Old 08-11-2020, 11:36   #1 (permalink)
Member: 1962832
Thanks Meter: 199
VIVO Y95 (1807) vibrate only
vivo y95 skynix emmc damage, iam change new compatable emmc
iam write direct via emmc dump file write success,firmware file write success
but device now power on vibrate only...
damage emmc number
H9TQ52ACLTMCUR-KUM
CHANGE EMMC NOW
KMRH60014A-B614
10.08.2020 11:51:01> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started..
10.08.2020 11:51:10> Box API Version: 3401
10.08.2020 11:51:10> FS Driver Version: 29062020
10.08.2020 11:51:10> SQLite Version: 3.32.0
10.08.2020 11:51:10> FSCK Engine Version: 29062020
10.08.2020 11:51:10> ESE DB Version: 29062020
10.08.2020 11:51:10> System Util Version: 29062020
10.08.2020 11:51:10> System: Windows NT 6.2 (Build 9200) / 64 BIT
10.08.2020 11:51:10> CPU: Intel(R) Pentium(R) CPU G2020 @ 2.90GHz
10.08.2020 11:51:10> Total RAM: 3.88 GB
10.08.2020 11:51:10> Telegram Support: https://t.me/z3xefm
10.08.2020 11:51:10> FRP Apps: Index of /frp
10.08.2020 11:51:13> Z3X Card Serial: AA6083B3
10.08.2020 11:51:13> EasyJtag Plus Box Found at: COM13
10.08.2020 11:51:13> EasyJtag Plus Box Firmware: 2.52.4
10.08.2020 11:51:27> Source: Qualcomm 9008 EMMC/UFS/AUTO
10.08.2020 11:51:27> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
10.08.2020 11:51:27> Box Voltage set to: 2800 mV
10.08.2020 11:51:27> Scanner Thread Created..
10.08.2020 11:51:27> Config: 1011111111101111
10.08.2020 11:51:27> Setup HiPower CLK: OFF
10.08.2020 11:51:27> Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT
10.08.2020 11:51:28> EasyJtag Plus Box Found! Result: 0/OK
10.08.2020 11:51:28> EasyJtag Plus S/N: 18FF51FF694D6BB3
10.08.2020 11:51:28> EasyJtag Plus Box FirmWare: 2.52
10.08.2020 11:51:28> Box Bus Width = 8 BIT
10.08.2020 11:51:28> Box Hardware = EasyJtag 2nd Generation
10.08.2020 11:51:28> Use Qlm 9008 (EDL) Mode..
10.08.2020 11:51:28> Please Connect Qlm Device in 9008 (EDL) Mode..
10.08.2020 11:51:28> Selected Primary Memory Type: AUTO
10.08.2020 11:51:28> Waiting For Device..
10.08.2020 11:51:28> Found Device:
10.08.2020 11:51:28> Path: \\?\usb#vid_05c6&pid_9008#6&df2ee03&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
10.08.2020 11:51:28> Desc: Qualcomm HS-USB QDLoader 9008
10.08.2020 11:51:28> HWID: USB\VID_05C6&PID_9008&REV_0000
10.08.2020 11:51:28> Name: Qualcomm HS-USB QDLoader 9008 (COM18)
10.08.2020 11:51:28> Vendor: Lenovo Inc.
10.08.2020 11:51:28> Trying Connect to Device..
10.08.2020 11:51:28> Open Port OK
10.08.2020 11:51:28> Sahara OK, Get Data..
10.08.2020 11:51:28> Read Qualcomm CPU Info OK
10.08.2020 11:51:28> S/N: 0x0E7FD2CB
10.08.2020 11:51:28> HW ID: 0x000BF0E100000000
10.08.2020 11:51:28> HASH: 0x60BA997FEF6DA9F05885FA11F1DD6D2A90D052A257A09C20 75D7246CC73C0D43
10.08.2020 11:51:28> SBL : 0x00000000
10.08.2020 11:51:28> DEV HASH: 0x000000171561
10.08.2020 11:51:28> CPU : SnapDragon 439 [SDM439]
10.08.2020 11:51:28> Loader Automatically Selected..
10.08.2020 11:51:28> Using Qlm Loader: 36AA2853000000171561.ldr
10.08.2020 11:51:28> Sending Loader..
