08-28-2013, 14:20 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Sabia >Gizan>KSA
Member: 978854 Status: Offline Thanks Meter: 33 | need s3 i9300 dead boot steps i have tried several times ..sevral s3 i9300 connect ok here is log when i click on "Detect eMMC Card" Successefuly connected to box on COM21 Box S/N: -------------, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1650 mV CMD Active Level:2351 mV EMMC CID 1501003030303030300020110726589D EMMC CSD 902701320F5903FFF6DBFFEF8A404023 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 05/2005 FW rev.0x0 HW rev.0x0 EMMC Serial #: 537986854 EMMC NAME: 000000 EMMC Capacity: 16384 MB (High Density Card) ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x01] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x04] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x07] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x04] Access size [ACC_SIZE: 0x08] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x90] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x02000000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x01] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enable No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0xd38000 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 and when i want to write boot file "EMMC_ROM2_00000000_00200000" with selection "Partition to access:>Boot<" "Preset:>2mb<" Start hex 0x000000 Lenth Hex 0x200000 Click on "Write eMMC Card" selected this file downloaded from support "EMMC_ROM2_00000000_00200000" here is log Z3X Card Version : 22 Z3X Card Activation [JTAG] : 1 Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com Writing file...H:\box seuup\z3x\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_00 200000.bin Successefuly connected to box on COM21 Box S/N: 1616060D1E65C74C, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:1660 mV CMD Active Level:2361 mV EMMC CID 1501003030303030300020110726589D EMMC CSD 902701320F5903FFF6DBFFEF8A404023 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 05/2005 FW rev.0x0 HW rev.0x0 EMMC Serial #: 537986854 EMMC NAME: 000000 EMMC Capacity: 16384 MB (High Density Card) Writing 00200000 bytes to 00000000 ...ROM1 Write Speed: 364 kB/s Done !!! ------------------------ still mobile is dead what is solution pls define steps waiting or ur responce |
08-28-2013, 16:46 | #3 (permalink) |
Freak Poster Join Date: Dec 2007 Location: somewhere in KENYA
Member: 648607 Status: Offline Sonork: 100.1638674 Thanks Meter: 23 | EasyJtag Suite ver.: 1.0.61.1 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). Successefuly connected to box on COM91 Box S/N: 13131317E36D8374, ,FW Ver.: 01.47 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA83-8634 Z3X Card Version : 22 Z3X Card Activation [JTAG] : 1 Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com Successefuly connected to box on COM91 Box S/N: 13131317E36D8374, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2691 mV CMD Active Level:2763 mV eMMC ACK Error ( Check Connection ) eMMC Card initialisation error! whats wrong?????? |
