05-05-2017, 01:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: syria Age: 46
Member: 257716 Status: Offline Sonork: 1650684 Thanks Meter: 57 | what hell with my box Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: , ,FW Ver.: 01.58 CMD Pullup Level:1711 mV CMD Active Level:1835 mV Box IO Level:1800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
05-05-2017, 08:27 | #2 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
It doesn't look like box problem. Check your adapters VCC voltage 2.8V or 3.3 V with multimeter. Make sure that adapter voltages 1.8 and 2.8 are not swapped (some adapters have swapped VCC 2.8V and VCCQ 1.8V voltage marking). Also provide detailed info and photos of your ISP setup. Best Regards Last edited by vikboston; 05-05-2017 at 08:43. | |
05-06-2017, 12:27 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Hmm, didn't he set too low voltage in settings (at least on this log)? At 1.8 rarely any eMMC can be properly deteced. I'd switch to 2.8V and check again. |
