10-16-2021, 14:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 157 | samsung T295 pit error Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2006 mV CMD Active Level: 2147 mV EMMC Device Information : EMMC CID: 150100515836334D4200ADEBCC033855 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: ADEBCC03 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2021 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_ADEBCC03_20211016_182927.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000405000 - 000000485000], size: 000000080000 (512. KB) Partition: rpm, [000000485000 - 000000505000], size: 000000080000 (512. KB) Partition: tz, [000000505000 - 000000705000], size: 000000200000 (2.00 MB) Partition: devcfg, [000000705000 - 000000745000], size: 000000040000 (256. KB) Partition: dsp, [000000745000 - 000001745000], size: 000001000000 (16.0 MB) Partition: mdtp, [000001745000 - 000003745000], size: 000002000000 (32.0 MB) Partition: sbl1bak, [000003745000 - 0000037C5000], size: 000000080000 (512. KB) Partition: rpmbak, [0000037C5000 - 000003845000], size: 000000080000 (512. KB) Partition: tzbak, [000003845000 - 000003A45000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000003A45000 - 000003A85000], size: 000000040000 (256. KB) Partition: dspbak, [000003A85000 - 000004A85000], size: 000001000000 (16.0 MB) Partition: mdtpbak, [000004A85000 - 000007000000], size: 00000257B000 (37.4 MB) Partition: cmnlib, [000007000000 - 000007100000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000007100000 - 000007200000], size: 000000100000 (1.00 MB) Partition: keymaster, [000007200000 - 000007300000], size: 000000100000 (1.00 MB) Partition: aboot, [000007300000 - 000007500000], size: 000000200000 (2.00 MB) Partition: vbmeta, [000007500000 - 000007510000], size: 000000010000 (64.0 KB) Partition: reserved, [000007510000 - 000007800000], size: 0000002F0000 (2.94 MB) Partition: vk, [000007800000 - 000007A00000], size: 000000200000 (2.00 MB) Partition: em, [000007A00000 - 000007E00000], size: 000000400000 (4.00 MB) Partition: bksecapp, [000007E00000 - 000007E80000], size: 000000080000 (512. KB) Partition: btd, [000007E80000 - 000008000000], size: 000000180000 (1.50 MB) Partition: cmnlibbak, [000008000000 - 000008100000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000008100000 - 000008200000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000008200000 - 000008300000], size: 000000100000 (1.00 MB) Partition: abootbak, [000008300000 - 000008500000], size: 000000200000 (2.00 MB) Partition: dtbo, [000008500000 - 000008D00000], size: 000000800000 (8.00 MB) Partition: vbmetabak, [000008D00000 - 000008D10000], size: 000000010000 (64.0 KB) Partition: apnhlos, [000008D10000 - 00000F000000], size: 0000062F0000 (98.9 MB) Partition: fsc, [00000F000000 - 00000F340000], size: 000000340000 (3.25 MB) Partition: ssd, [00000F340000 - 00000F380000], size: 000000040000 (256. KB) Partition: mota, [00000F380000 - 00000F400000], size: 000000080000 (512. KB) Partition: dip, [00000F400000 - 00000F800000], size: 000000400000 (4.00 MB) Partition: ddr, [00000F800000 - 00000F880000], size: 000000080000 (512. KB) Partition: sec, [00000F880000 - 00000F8C0000], size: 000000040000 (256. KB) Partition: fsg, [00000F8C0000 - 0000102C0000], size: 000000A00000 (10.0 MB) Partition: limits, [0000102C0000 - 0000102C8000], size: 000000008000 (32.0 KB) Partition: devinfo, [0000102C8000 - 000010800000], size: 000000538000 (5.22 MB) Partition: pad, [000010800000 - 000010840000], size: 000000040000 (256. KB) Partition: modemst1, [000010840000 - 000010C40000], size: 000000400000 (4.00 MB) Partition: modemst2, [000010C40000 - 000011040000], size: 000000400000 (4.00 MB) Partition: sec_efs, [000011040000 - 000012040000], size: 000001000000 (16.0 MB) Partition: efs, [000012040000 - 000013040000], size: 000001000000 (16.0 MB) Partition: splash, [000013040000 - 000013B40000], size: 000000B00000 (11.0 MB) Partition: apdp, [000013B40000 - 000013B80000], size: 000000040000 (256. KB) Partition: msadp, [000013B80000 - 000013BC0000], size: 000000040000 (256. KB) Partition: param, [000013BC0000 - 0000147C0000], size: 000000C00000 (12.0 MB) Partition: persist, [0000147C0000 - 0000167C0000], size: 000002000000 (32.0 MB) Partition: misc, [0000167C0000 - 0000168C0000], size: 000000100000 (1.00 MB) Partition: syscfg, [0000168C0000 - 000016940000], size: 000000080000 (512. KB) Partition: mcfg, [000016940000 - 000016D40000], size: 000000400000 (4.00 MB) Partition: dpo, [000016D40000 - 000016D42000], size: 000000002000 (8.00 KB) Partition: logdump, [000016D42000 - 00001AD42000], size: 000004000000 (64.0 MB) Partition: keystore, [00001AD42000 - 00001ADC2000], size: 000000080000 (512. KB) Partition: config, [00001ADC2000 - 00001ADCA000], size: 000000008000 (32.0 KB) Partition: oem, [00001ADCA000 - 00002ADCA000], size: 000010000000 (256. MB) Partition: recovery, [00002ADCA000 - 00002EDCA000], size: 000004000000 (64.0 MB) Partition: boot, [00002EDCA000 - 000032DCA000], size: 000004000000 (64.0 MB) Partition: debug, [000032DCA000 - 000033800000], size: 000000A36000 (10.2 MB) Partition: steady, [000033800000 - 000033C00000], size: 000000400000 (4.00 MB) Partition: persistent, [000033C00000 - 000033C80000], size: 000000080000 (512. KB) Partition: bota, [000033C80000 - 000036000000], size: 000002380000 (35.5 MB) Partition: system, [000036000000 - 000129000000], size: 0000F3000000 (3.80 GB) Partition: vendor, [000129000000 - 000158800000], size: 00002F800000 (760. MB) Partition: product, [000158800000 - 000174800000], size: 00001C000000 (448. MB) Partition: cache, [000174800000 - 000188000000], size: 000013800000 (312. MB) Partition: omr, [000188000000 - 000189400000], size: 000001400000 (20.0 MB) Partition: modem, [000189400000 - 00018EC00000], size: 000005800000 (88.0 MB) Partition: userdata, [00018EC00000 - 000747BFBE00], size: 0005B8FFBE00 (22.8 GB) GPT header successfully parsed Get firmware version Error: Device_register [mount_0] failed PartType: LINUX Error: Device_register [mount_0] failed PartType: LINUX Firmware info not found tab was pit error. after repair emmc no download mode. please help me. i write pit file and BL also (BL_T295XXU4CUG1_CL21965548_QB41260280_REV00_user_ low_ship_MULTI_CERT.tar) |
