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB) Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB) Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB) Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB) Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB) Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB) Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB) Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB) Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB) Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB) Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB) Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB) Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB) Partition: splash, [000014000000 - 000015400000], size: 000001400000 (20.0 MB) Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB) Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB) Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB) Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB) Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB) Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB) Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB) Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB) Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB) Partition: oem, [0000F6188000 - 0000FA188000], size: 000004000000 (64.0 MB) Partition: limits, [0000FC000000 - 0000FC008000], size: 000000008000 (32.0 KB) Partition: mota, [000100000000 - 000100080000], size: 000000080000 (512. KB) Partition: dip, [000100080000 - 000100180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000100180000 - 000102180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000102180000 - 000102200000], size: 000000080000 (512. KB) Partition: mcfg, [000102200000 - 000102600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000104000000 - 000104020000], size: 000000020000 (128. KB) Partition: lksecappbak, [000104020000 - 000104040000], size: 000000020000 (128. KB) Partition: cmnlib, [000104040000 - 000104080000], size: 000000040000 (256. KB) Partition: cmnlibbak, [000104080000 - 0001040C0000], size: 000000040000 (256. KB) Partition: cmnlib64, [0001040C0000 - 000104100000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000104100000 - 000104140000], size: 000000040000 (256. KB) Partition: keymaster, [000104140000 - 000104180000], size: 000000040000 (256. KB) Partition: keymasterbak, [000104180000 - 0001041C0000], size: 000000040000 (256. KB) Partition: apdp, [000108000000 - 000108040000], size: 000000040000 (256. KB) Partition: msadp, [000108040000 - 000108080000], size: 000000040000 (256. KB) Partition: dpo, [000108080000 - 000108082000], size: 000000002000 (8.00 KB) Partition: cust, [000108082000 - 000128082000], size: 000020000000 (512. MB) Partition: userdata, [000128082000 - 000E8F7FBE00], size: 000D67779E00 (53.6 GB) GPT header successfully parsed Get firmware version Brand = Xiaomi Manufacturer = Xiaomi Device = santoni Model = Redmi 4X Phone platform = msm8937 CPU Abi = arm64-v8a Android release = 6.0.1 Firmware version = MMB29M Miui Version = 7.6.8 Firmware date = Thu Jun 8 00:41:25 WIB 2017 |
01-25-2020, 21:11 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | 1) you need compatible eMMC with Clean RPMB 2) you need backup efs from old eMMC, and after restore it |
The Following User Says Thank You to layder For This Useful Post: |
01-28-2020, 20:08 | #8 (permalink) |
Member: 2636476 Status: Offline Thanks Meter: 61 | Then can i use this emmc in j510f if yes plz process for program this ic Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100524836344142057049DEB6641F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RH64AB , HEX: 524836344142 , S/N: 7049DEB6 , rev. 0x05 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2017 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 18259 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RH64AB_7049DEB6_20200125_151120.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB) Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB) Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB) Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB) Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB) Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB) Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB) Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB) Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB) Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB) Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB) Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB) Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB) Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB) Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB) Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB) Partition: splash, [000014000000 - 000015400000], size: 000001400000 (20.0 MB) Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB) Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB) Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB) Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB) Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB) Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB) Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB) Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB) Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB) Partition: oem, [0000F6188000 - 0000FA188000], size: 000004000000 (64.0 MB) Partition: limits, [0000FC000000 - 0000FC008000], size: 000000008000 (32.0 KB) Partition: mota, [000100000000 - 000100080000], size: 000000080000 (512. KB) Partition: dip, [000100080000 - 000100180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000100180000 - 000102180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000102180000 - 000102200000], size: 000000080000 (512. KB) Partition: mcfg, [000102200000 - 000102600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000104000000 - 000104020000], size: 000000020000 (128. KB) Partition: lksecappbak, [000104020000 - 000104040000], size: 000000020000 (128. KB) Partition: cmnlib, [000104040000 - 000104080000], size: 000000040000 (256. KB) Partition: cmnlibbak, [000104080000 - 0001040C0000], size: 000000040000 (256. KB) Partition: cmnlib64, [0001040C0000 - 000104100000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000104100000 - 000104140000], size: 000000040000 (256. KB) Partition: keymaster, [000104140000 - 000104180000], size: 000000040000 (256. KB) Partition: keymasterbak, [000104180000 - 0001041C0000], size: 000000040000 (256. KB) Partition: apdp, [000108000000 - 000108040000], size: 000000040000 (256. KB) Partition: msadp, [000108040000 - 000108080000], size: 000000040000 (256. KB) Partition: dpo, [000108080000 - 000108082000], size: 000000002000 (8.00 KB) Partition: cust, [000108082000 - 000128082000], size: 000020000000 (512. MB) Partition: userdata, [000128082000 - 000E8F7FBE00], size: 000D67779E00 (53.6 GB) GPT header successfully parsed Get firmware version Brand = Xiaomi Manufacturer = Xiaomi Device = santoni Model = Redmi 4X Phone platform = msm8937 CPU Abi = arm64-v8a Android release = 6.0.1 Firmware version = MMB29M Miui Version = 7.6.8 Firmware date = Thu Jun 8 00:41:25 WIB 2017 |