10.08.2020 11:51:28> Loader Size: 390408 bytes
10.08.2020 11:51:28> Loader CheckSum: 0x48C842C5
10.08.2020 11:51:28> Loader Info:
10.08.2020 11:51:28> HWID: 0x000BF0E100000000
10.08.2020 11:51:28> SWID: 0x0000000000000003
10.08.2020 11:51:28> CPU: MSM8937
10.08.2020 11:51:29> CERT Cnt: 3
10.08.2020 11:51:29> Wait..
10.08.2020 11:51:33> Loader Sent, Run FireHose..
10.08.2020 11:51:33> Get Memory Type.. [AUTO]
10.08.2020 11:51:33> Detected Memory: EMMC
10.08.2020 11:51:33> FireHose Config Info: MSM8937, Memory: eMMC, Ver: 1
10.08.2020 11:51:33> Ext Info: 0x00002000/0x00100000/0x00001000/0x00001000
10.08.2020 11:51:33> FireHose Configure OK
10.08.2020 11:51:33> Get Protocol Type..
10.08.2020 11:51:34> Detected Generic FireHose Type..
10.08.2020 11:51:34> Reading EMMC ROM's Info..
10.08.2020 11:51:34> EMMC ROM #1 - 122142720 / 58.24 GB
10.08.2020 11:51:34> EMMC ROM #2 - 8192 / 4.00 MB
10.08.2020 11:51:34> EMMC ROM #3 - 8192 / 4.00 MB
10.08.2020 11:51:34> Memory Type: EMMC
10.08.2020 11:51:34> Physical Partitions: 3
10.08.2020 11:51:34> Packet Size: 16384
10.08.2020 11:51:34> Sector Size: 512
10.08.2020 11:51:34> EMMC Vendor: 0x15 - SAMSUNG
10.08.2020 11:51:34> EMMC NAME: RH64AB
10.08.2020 11:51:34> BOOT OK, FireHose Ready..
10.08.2020 11:51:34> Selected Primary Memory Type: EMMC
10.08.2020 11:51:34> Run Main Engine..
10.08.2020 11:51:34> Scanning GUID Partition Table from ROM1
10.08.2020 11:51:34> GUID Partition Table is Found. Max Parts: 60
10.08.2020 11:51:34> GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB
10.08.2020 11:51:34> GPT: MODEM [000001000000 - 000008000000] Size: 128.00 MB
10.08.2020 11:51:34> GPT: FSC [000009000000 - 000000000400] Size: 1.00 KB
10.08.2020 11:51:34> GPT: SSD [000009001000 - 000000002000] Size: 8.00 KB
10.08.2020 11:51:34> GPT: SBL1 [000009003000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: SBL1BAK [000009083000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: RPM [000009103000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: RPMBAK [000009183000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: TZ [000009203000 - 000000200000] Size: 2.00 MB
10.08.2020 11:51:34> GPT: TZBAK [000009403000 - 000000200000] Size: 2.00 MB
10.08.2020 11:51:34> GPT: DEVCFG [000009603000 - 000000040000] Size: 256.00 KB
10.08.2020 11:51:34> GPT: DEVCFGBAK [000009643000 - 000000040000] Size: 256.00 KB
10.08.2020 11:51:34> GPT: DSP [000009683000 - 000001000000] Size: 16.00 MB
10.08.2020 11:51:34> GPT: DSPBAK [00000A683000 - 000001000000] Size: 16.00 MB
10.08.2020 11:51:34> GPT: MODEMST1 [00000B683000 - 000000280000] Size: 2.50 MB
10.08.2020 11:51:34> GPT: MODEMST2 [00000B903000 - 000000280000] Size: 2.50 MB
10.08.2020 11:51:34> GPT: DDR [00000C000000 - 000000008000] Size: 32.00 KB
10.08.2020 11:51:34> GPT: FSG [00000C008000 - 000000280000] Size: 2.50 MB
10.08.2020 11:51:34> GPT: SEC [00000C288000 - 000000004000] Size: 16.00 KB
10.08.2020 11:51:34> GPT: SPLASH [00000D000000 - 000000B00000] Size: 11.00 MB
10.08.2020 11:51:34> GPT: ABOOT [00000E000000 - 000001000000] Size: 16.00 MB
10.08.2020 11:51:34> GPT: ABOOTBAK [00000F000000 - 000001000000] Size: 16.00 MB
