04-07-2017, 15:13 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Samsung s6312 emmc repair done Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0101100DAF863348, ,FW Ver.: 01.58 CMD Pullup Level:1722 mV CMD Active Level:1722 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004A355530304D02D51F2E2490F6 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x2 EMMC NAME: J5U00M , S/N: 3575590436 EMMC NAME (HEX): 4A355530304D00 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: J5U00M_3575590436_20170406_1609.extcsd Searching for partition tables... Detected GPT over MBR... Invalid EFI Signature. Done. Length limit is enabled! Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 3 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142AA00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142AC00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142AE00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142B000... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142B200... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142B400... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142B600... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142B800... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142BA00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142BC00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142BE00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142C000... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142C200... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142C400... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142C600... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142C800... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142CA00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142CC00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142CE00... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000000200 bytes to 000142D000... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 0000005000 bytes to 0000000200... ROM1 (USER ROM) Done. Write Speed: 109 kB/s Length limit is enabled! Writing 0000025800 bytes to 0000005200... ROM1 (USER ROM) Done. Write Speed: 246 kB/s Length limit is enabled! Writing 0001400000 bytes to 000002AA00... ROM1 (USER ROM) Done. Write Speed: 963 kB/s Length limit is enabled! Writing 0000000200 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 4 kB/s Length limit is enabled! Writing 00000FA000 bytes to 0001800000... ROM1 (USER ROM) Done. Write Speed: 737 kB/s Length limit is enabled! Writing 00000FA000 bytes to 00018FA000... ROM1 (USER ROM) Done. Write Speed: 800 kB/s Length limit is enabled! Writing 00001F4000 bytes to 00019F4000... ROM1 (USER ROM) Done. Write Speed: 4376 kB/s Length limit is enabled! Writing 0000C00000 bytes to 0001BE8000... ROM1 (USER ROM) Done. Write Speed: 2145 kB/s Length limit is enabled! Writing 0000300000 bytes to 00027E8000... ROM1 (USER ROM) Done. Write Speed: 816 kB/s Length limit is enabled! Writing 0000300000 bytes to 0002AE8000... ROM1 (USER ROM) Done. Write Speed: 816 kB/s Length limit is enabled! Writing 0000400000 bytes to 0002DE8000... ROM1 (USER ROM) Done. Write Speed: 7913 kB/s Length limit is enabled! Writing 0000800000 bytes to 00031E8000... ROM1 (USER ROM) Done. Write Speed: 10754 kB/s Length limit is enabled! Writing 0000C00000 bytes to 00039E8000... ROM1 (USER ROM) Done. Write Speed: 1902 kB/s Length limit is enabled! Writing 0000400000 bytes to 00045E8000... ROM1 (USER ROM) Done. Write Speed: 8405 kB/s Length limit is enabled! Writing 0000400000 bytes to 00049E8000... ROM1 (USER ROM) Done. Write Speed: 8405 kB/s Length limit is enabled! Writing 0000C00000 bytes to 0004DE8000... ROM1 (USER ROM) Done. Write Speed: 2057 kB/s Length limit is enabled! Writing 0001800000 bytes to 00059E8000... ROM1 (USER ROM) Done. Write Speed: 27807 kB/s Length limit is enabled! Writing 0000400000 bytes to 00071E8000... ROM1 (USER ROM) Done. Write Speed: 8405 kB/s Length limit is enabled! Writing 0000080000 bytes to 00075E8000... ROM1 (USER ROM) Done. Write Speed: 1157 kB/s Length limit is enabled! Writing 0000200000 bytes to 0007668000... ROM1 (USER ROM) Done. Write Speed: 3738 kB/s Length limit is enabled! Writing 004B000000 bytes to 0007868000... ROM1 (USER ROM) Done. Write Speed: 1244 kB/s Length limit is enabled! Writing 002D000000 bytes to 0052868000... ROM1 (USER ROM) Done. Write Speed: 45783 kB/s Length limit is enabled! Writing 0006400000 bytes to 007F868000... ROM1 (USER ROM) Done. Write Speed: 2325 kB/s Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0101100DAF863348, ,FW Ver.: 01.58 CMD Pullup Level:1732 mV CMD Active Level:1711 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004A355530304D02D51F2E2490F6 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x2 EMMC NAME: J5U00M , S/N: 3575590436 EMMC NAME (HEX): 4A355530304D00 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: J5U00M_3575590436_20170406_1629.extcsd Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 0101100DAF863348, ,FW Ver.: 01.58 CMD Pullup Level:1722 mV CMD Active Level:1722 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004A355530304D02D51F2E2490F6 EMMC CSD : D02701320F5903FFF6DBFFE18E404028 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x2 EMMC NAME: J5U00M , S/N: 3575590436 EMMC NAME (HEX): 4A355530304D00 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: J5U00M_3575590436_20170406_1629.extcsd Searching for partition tables... Detected MBR... Disk Signature: 00000000 MMCBLK0P0 Type: Unknown:0x4d Start: 200 Len: 5000 MMCBLK0P1 Type: Unknown:0x45 Start: 5200 Len: 25800 MMCBLK0P2 Type: WIN95 FAT32 (LBA) Start: 2AA00 Len: 1400000 MMCBLK0P3 Type: Extended Start: 142AA00 Len: E7BD5600 Warning: Extended Partition Detected - this feature not tested MMCBLK0P4 Type: Unknown:0x46 Start: 1800000 Len: FA000 MMCBLK0P5 Type: Unknown:0x47 Start: 18FA000 Len: FA000 MMCBLK0P6 Type: Unknown:0x29 Start: 1BE8000 Len: C00000 MMCBLK0P7 Type: Unknown:0x2f Start: 31E8000 Len: 800000 MMCBLK0P8 Type: Unknown:0x49 Start: 7668000 Len: 200000 Done. |
