Old 04-16-2015, 18:38   #61 (permalink)
Member: 2379007
Sonork: 100.1664140
Thanks Meter: 4
Hello everyone I have the same problem
how can you solve?
Compression thread encountered exception: "Exception of type Compression Exception thrown, cause buffer error (-5)"
Old 04-21-2015, 12:59   #62 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
how can you solve?
post screen shot.
BR.
Old 04-23-2015, 04:21   #63 (permalink)
Member: 108131
Thanks Meter: 21
i'm i to see any file on the magic sd card after creation????
Hi, i go through the procedure as described in the images you shared but when i finish creating the magic sd card, i'm i to see any file (s) on the card as when i check the content after creation, there isn't a single file on the sd card.
it's still a blank sd card. i have tried several cards of varying sizes and the outcome has been the same.
what will you advice???
thanx and best wishes
Old 04-23-2015, 10:47   #64 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
mr blang please add sdcard mode tp photos to shell
Old 04-26-2015, 11:49   #65 (permalink)
Registered User
Member: 1494799
Sonork: 100.1602242
Thanks Meter: 15
i m doing make sd card but no drives show in target
Old 04-26-2015, 12:27   #66 (permalink)
Member: 1128422
Thanks Meter: 67
try run easy jtag from shell..., or run easy jtag as administrator will be ok
br
Old 04-26-2015, 20:54   #67 (permalink)
Member: 1935994
Sonork: 2345
mantab gan
izin sundul
Old 04-27-2015, 13:32   #68 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Originally Posted by naski View Post
mantab gan
izin sundul
Only English please read forum rules.
Old 05-04-2015, 16:30   #69 (permalink)
Member: 1090661
Thanks Meter: 15
here is the image with the problem...
Old 05-04-2015, 17:30   #70 (permalink)
Member: 1090661
Thanks Meter: 15
https://drive.google.com/file/d/0B8a...JfbVZpeVk/view
Old 05-09-2015, 04:36   #71 (permalink)
Member: 108131
Thanks Meter: 21
No file on sd card after creating magic sd card
Hi Team, please i'm i to see any files on the magic sd card after creating it???
reason for asking is i've done this for several of the supported devices and various files in the support and in all instance, though it says "SD operation done", there's no file on the sd card and when i insert to put the device in download mode, nothing happens.
i have tried this with SEVERAL sd cards and the result is the same.
please clarify this for me. thanx and best wishes
Old 05-09-2015, 05:31   #72 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
You can't see that created file in the sd card.
What is the your phone history.
Old 05-12-2015, 21:16   #73 (permalink)
Member: 1090661
Thanks Meter: 15
Originally Posted by .:MobileLife:. View Post
post screen shot.
BR.
Old 05-19-2015, 06:36   #74 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Originally Posted by gjalvarez View Post
Download bin once again
Run jtag exe in administrate mode
Change SDcard.
BR.
Old 05-19-2015, 07:37   #75 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 41
Sometimes you get corrupted zbin file from support, so download it again and try to open it with 7zip to see if it's ok
After you make the sd boot card, insert it in a working phone and it should notify you that this sd card is damaged or something like that..... Than you are ready to fix your dead phone
Use terraterm with a serial port, to force your device to enter sd card mode
Regards
Sent from my iPad using Tapatalk
Page generated in 0.23445 seconds with 8 queries