10.08.2020 11:51:34> GPT: DTBO [000010000000 - 000000800000] Size: 8.00 MB
10.08.2020 11:51:34> GPT: DTBOBAK [000010800000 - 000000800000] Size: 8.00 MB
10.08.2020 11:51:34> GPT: VBMETA [000011000000 - 000000010000] Size: 64.00 KB
10.08.2020 11:51:34> GPT: VBMETABAK [000011010000 - 000000010000] Size: 64.00 KB
10.08.2020 11:51:34> GPT: BOOT [000011020000 - 000004000000] Size: 64.00 MB
10.08.2020 11:51:34> GPT: RECOVERY [000015020000 - 000004000000] Size: 64.00 MB
10.08.2020 11:51:34> GPT: DEVINFO [000019020000 - 000001000000] Size: 16.00 MB
10.08.2020 11:51:34> GPT: SYSTEM [00001A020000 - 000120000000] Size: 4.50 GB
10.08.2020 11:51:34> GPT: VENDOR [00013A020000 - 000050000000] Size: 1.25 GB
10.08.2020 11:51:34> GPT: CACHE [00018B000000 - 000010000000] Size: 256.00 MB
10.08.2020 11:51:34> GPT: PERSIST [00019B000000 - 000002000000] Size: 32.00 MB
10.08.2020 11:51:34> GPT: MISC [00019D000000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: KEYSTORE [00019D100000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: CONFIG [00019D180000 - 000000008000] Size: 32.00 KB
10.08.2020 11:51:34> GPT: OEM [00019D188000 - 000004000000] Size: 64.00 MB
10.08.2020 11:51:34> GPT: LIMITS [0001A2000000 - 000000008000] Size: 32.00 KB
10.08.2020 11:51:34> GPT: MOTA [0001A3000000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: DIP [0001A3080000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: MDTP [0001A3180000 - 000002000000] Size: 32.00 MB
10.08.2020 11:51:34> GPT: MDTPBAK [0001A5180000 - 000002000000] Size: 32.00 MB
10.08.2020 11:51:34> GPT: SYSCFG [0001A7180000 - 000000080000] Size: 512.00 KB
10.08.2020 11:51:34> GPT: MCFG [0001A7200000 - 000000400000] Size: 4.00 MB
10.08.2020 11:51:34> GPT: CMNLIB [0001A8000000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: CMNLIBBAK [0001A8100000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: CMNLIB64 [0001A8200000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: CMNLIB64BAK [0001A8300000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: KEYMASTER [0001A8400000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: KEYMASTERBAK [0001A8500000 - 000000100000] Size: 1.00 MB
10.08.2020 11:51:34> GPT: SURVIVAL [0001A8600000 - 000004000000] Size: 64.00 MB
10.08.2020 11:51:34> GPT: APDP [0001AD000000 - 000000040000] Size: 256.00 KB
10.08.2020 11:51:34> GPT: MSADP [0001AD040000 - 000000040000] Size: 256.00 KB
10.08.2020 11:51:34> GPT: DPO [0001AD080000 - 000000002000] Size: 8.00 KB
10.08.2020 11:51:34> GPT: LOGDUMP [0001AD082000 - 000004000000] Size: 64.00 MB
10.08.2020 11:51:34> GPT: APANIC [0001B1082000 - 000000A00000] Size: 10.00 MB
10.08.2020 11:51:34> GPT: BACKUP [0001B1A82000 - 000000A00000] Size: 10.00 MB
10.08.2020 11:51:34> GPT: SEED [0001B2482000 - 000000400000] Size: 4.00 MB
10.08.2020 11:51:34> GPT: RESERVED [0001B2882000 - 000000A00000] Size: 10.00 MB
10.08.2020 11:51:34> GPT: USERDATA [0001B3282000 - 000CDC579E00] Size: 51.44 GB
10.08.2020 11:51:34> GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16.50 KB
10.08.2020 11:51:34> Reading Table Completed
10.08.2020 11:51:34> Scanning GUID Partition Table from ROM2
10.08.2020 11:51:34> GPT Signature Not Found. Break..
