02-28-2016, 16:33 | #61 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Good Luck dear. Sent from my SM-N910C using Tapatalk |
02-29-2016, 11:51 | #62 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
@shamsulhaq @ shabirahmad22 this is not fake this is real we are doing this since months without removing emmc ic on i9300/n7100 if you need prove bring sets with such issue we will show you how to do this in few mins without removing emmc or any components Regards | |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
02-29-2016, 12:46 | #63 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | @shamsulhaq and shabirahmad22 : don't worry dear everything is no impossible in this world. one more update i have dumped emmc with usb flash drive pcb also connect memory card on it few years ago. i have got this picture from my facebook account you can see there. uploadfromtaptalk1456746335742.jpg Sent from my SM-N910C using Tapatalk |
08-11-2016, 17:37 | #68 (permalink) |
Freak Poster Join Date: May 2016 Location: Saudi Arab Dammam
Member: 2574123 Status: Offline Sonork: 100.1652460 Thanks Meter: 11 | before repair it was dead JTAG Connection is not supported for this device Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2010 mV CMD Active Level:2475 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 537986854_20160811_1922.extcsd Done. after repair Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2547 mV CMD Active Level:3124 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU000_ 538150534_20160811_1931.extcsd Done. world best z3x team |
The Following User Says Thank You to khanyunus For This Useful Post: |
