SanDisk SD5C28B-16G Hi, any support for SanDisk SD5C28B-16G ?
Phone is WIKO DARKSIDE, flashing is ok but with no change in the phone, same desktop background, same android errors, seems like a "fake" flashing.
Desoldered eMMC, detected like this: Quote:
EasyJtag Suite ver.: 2.3.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
undefined
Android Explorer ver.: 1.0.0.6
eMMC ODIN ver.: 1.0.0.8
Successfully connected to box on COM76
Box S/N: 0A013xxxxxxxxx, ,FW Ver.: 01.55
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AAE9-F523 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 2.3.0.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0A013xxxxxxx ,FW Ver.: 01.55CMD Pullup Level:1546 mV
CMD Active Level:2547 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is off!
---------- eMMC Device Information ----------EMMC CID : 02000053444D30333290FFFFFFFF29BC
EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA
EMMC Manufacturer ID: 0002 , OEM ID: 0000
EMMC Date: 02/2006 Rev.0x90
EMMC NAME: SDM032, S/N: 4294967295
EMMC NAME (HEX): 53444D30333200
EMMC ROM1 (Main User Data) Capacity: 30 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.0 (MMC 4.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x00
Device NOT support partitioning feature
Device cannot have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: SDM032_4294967295_20160812_1410.extcsd
Done.
| Any reading operation will fail: Quote:
Retry Fail!Retry reading adress 0x00000000 (Attempt #5)
Retry Fail!Read Block Failed, Reason: CARD Data FIFO Timeout Error
Done.
| Detect regions from eMMC: Quote:
Data partitions (firmware parts) count is 128 (dec)
mmc_read_blocks(0 , 8 ), Reason: CARD Data FIFO Timeout Error
mmc_read_blocks(1 , 1 ), Reason: CMD CRC Error
mmc_read_blocks(FFFFFE00 > 1E9C000 ), Read address is invalid
Meta partitions (partitions storing partition table) count is 0 (dec)
Partitions are not found!
| Erasing eMMC: Quote:
CMD Pullup Level:2464 mVCMD Active Level:2567 mV
CLK Rate:14000 khz
Erasing 00020000 bytes from 00000000 ...ROM1Full Verify Enabled!
Verify Erased Block Failed , block #0x00000000
Erase Done.
| Any advice?
Thanks! |
