09-22-2021, 12:24 | #1 (permalink) |
Junior Member Join Date: May 2021 Location: Boot0,
Member: 2987544 Status: Offline Sonork: [email protected] Thanks Meter: 0 | USERDATA F2FS partition using EasyJtag+ introduction: So, am working on recoverying my Old data from Huawei y7P Phone, the phone dropped from high stairs while i was in work,(Telecommunication structure), i did reball both CPU and EMMC, the PCB is bent under CPU so i was not able to give him life again. Problem : In easyjtag, i did a full backup for everything, i notice that in easy+ the /USERDATA partition shows as raw. i thought i was MBR/GPT problem. after some digging and using binwalk with EMMC Manager , i found the partition to be F2FS filesystem, Not EXt4 or FAT32 . and thats why i was not able to read it using Easy+ software. after that i did run my ubuntu and successfully mount the partition, the next problem i face is the list of all folders are availble but what inside Code: /mnt/media/0 i did use Code: "sudo chown" Code: "sudo chmod" any idea how to resolve ? NOTE: Since am not able to update with tree result. i have attached the tree output as attachment. |
09-22-2021, 13:57 | #2 (permalink) |
Product Supporter Join Date: Sep 2017 Location: MH Unlocker Pro
Member: 2753718 Status: Offline Sonork: FB : MH Unlocker Pro Thanks Meter: 811 | Nand file system if its F2FS, Encrypted and useless to digging BR. SeharH |
The Following User Says Thank You to SeharH For This Useful Post: |
09-23-2021, 10:23 | #3 (permalink) | |
Member: 2987544 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Quote:
it got the salt and the key i guess, only missing the tools, any help ? | |
09-24-2021, 07:20 | #5 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Quote:
You need ufed pa which is $300 Let me know if want the tool | |
09-27-2021, 21:42 | #6 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | F2FS file system is supported for mount and extraction with various methods; First method: Using Linux and following this guide: Complexity level: Difficult Second method: Using Windows Tool (Mobile Revelator) which can be obtained from here: Note that not all F2FS images are supported. Try and feedback. br, mshibo Last edited by MiRoOo; 09-27-2021 at 21:51. |
The Following 2 Users Say Thank You to MiRoOo For This Useful Post: |