10.08.2020 11:51:34> Scanning GUID Partition Table from ROM3
10.08.2020 11:51:34> Partition #5 mount as [/MODEM] - 128.00 MB
10.08.2020 11:51:34> Partition #16 mount as [/dev_16] - 16.00 MB
10.08.2020 11:51:34> Partition #17 mount as [/dev_17] - 16.00 MB
10.08.2020 11:51:34> Partition #33 mount as [/dev_33] - 4.50 GB
10.08.2020 11:51:34> Partition #34 mount as [/dev_34] - 1.25 GB
10.08.2020 11:51:34> Partition #35 mount as [/dev_35] - 256.00 MB
10.08.2020 11:51:34> Partition #36 mount as [/dev_36] - 32.00 MB
10.08.2020 11:51:34> Partition #40 mount as [/dev_40] - 64.00 MB
10.08.2020 11:51:34> Partition #63 mount as [/dev_63] - 51.44 GB
10.08.2020 11:51:34> EmptyCheck:
10.08.2020 11:51:34> EMPTY - #17 - [MODEMST1]
10.08.2020 11:51:34> EMPTY - #18 - [MODEMST2]
10.08.2020 11:51:34> EMPTY - #22 - [SPLASH]
10.08.2020 11:51:34> EMPTY - #27 - [VBMETA]
10.08.2020 11:51:34> EMPTY - #28 - [VBMETABAK]
10.08.2020 11:51:34> EMPTY - #36 - [MISC]
10.08.2020 11:51:34> EMPTY - #37 - [KEYSTORE]
10.08.2020 11:51:34> EMPTY - #38 - [CONFIG]
10.08.2020 11:51:34> EMPTY - #40 - [LIMITS]
10.08.2020 11:51:35> EMPTY - #41 - [MOTA]
10.08.2020 11:51:35> EMPTY - #42 - [DIP]
10.08.2020 11:51:35> EMPTY - #45 - [SYSCFG]
10.08.2020 11:51:35> EMPTY - #46 - [MCFG]
10.08.2020 11:51:35> EMPTY - #54 - [APDP]
10.08.2020 11:51:35> EMPTY - #55 - [MSADP]
10.08.2020 11:51:35> EMPTY - #56 - [DPO]
10.08.2020 11:51:35> EMPTY - #57 - [LOGDUMP]
10.08.2020 11:51:35> EMPTY - #60 - [SEED]
10.08.2020 11:51:35> EMPTY - #61 - [RESERVED]
10.08.2020 11:51:35> EmptyCheck: Done
10.08.2020 11:51:35> Android Info:
10.08.2020 11:51:35> Brand = vivo
10.08.2020 11:51:35> Vendor = vivo
10.08.2020 11:51:35> Device = msm8937_64
10.08.2020 11:51:35> Model = vivo 1807
10.08.2020 11:51:35> Product = msm8937_64
10.08.2020 11:51:35> CPU ABI = arm64-v8a
10.08.2020 11:51:35> Android Version = 8.1.0
10.08.2020 11:51:35> Firm Version = OPM1.171019.026 release-keys
10.08.2020 11:51:35> Inc. Version = eng.compil.20181026.204722
10.08.2020 11:51:35> Firm Date = Fri Oct 26 20:47:22 CST 2018
10.08.2020 11:51:35> Security Patch = 2018-10-01
10.08.2020 11:51:35> Platform = msm8937
10.08.2020 11:51:35> Scanner Thread Terminated
10.08.2020 11:51:35> Elapsed: 00:00:08:094
10.08.2020 11:51:35> Found 64 Partition(s)..
10.08.2020 11:51:35> Scan Done. Init Main Engine...
10.08.2020 11:51:35> Use Qlm EMMC Device: Qualcomm HS-USB QDLoader 9008 (COM18)
10.08.2020 11:51:35> Reader Engine Initialized.. 0/OK
10.08.2020 11:51:35> Source: Qualcomm 9008 EMMC/UFS/AUTO
10.08.2020 11:51:35> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
10.08.2020 11:51:35> Config: 1011111111101111
10.08.2020 11:51:35> Operation Done: [Init Engine], Elapsed: 00:00:00:031
Page generated in 0.14401 seconds with 8 queries
