03-02-2018, 12:42 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: iran.ahwaz Age: 41
Member: 133927 Status: Offline Thanks Meter: 20 | samsung t555 i have porblam by this model.when conecet to pc only qualcomm hs usb qdloader 9008 and tablet not trun on.please see this log of emmc and help me. Compression is ON Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 05050E16C5350393, ,FW Ver.: 01.62 CMD Pullup Level:3155 mV CMD Active Level:3238 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 150100414A4E4233520331E1B41343EC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2016 Rev.0x3 EMMC NAME: AJNB3R , S/N: 836875283 EMMC NAME (HEX): 414A4E42335200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: AJNB3R_ 836875283_20180302_1448.extcsd Done. |
03-02-2018, 12:47 | #2 (permalink) |
Member: 133927 Status: Offline Thanks Meter: 20 | this is anthore log. Setting frequence to 7 Mhz CMD Pullup Level: 3165 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 150100414A4E4233520331E1B41343EC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG , EMMC NAME: AJNB3R , EMMC NAME (HEX): 414A4E423352 , S/N: 31E1B413 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2016 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: AJNB3R_31E1B413_20180302_151631.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Model = SM-T555 Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 5.0.2 Firmware version = LRX22G.T555XXU1AOJ1 Firmware date = Thu Oct 8 17:36:23 KST 2015 |
